Campo personalizzato non funzionante
@vinothkannans Again thanks for suggestion,
I have successfully added field.
I have one issue though the add_to_serializer is loaded before a HTTP request comes in, therefore if I set the value of the custom field with params[“value_to_field”] from the params Hash, it fails for obvious reason, the fact that it add_to_serializer does not have access to params, is there a way to circumvent this limitation.
Thanks
You can get params only in controllers.
You have to understand the differences between serializers and controllers. Also read other Rails essentials.
