Install the Discourse Theme CLI console app to help you build themes
The discourse Discourse Theme CLI is a ruby gem that allows you to use your editor of choice when developing Discourse themes and theme components. As you save files the CLI will update the remote theme or component and changes to it will appear live!
Installing
To play with it, make sure you have Ruby 2.5 or up installed.
If you are on Windows, you have 2 options:
Option 1: Windows Subsystem for Linux.
Windows 10 has access to a full Linux environment, you can use it to install ruby simply with sudo apt-get install ruby, this will give you Ruby 2.3.
Options 2: Older Windows
Older versions of Windows have no access to WSL, you can easily install Ruby with Ruby Installer, go for the recommended version and default settings for the install.
Mac OS version 10.13.3 ship with Ruby 2.3 out of the box, nothing special is needed. If you are running an earlier version of Mac OS consider using rvm, rbenv or homebrew to install a recent ruby.
Once Ruby 2.2 or later is running, open a terminal or command shell and run:
gem install discourse_theme
Once installed, to learn more about it:
discourse_theme
Upgrading
gem update discourse_theme
Features
The CLI provides 3 main functions:
discourse_theme new
You can use it to quickly create a new theme with discourse_theme new YOUR_DIR_NAME
discourse_theme watch
You can use it to monitor a theme and synchronize with a discourse site (with live refresh) using discourse_theme watch YOUR_DIR_NAME
What this means is that you can use your own editor to edit you theme and site will magically :unicorn: update with the changes!
discourse_theme download
You can download an existing theme from Discourse using discourse_theme download YOUR_DIR_NAME. You will then be given the option to start “watching” straight away!
Credentials
You will need to generate an API Key. Go to the admin area and generate a key there.
  • :exclamation: Select a “User Level” of Single User when generating the key, not All Users.
  • :exclamation: Make sure to check Global Key or you will receive 403 forbidden errors.
Credentials are (optionally) stored at ~/.discourse_theme. API keys are stored per-site, and the URL/theme_id for each directory is also tracked. If you ever need to change your settings, just add --reset to any command and you will be prompted for all values again.
Testimonials
“This tool is truly a GEM!” @awole20
“This is very very good.” @awesomerobot
“It’s working :slight_smile: And it’s pretty dosh garn cool. Nice!” @angus
“OMG. It’s unbelievable.” @pfaffman
This document is version controlled - suggest changes on github.
Theme Creator, create and show themes without installing Discourse!
CSS Theme Contest (with Prizes!)
Customizing handlebars templates
Setting up a solid workflow for custom theme development
Theme Developer Quick Reference Guide
Structure of themes and theme components
Automating Discourse Plugin Setup with `create-discourse-plugin` gem
Developing Plugins Faster by separating the frontend into a theme component
Feedback on "on-discourse" javascript for setting up custom JS for each page?
Add settings to your Discourse theme
Get started with Theme Creator and the Theme CLI
Designer's Guide to getting started with themes in Discourse
Split up theme Javascript into multiple files
Updated Custom Header Icon: Post Data via URL
Theme Developer Tutorial: 2. Creating a remote theme
Developing Discourse Themes & Theme Components
Hiding GUI elements for new users (less overwhelming)
Add custom content that only appears on your homepage
Custom CSS/HTML
If you want to edit this theme, you must submit a change on its repository
Edit CSS/HTML editor cursor offset makes it unusable due to CSS font override
How "difficult" is modifying/extending Discourse for a backend dev
Exporting a Theme from Staging and Importing it to the Production portal
Using Plugin Outlet Connectors from a Theme or Plugin
Downloaded component installs fine, but does not once changed/re-zipped
What are the benefits of a dev environment?
3.2.0.beta2-dev (7019dbcfe1) does not load CSS from common.scss anymore
End-to-end system testing for themes and theme components
Different CSS changes for different color schemes
Need help integrating code wrote on Edittext to the Discourse
How to add a custom button in user profile card?
Remote themes not in database
When to use a plugin vs theme component?
Discourse core is switching to pnpm for JS package management
Using the new custom-homepage feature
Focus the editor when title is pre-filled
Cannot put the template in the desired outlet
Is this the correct way to create a theme component?
Canvas Theme Template
Getting error while uploading theme
[Zotero extension +] Firefox v116 on macOS broken Discourse?
Install Discourse for development using Docker
How to easily edit my site remotely?
Import site theme via console
How are theme setting fields created?
Customisability in discourse?
Discourse Theme CLI is the bomb
Discourse 2.0.0.beta5 Release Notes
How difficult would it be to make the Discourse UI more like Flarum?
Discourse-webpack: A boilerplate for developing JS-heavy Discourse components
Import Error: about.json does not exist, or is invalid
How to Add Unique HTML Content Below Topic Body in discourse forum for Specific Topics
Reuse Discourse Hamburger Functionality
Themes - Add a description field
Create and share a font theme component
How to create a theme (if I am a pure end user)
Linting configuration
Is it possible to use a local plugin directory with a docker install?
How to overrule a color variable for one theme only?
Can't customize text on custom button in template override using UI
Is it possible to use theme component from local folder (as plugin) - for local development?
Restrict editing of remote themes
When exporting a theme, I get a broken archive
Uploads via Admin >> Customize >> Themes disappear after a watched theme is saved.
How do we include image assets in the theme so they don’t get wiped out after a save is done?
Hi, welcome!
You need to include the assets in your theme component directly.
At the root, you create an assets directory.
Then, you declare them in about.json
"assets": {
  "<your_identifier>": "assets/<your_asset_filename>",
You can see an example here GitHub - MeghnaAJ/discourse-christmas-decorations · GitHub.
A quick heads-up for developers who are using this tool to generate theme components:
You are encouraged to upgrade it! :+1:
A recent PR made the discourse-theme-skeleton repo as the default template. It will give you the latest configuration files!
Thanks!
It would be great to add an Update section to the topic…
Is it a --reset or a rubygem update?
Good idea! I’ve added a ‘upgrading’ section to the OP
To install the gem on WSL, I had to run both
sudo apt-get install ruby and sudo apt-get install ruby-dev.
Maybe that can be added to the installation instructions.
If you do not install ruby-dev, do you get an error? It should not be necessary to install ruby-dev as ruby itself is sufficient.
I’m pretty sure that I got an error that told me to install ruby-dev, otherwise I wouldn’t have known the package existed.
But I cannot reproduce it by trying to reinstall. Maybe I did something weird the first time.
Hmm that is indeed odd. Feel free to let me know if you can reproduce the problem again.
I updated my server yesterday to 3.5.0.beta9-dev and I don’t get live reloads with the discourse theme gem since. Gem is version 2.1.6.
I don’t see any errors and stuff, so wanted to ask first if anyone else has the same issue?
Live reloads of stylesheets have been disabled for production instances, because they were causing problems when updating themes and/or Discourse core.
Fundamentally: stylesheet changes are often tied to changes in JS/HTML, so live-loading for only stylesheets is risky. Users end up running ‘new’ stylesheets against ‘old’ HTML, which can lead to some very strange experiences.
Live-loading is still enabled for development-mode Discourse instances. Ideally, you’d use that for development rather than a production site. Apart from the stylesheet reload, development-mode Ember gives you waaaay more friendly error messages than production-mode Ember.
That’s a big change. I’m surprised that there wasn’t an announcement. I’d been doing theme development mostly only on production sites.
A site setting to get the old behavior might be nice.
Agreed, this surprised me, and I couldn’t find this current thread despite searching, or maybe I saw the older OP date and ignored it.
A post was split to a new topic: How do I recover a previous theme
