tgxworld
(Alan Tan)
01.Январь.2019 22:18:56
22
We still need the proxy for until the old SiteSetting.favicon_url is removed. We’re currently deprecating it in the next release.
$ wget https://dungeon.gg/uploads/default/original/1X/ea21955a8a3d56191e5d88eb8df873de430f6cb5.png
--2019-01-02 06:15:32-- https://dungeon.gg/uploads/default/original/1X/ea21955a8a3d56191e5d88eb8df873de430f6cb5.png
Resolving dungeon.gg (dungeon.gg)... 35.199.105.252
Connecting to dungeon.gg (dungeon.gg)|35.199.105.252|:443... connected.
ERROR: cannot verify dungeon.gg's certificate, issued by ‘CN=COMODO RSA Domain Validation Secure Server CA,O=COMODO CA Limited,L=Salford,ST=Greater Manchester,C=GB’:
Unable to locally verify the issuer's authority.
Not sure if it is just me but I can’t seem curl or wget the upload. It works fine for me in the browser though.
If we only need it for a particular combination of a) weird browsers and b) weird configurations where the favicon URL is totally off-site then I say we pull it ASAP.
neemiasvf
(Neemias Freitas)
01.Январь.2019 23:48:59
24
Hey Alan!
Why does this happen? I’ve noticed that some browsers also accuse my website of not being secure because they cannot verify the certificate’s issuer. It’s a paid certificate and as you can see, it’s issued by COMODO, which is very well known.
tgxworld
(Alan Tan)
02.Январь.2019 00:20:29
25
@sam will have more context since he added the proxy but I don’t think we can remove it since we want to allow favicons to be served via the CDN.
# We need to be able to draw our favicon on a canvas
# and pull it off the canvas into a data uri
# This can work by ensuring people set all the right CORS
# settings in the CDN asset, BUT its annoying and error prone
# instead we cache the favicon in redis and serve it out real quick with
# a huge expiry, we also cache these assets in nginx so it bypassed if needed
For this particular problem, it is something odd about @neemiasvf ’s SSL setup:
$ openssl s_client -connect dungeon.gg:443
<truncated>
Verify return code: 21 (unable to verify the first certificate)
@neemiasvf How do you have your SSL configured? Are you on the docker based install?
neemiasvf
(Neemias Freitas)
02.Январь.2019 00:25:08
26
I followed this tutorial: Allow SSL / HTTPS for your Discourse Docker setup
Could you try this command again? It returned the following for me:
Summary
CONNECTED(00000005)
depth=0 OU = Domain Control Validated, OU = PositiveSSL, CN = dungeon.gg
verify error:num=20:unable to get local issuer certificate
verify return:1
verify error:num=21:unable to verify the first certificate
verify return:1
Certificate chain
0 s:/OU=Domain Control Validated/OU=PositiveSSL/CN=dungeon.gg
i:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Domain Validation Secure Server CA
Server certificate
-----BEGIN CERTIFICATE-----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=
-----END CERTIFICATE-----
subject=/OU=Domain Control Validated/OU=PositiveSSL/CN=dungeon.gg
issuer=/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO RSA Domain Validation Secure Server CA
No client certificate CA names sent
Server Temp Key: ECDH, P-384, 384 bits
SSL handshake has read 2666 bytes and written 358 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES128-GCM-SHA256
Server public key is 4096 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES128-GCM-SHA256
Session-ID: 6038753C9F271BE81C5D22DFF4935E5AFECCE16C9FB6EECAEF5B6EE0D37F8908
Session-ID-ctx:
Master-Key: 93CE5931402313B65E0CD9C74A34CD52AF1B152DC03F364B6A8009D434C1A958FDFC6BB0D297608E47B3A3722AD21E4E
Start Time: 1546388599
Timeout : 7200 (sec)
closed
tgxworld
(Alan Tan)
02.Январь.2019 00:27:14
27
You’re getting the same output as I am
Can you try using the Let’s Encrypt setup instead?
neemiasvf
(Neemias Freitas)
02.Январь.2019 00:31:05
28
Yeah, sure! That’s just gonna take me some time. But I honestly thought it would be better to pay for one.
neemiasvf
(Neemias Freitas)
02.Январь.2019 01:18:02
29
Done! Getting these returns now:
CONNECTED(00000005)
depth=2 O = Digital Signature Trust Co., CN = DST Root CA X3
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
verify return:1
depth=0 CN = dungeon.gg
verify return:1
Certificate chain
0 s:/CN=dungeon.gg
i:/C=US/O=Let's Encrypt/CN=Let's Encrypt Authority X3
1 s:/C=US/O=Let's Encrypt/CN=Let's Encrypt Authority X3
i:/O=Digital Signature Trust Co./CN=DST Root CA X3
Server certificate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subject=/CN=dungeon.gg
issuer=/C=US/O=Let's Encrypt/CN=Let's Encrypt Authority X3
SSL handshake has read 3587 bytes and written 358 bytes
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Session-ID: 1E8EF7041BFF50428535FEB1AC1C02AB3B4440C8AFA1ABEB33F82727040DCAC2
Session-ID-ctx:
Master-Key: E857604B095B3379B4D5A16FDE838910893F71E0B37A1C94D65FCA699B873330F199F145A8E269E1218EB913E8947B25
Start Time: 1546391748
Verify return code: 0 (ok)
closed
--2019-01-01 23:17:39-- https://dungeon.gg/uploads/default/original/1X/ea21955a8a3d56191e5d88eb8df873de430f6cb5.png
HTTP request sent, awaiting response... 200 OK
Length: 1730 (1.7K) [image/png]
Saving to: ‘ea21955a8a3d56191e5d88eb8df873de430f6cb5.png’
ea21955a8a3d56191e5d88eb8df873de43 100%[================================================================>] 1.69K --.-KB/s in 0s
2019-01-01 23:17:39 (71.7 MB/s) - ‘ea21955a8a3d56191e5d88eb8df873de430f6cb5.png’ saved [1730/1730]
sam
(Sam Saffron)
02.Январь.2019 01:20:28
30
favicon proxy is actually an opposite problem, see:
It exists due to this feature:
The Show new / updated topic count on browser icon user setting (which is default off) that @chrishunt built back in the day uses canvas to render. The trouble is that canvas has some insane rules here… which I really do not understand.
