Adding preview screenshots to Discourse themes
:bookmark: This guide explains how to add preview screenshots to your Discourse theme to showcase how it looks in both light and dark modes.
:person_raising_hand: Required user: Theme developers
Adding preview screenshots to your Discourse theme helps users quickly understand how your theme looks before they install it. This guide will walk you through adding light and dark mode screenshots to your theme.
Creating the screenshots folder
To add preview screenshots to your theme:
  1. Create a folder called screenshots in the root directory of your theme
  2. Add two image files to this folder:
    • light.webp - Shows your theme in light mode
    • dark.webp - Shows your theme in dark mode
Setting up the image files
Your screenshot images must meet these requirements:
  • Ratio: 16:9 aspect ratio
  • Dimensions: 2560 × 1440 pixels (recommended)
  • File size: Under 1MB per image
  • Format: WebP, PNG, JPEG
:information_source: Using the recommended dimensions ensures your screenshots look crisp on high-resolution displays while maintaining reasonable file sizes.
Updating the about.json file
After creating your screenshots, you need to update your theme’s about.json file to include references to these images:
  1. Open your theme’s about.json file
  2. Add the screenshots array to the JSON object:
  "screenshots": ["screenshots/light.webp", "screenshots/dark.webp"]
Best practices for theme screenshots
Capturing your theme
When taking screenshots of your theme:
  • Show the main interface components that make your theme unique.
  • Include examples of your theme’s color palette and typography.
  • Ensure both screenshots show the same view for easy comparison.
  • Use realistic content rather than placeholder text where possible.
Image optimization
Keep your images under the 1MB size limit by:
  • Using WebP format, as it combines the advantages of JPEG and PNG, offering more efficient compression than both.
  • For PNG format, using optimization tools like TinyPNG or ImageOptim.
  • Removing unnecessary metadata from image files.
  • Considering slightly reduced dimensions if needed while maintaining the 16:9 ratio.
Common issues and solutions
Images not appearing in theme preview
Issue: Screenshots don’t appear when viewing the theme in the admin panel.
Solution: Verify that:
  1. Your file names in about.json exactly match the actual file names (these are case-sensitive).
  2. The images are properly uploaded to the theme’s repository in the screenshots folder.
File size too large
Issue: Image files exceed the 1MB limit.
Solution:
  1. Use image optimization tools to reduce file size.
  2. Reduce image dimensions while maintaining the 16:9 ratio.
  3. Consider using a more efficient compression method.
FAQs
Q: Do I need both light and dark screenshots?
A: It is not required, but it’s good practice to include both light and dark screenshots. If you only include one, the same image will be displayed for both light and dark schemes. If no image is provided at all, a fallback will be displayed.
Q: Can I use a different image format than PNG?
A: PNG is recommended for its balance of quality and size. While other formats might work, PNG is the standard for Discourse theme screenshots.
Q: How do I take good screenshots of my theme?
A: Use a full-screen browser window at 2560×1440 resolution with developer tools closed. Set your theme to light mode for one screenshot and dark mode for the other.
Additional resources
This document is version controlled - suggest changes on github.
3 curtidas
Acho que a captura de tela escura deveria aparecer quando estou no modo escuro? Não funciona para mim, não tenho certeza se é um bug ou se estou perdendo alguma coisa.
1 curtida
Notei algo semelhante. Vejo a versão escura no modo claro.
Ao fazer o upload das minhas capturas de tela, recebi a mensagem:
Ocorreu um erro: As capturas de tela do tema devem ter no máximo 3840x2160. A captura de tela dark.webp excede isso. Suas dimensões são 4004x2024.
Talvez esse máximo pudesse ser mencionado nesta documentação?
Edição: aparentemente também não se importa com a proporção de aspecto de 16:9
Acabei de reduzir minha imagem para 3840 × 1941 e está funcionando bem.
