Comment trouver n'importe quelle image manquante ?
I also have a lot of missing images:
root@xxxxx-app:/var/www/discourse# rake posts:missing_uploads
37 post uploads are missing.
34 uploads are missing.
5 of 34 are old scheme uploads.
33 of 1013268 posts are affected.
but after
root@xxxxx-app:/var/www/discourse# rake uploads:missing
/var/www/discourse/public/uploads/default/original/2X/3/3a9bf205dec2b6bd0b3cc35a3be1f69499960713.JPG
/var/www/discourse/public/uploads/default/original/3X/2/d/2db0ff326859b94824b64c4e0c2b156c562b7a99.jpg
/var/www/discourse/public/uploads/default/original/3X/e/f/ef271ac232c31e747206b47e4de7e0570de9e030.jpg
**10604** of 101083 uploads are missing
/var/www/discourse/public/uploads/default/optimized/2X/3/3d3efaa44fb43b99ec290b75e289080fc448f709_1_657x500.gif
/var/www/discourse/public/uploads/default/optimized/2X/4/4e3b01361d7c30c3df27a9606271175d91edff6d_1_200x200.jpeg
/var/www/discourse/public/uploads/default/optimized/2X/6/68fcd443312e7c500d25a6067c04c98aa1066686_1_200x200.JPG
/var/www/discourse/public/uploads/default/optimized/2X/1/16452ee2749e93e6b47d1388a20e34c1e3832ee1_1_100x100.jpg
/var/www/discourse/public/uploads/default/optimized/2X/0/0e843544885c0ee7a0c350d66bbe852dd4f0a497_1_135x135.jpeg
/var/www/discourse/public/uploads/default/optimized/2X/f/fb3d38e8d1b0e8ae25606156d37b8045f7cbc2b3_1_200x200.jpg
/var/www/discourse/public/uploads/default/optimized/2X/5/54a076f5be7cfabcf0fa34e57b836d85a33a879e_1_200x200.jpg
7 of 247116 optimized_images are missing
I’m having this problem as well on a forum running v2.3.0.beta9. I haven’t restored from backups. It’d be good to know why it’s happening and what we can do to restore the missing uploads. The good news is that the missing uploads seem to be in the tombstone, so hope isn’t lost..
So far, I’ve rebuilt the app and run rake uploads:missing, but that hasn’t helped.
root@forum-app:/var/www/discourse# rake posts:missing_uploads
Looking for missing uploads on: default
146 post uploads are missing.
142 uploads are missing.
81 of 58082 posts are affected.
root@forum-app:/var/www/discourse# rake uploads:missing
The missing uploads are from twoish weeks ago.
Problem solved! rake uploads:recover_from_tombstone did the trick. It’d still be good to understand why this happened…
@vinothkannans, @zogstrip Any updates on this?
Just checking in again. Does anyone know the answers to the following questions from a month ago?
  1. What’s the difference between a missing upload and a missing post upload? (Last I checked, my site appeared to have 196 more of the latter.)
  2. Why does Discourse report images that haven’t been migrated to the new upload scheme as “missing”?
  3. If this is expected behavior, how can I migrate the 200+ images like this on my site to the new upload scheme?
@vinothkannans can advise
  • missing upload - The upload record is found in DB but the file is missing in the file storage.
  • missing post upload - The upload record is not found in DB for an upload URL in the post.
I think those old scheme uploads are not found in the database and/or filesystem too.
You can do it by enabling the setting using the below command. It will migrate those upload if they’re found in DB and filesystem.
SiteSetting.migrate_to_new_scheme = true
Forgive me.. where do we load these?
You need to enter that into the rails console as it’s a hidden site setting.
so:
root@site:~# cd /var/discourse/
root@site:/var/discourse# ./launcher enter app
root@site-app:/var/www/discourse# rails c
[1] pry(main)> SiteSetting.migrate_to_new_scheme = true
then exit, and rebuild?
EDIT:
any other steps.. do we need to undo this after?
Looks good. No need to rebuild or undo.
Thanks, @vinothkannans. :bowing_man:t2:
How will I know that this command has been successful? Should I try running rake posts:missing_uploads again after enabling this hidden site setting in the Rails console? Or maybe PostCustomField.where(name: Post::MISSING_UPLOADS)?
Des nouvelles à ce sujet ?
Elle s’exécutera et effectuera la migration dans un tâche d’arrière-plan. Une fois terminée, la valeur du paramètre du site SiteSetting.migrate_to_new_scheme reviendra à false. Ensuite, exécutez à nouveau la tâche rake posts:missing_uploads.
D’accord, j’ai simplement suivi vos conseils et le résultat semble prometteur. Tout d’abord, je suis entré dans le conteneur Discourse :
$ cd /var/discourse
$ sudo ./launcher enter app
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
Unable to find image 'discourse/base:2.0.20190625-0946' locally
2.0.20190625-0946: Pulling from discourse/base
Digest: sha256:9899c60721649460283ac800836ac1ebecbc3ed8a97a496e514cf8c97f5b6d82
Status: Downloaded newer image for discourse/base:2.0.20190625-0946
Ensuite, j’ai exécuté rake posts:missing_uploads :
Fixing missing uploads:
12 post uploads are missing.
12 uploads are missing.
1 of 12 are old scheme uploads.