HTML provides a crossorigin attribute for images that, in combination with an appropriate CORS header, allows images defined by the element that are loaded from foreign origins to be used in a as if they had been loaded from the current origin.
Basically if you want to render a foreign image in canvas you need to sacrifice a 3 chickens. Because … reasons.
To avoid this we proxy the image locally.
So back on topic... the simplest thing to do here going forward is:
Strip this proxy route and logic
IF using new favicon scheme simply have the client use “on-site” upload url
IF using old scheme then break the feature (favicon notifications) till admins re-upload favicon. (or … maybe you migrate in a onceoff)
neemiasvf
(Neemias Freitas)
02.Январь.2019 01:29:36
31
Guess what?
When you disable Show new / updated topic count on browser icon in user preferences, the favicon loads with no problem.
@codinghorror , if you login back again at https://dungeon.gg and disable that option, you can see that it works fine.
It is indeed because of that feature, as @sam pointed out.
For now, I’ll be updating all of my users preferences so that they don’t have that problem. Meanwhile, you guys work on a solution for this.
Again, I’d like to offer help in solving this issue, IF you need it. I’m just now graduating in Computer Science and I really like Discourse and am very enthusiastic about it, so…
As for the certificate @tgxworld , here are the results, which are now waaaay better: SSL Server Test: dungeon.gg (Powered by Qualys SSL Labs)
tgxworld
(Alan Tan)
02.Январь.2019 01:54:11
32
There wasn’t anything broken from what I can tell. Your site had SSL incorrectly configured somehow that was preventing us from downloading the image properly as part of the following logic:
file = FileHelper.download(
UrlHelper.absolute(SiteSetting.site_favicon_url),
max_file_size: 50.kilobytes,
tmp_file_name: FAVICON,
follow_redirect: true
I actually tried to download it manually which is how I noticed that SSL might not have been configured correctly.
neemiasvf
(Neemias Freitas)
02.Январь.2019 01:55:27
33
I just now updated all of my user’s preferences by doing:
UserOption.all do |uo|
uo.set_defaults
uo.save
end
That should solve the problem temporarily.
neemiasvf
(Neemias Freitas)
02.Январь.2019 01:57:06
34
Yeah, but even after I changed the configuration to Let’s Encrypt, the problem persisted. The actual solution was changing the setting for Show new / updated topic count on browser icon to false.
sam
(Sam Saffron)
02.Январь.2019 02:00:24
35
I am afraid this is impossible. You somehow have a setup where your server is unable to make HTTPS requests to itself.
Run:
./launcher enter app
rails c
FileHelper.download('https://dungeon.gg/uploads/default/original/1X/ea21955a8a3d56191e5d88eb8df873de430f6cb5.png')
You will notice that does not work cause somehow something is not configured right.
My first recommendation would to do ./launcher rebuild app, next up I would recommend looking at your Docker DNS settings, maybe somehow DNS is not resolving from when you are inside the container.
neemiasvf
(Neemias Freitas)
02.Январь.2019 02:05:36
36
Right.
By running this:
I got:
ArgumentError: missing keywords: max_file_size, tmp_file_name
from /var/www/discourse/lib/file_helper.rb:22:in `download'
So I went ahead and ran:
FileHelper.download('https://dungeon.gg/uploads/default/original/1X/ea21955a8a3d56191e5d88eb8df873de430f6cb5.png', max_file_size: 99999, tmp_file_name: 'test')
And I got:
=> #<File:/tmp/test20190102-5149-67ou.png>
sam
(Sam Saffron)
02.Январь.2019 02:05:55
37
And since our source is going to be on S3 if S3 uploads are enabled, there is nothing we can do.
tgxworld
(Alan Tan)
02.Январь.2019 02:06:18
38
That is because the favicon is cached for 30 minutes.
neemiasvf
(Neemias Freitas)
02.Январь.2019 02:07:38
39
I see. Anyways, it’s already solved due to changing user’s preferences.
tgxworld
(Alan Tan)
02.Январь.2019 02:10:05
40
The problem has already been solved by switching to Let’s Encrypt for your SSL needs. You just have to wait 30 mins till the cache is cleared.
neemiasvf
(Neemias Freitas)
02.Январь.2019 02:12:38
41
Alright. I’ll wait a bit more and change the setting back again. If it works, I’ll give you a haha
