Header search plugin
Thanks, fixed.
https://github.com/angusmcleod/discourse-header-search/commit/4e7f6e39a59694b2ba213e0c0161bbe15953e3b8
Live on my sandbox.
Great! It looks like you disabled it for mobile in your sandbox?
The plugin doesn’t support mobile yet :slight_smile: It should only affect search on desktop.
there is small padding issue, trying to solve anyhelp ?
Untitled
It looks like you’re pointing to the border around the input. That’s standard Discourse css.
Add this to your custom css to override it for this specific input:
.search-header #search-term {
   border: 1px solid #your_color
A little fix even for the Pavilion Header Search Theme Component , please master :wink:.
Theme fixed :slight_smile:
https://github.com/angusmcleod/discourse-header-search-theme/commit/4a44f5fd578cab57aad3db7abf7207daa30a976a
cc @supernaturally
if the word(ing) for “extended” is longer in the localization (here: de:“Erweiterte Suche”), the layout is messed up by overtypging.
(And the bar would have enough space to expand a little)
mm ok. I’ve put that link outside the search input. Let’s see how that goes.
https://github.com/angusmcleod/discourse-header-search/commit/ea436962efb3994e28619868f29c9c698215db20
The old search icon shows up, and when clicked disappears while still opening the search bar:
It appears when I enter the home pages, or leave or enter a topic.
Thanks, fixed.
https://github.com/angusmcleod/discourse-header-search/commit/4be3c0743027904cd23739a7778156308a7a66d6
@angus I am still getting this bug
Can describe, or give an example for, the specific issue you’re seeing?
As described by @nawthor , the issue seems to be fixed.
See e.g. https://discourse.angusmcleod.com.au
@angus
This plugin appears to be causing issues with rendering in IE 11.
On IE 11 my site stopped loading and displayed a white display only. I then went through and unistalled/installed each plugin until I got to this one.
This plugin seems to stop Discourse from loading in IE 11. I am running IE 11.0.9600.18837
Additionally I was able to replicate this on: https://discourse.angusmcleod.com.au/
Edit: This only shows in IE, can’t replicate in Firefox or Chrome.
Thanks, fixed. :sun_with_face:
https://github.com/angusmcleod/discourse-header-search/commit/17e7cdea4670f403ece72fc701980ad33dd32170
@angus
You are a champ :slight_smile:
I think the text should be highlighted title to see more easily.
are the “known issues” listed in the original post still an issue?
Nope, they’re resolved. But I can’t edit the first post anymore. @hawk can you wikify?
I’m out for a couple of weeks. Ping @jomaxro
