ActivityPub Plugin
I think the ones added by plugins are still a little inflexible when it comes to customising the sidebar. I think this is still the advised way of doing it:
Thank you this worked for me
For some reason it still appears in the sidebar on mobile, any clue?
Best regards
Olle
Ah, this looks like it may have changed for mobile based on the new way ‘more’ is displayed.
I think this should do it for ‘Federation’:
.sidebar-more-section-content {
    li[data-list-item-name=activity-pub-about] {
        display: none !important;
Great thank you!:slight_smile:
I think you can also use
.sidebar-section-link-wrapper[data-list-item-name="activity-pub-about"] {
         display: none;
to hide the link on mobile and desktop
A post was split to a new topic: Actor not discoverable on other sites
Hello, I installed the plugin, which was very easy, even I did not know either Mastodon or the plugin. Everything works well except for one small detail that I’ll explain here.
When I personally publish a topic as an administrator in the categories that are subsequently published on Mastodon, there is no problem. However, today, one of my users who had never posted on my forum before published a post in one of the categories. Naturally, this post went into the approval queue. I approved it, and the post was published in the category. However, it was never picked up by ActivityPub and published on Mastodon as I believe it should have been.
I considered two potential issues: first, this user is not an administrator—could that be the problem? Second, perhaps the issue stems from the fact that this post first went through a moderation queue before being approved by me. Could this have prevented it from being published on Mastodon? What do you think?
I also have a related question: uncertain about what was happening, I published a test post myself as an administrator, and there was no problem. After five minutes, it was posted on Mastodon, but I was unable to delete it from Mastodon. I suppose this is because it didn’t go to my main account but to an account linked to one of the actors. It seems impossible for me to control these actor-linked accounts on Mastodon, but that is more of a Mastodon-specific question.
Thanks for your attention.
I reckon this comes from same ground that any topics, that aren’t kind of organic, written in that category and published in normal way, don’t be federated.
You can do it manually, though.
Same happens with WordPress plugin or if a topic is published with the timer. Or moved from non-federated category to federated one.
I think that is more lacking a feature than a bug per se. ActivityPub isn’t totally ready yet.
You can remove a message from your sight, or from local timeline, if you are an admin of that instance.
But you can’t ever delete a message that isn’t yours. You must be the OP in the original instance to delete — and even then it is pure luck if all others in the Fediverse will follow that deletion request.
So you have to delete it from your forum and I’m not sure if that deletion will be federated too from Discourse. But you should be able to un-federate in Discourse. Anyway… it isn’t that big question because after few minutes no one sees such posting because of high traffic from Fediverse :smirking_face:
Thanks for your answers, not a big deal overall, but I wanted to exclude a possible wrong manipulation on my side.
Hey @patrickemin, thanks for trying out the plugin and I’m glad it’s working for you, and that it makes sense. That’s nice to hear :slight_smile:
Yes, this is expected behaviour. We don’t auto-publish posts on approval. As @Jagster notes, you can use the activity pub topic actions to manually publish a topic and its posts after approval. We may add a setting to auto-publish posts after approval. Some folks may still want to do that manually as people use the approval queue for different reasons.
Yes, this is also expected. When a post is federated, the “actor” that controls it is the actor that federated it. You won’t be able to delete it using your mastodon account. You need to delete it on Discourse itself. We then tell mastodon to delete it there too.
@angus I have a strange fault in one of my federated categories (only in one, all other functions of the plugin are fine):
The category appears as “inactive”. The actor can be saved as “enabled” without any error. When I return to the overview of all actors/categories, it is again (or still?) disabled:
grafik
How can I debug this ?
Hey @Thomas_Rother, is the category a publicly available category where regular users can post?
No, its read only. The purpose is to have a publicly available documentation area which is read only for the public (and logged-in users), but writeable only for Mods and Admins. ActivityPub should “lure” possible readers from outside as there is only limited Discourse documentation in german language …
I see. That is likely the reason it’s showing as Not Active. You may want to make a feature request for that use case.
see Feature Req: ActivityPub notifications from read-only categiories
Hello! We installed the plugin and it was working fine, but for no apparent reason, posts started being published as links instead of articles. The settings are correct, but they’re still published as links. How can I fix this?
First, thanks for the great plugin and I cannot wait that this gets more features!
This really should have some kind of whole forum actor. There were some discussion about this on the first posts but it seems that this has not been done yet.
It is nice to have different category/tag actors so you could spesify what you follow. But it would be great that you could make a “forum” actor that shows all public topics.
For example I could follow @pelittaa@pelittaa.fi actor and get all public posts.
There was already a feature request for following individual users and that would be a great addition also since now when I try to follow user using Mastodon it apparently sends follow request that never gets answered.
Hey there, is there any roadmap or upcoming features list for this plugin? For example, in NodeBB you can follow users from the fediverse, and forum users can be followed from the fediverse (not only subforums). Is something like that in scope for Discourse? Thanks!
Thanks for the question @panosd. We don’t have any plans to add new features to the plugin right now. We plan to make maintenance improvements over the next year, but no new features.
Following users is a bit counter-intuitive in a forum environment. That’s my take, anyway. I find it very difficult to reconcile the social media “feed that shows posts from followed users” with a forum’s organization around topics. Forum posts usually happen within a context (a topic, a category), and it’s hard to “fit” them in a social media space.
This is possible in Discourse, to be clear. You can add Follows to any tag or category that has federation enabled, and any actor (i.e. user) in ActivityPub can be followed.