3 of 8930 posts are affected.
(Seulement 12 pièces jointes manquantes cette fois ! Super !)
Enfin, j’ai défini SiteSetting.migrate_to_new_scheme à true et quitté la console Rails :
# rails c
=> false
[2] pry(main)> SiteSetting.migrate_to_new_scheme = true
=> true
[3] pry(main)> exit
Après un certain temps, j’ai confirmé que la valeur de SiteSetting.migrate_to_new_scheme était bien passée à false et j’ai relancé rake posts:missing_uploads :
=> false
[2] pry(main)> exit
3 of 8939 posts are affected.
Le résultat est à peu près le même, donc je pense que cela signifie que tous les messages utilisant l’ancien schéma de téléversement ont été migrés vers le nouveau. Cependant, le répertoire uploads contient encore beaucoup de sous-dossiers numérotés :
$ cd /var/discourse/shared/standalone/uploads/default/
$ ls
1    112  125  138  151  164  177  190  203  216  229  242  255  268  281  294  46  59  72  85  98
100  113  126  139  152  165  178  191  204  217  230  243  256  269  282  34   47  60  73  86  99
101  114  127  140  153  166  179  192  205  218  231  244  257  270  283  35   48  61  74  87  optimized
102  115  128  141  154  167  180  193  206  219  232  245  258  271  284  36   49  62  75  88  _optimized
103  116  129  142  155  168  181  194  207  220  233  246  259  272  285  37   50  63  76  89  original
104  117  130  143  156  169  182  195  208  221  234  247  260  273  286  38   51  64  77  90
105  118  131  144  157  170  183  196  209  222  235  248  261  274  287  39   52  65  78  91
106  119  132  145  158  171  184  197  210  223  236  249  262  275  288  40   53  66  79  92
107  120  133  146  159  172  185  198  211  224  237  250  263  276  289  41   54  67  80  93
108  121  134  147  160  173  186  199  212  225  238  251  264  277  290  42   55  68  81  94
109  122  135  148  161  174  187  200  213  226  239  252  265  278  291  43   56  69  82  95
110  123  136  149  162  175  188  201  214  227  240  253  266  279  292  44   57  70  83  96
111  124  137  150  163  176  189  202  215  228  241  254  267  280  293  45   58  71  84  97
Quelle serait la méthode la plus simple pour identifier quels messages (le cas échéant) font référence aux images de ces sous-dossiers ? Une simple requête dans la console Rails conviendrait.
Merci !
Il pourrait aussi contenir de nombreux répertoires vides. Je pense que vous devriez tous les ignorer.
La requête ci-dessous peut vous aider.
Post.where("cooked LIKE '%/uploads/default/%' AND cooked NOT LIKE '%/uploads/default/original/%' AND cooked NOT LIKE '%/uploads/default/optimized/%'")
Cette sortie est infiniment longue, et je ne vois pas de moyen simple de la rediriger vers un fichier pour traitement. (Le mieux que je puisse faire est d’appuyer sur la barre d’espace pour avancer d’une page à la fois… et je n’ai pas encore vu la fin).
Comment pourrions-nous obtenir cette sortie dans un fichier, ou peut-être faire en sorte qu’elle ignore le corps du message et les pièces jointes ?
ok, nous avons trouvé une solution qui évite d’afficher les trois colonnes les plus problématiques :
"raw", "cooked", "raw_email"
posts = Post.where("cooked LIKE '%/uploads/default/%' AND cooked NOT LIKE '%/uploads/default/original/%' AND cooked NOT LIKE '%/uploads/default/optimized/%'"); 42
CSV.open("/tmp/posts-to-review.csv", "wb") do |csv|
  csv << Post.attribute_names - ["raw", "cooked", "raw_email"]
  posts.each do |post|
    csv << post.attributes.except("raw", "cooked", "raw_email").values
  end
end
  • Évitez d’afficher la sortie en tapant q,
  • Quittez Ruby avec exit,
  • Effacez l’écran, puis utilisez cat /tmp/posts-to-review.csv.
J’aurais pu rediriger cela vers le dossier partagé… mais cette solution fonctionne.
(modifié pour ajouter des étapes plus claires)
Hmm… Je viens de vérifier (en utilisant find . -maxdepth 1 -type d -empty | wc -l) et j’ai trouvé seulement 19 répertoires numérotés vides sur 262 au total (en utilisant find . -maxdepth 1 -type d -iname '[0-9]*' | wc -l), soit environ 7 %. Donc, je ne pense pas que je doive les ignorer entièrement ?
Super, merci ! :+1:
J’ai remarqué que cela utilise l’attribut « cooked » — cela signifie probablement que la source Markdown peut continuer à utiliser l’ancien schéma de téléchargement ? Par exemple, j’ai trouvé un message contenant cette balise image dans la source :
<img src="/uploads/default/293/8d45810f8911c08c.jpg" width="666" height="500">
Cependant, si vous passez la souris sur l’image rendue, elle pointe vers l’URL suivante :
/uploads/default/original/2X/0/0d1e04b9215f210faf1d8509e6bede9c3319e02b.jpeg
Devrions-nous nous inquiéter du fait que les URL des images dans la source Markdown ne correspondent pas aux URL des images dans le HTML rendu (y compris les hachages de fichiers) ? Par exemple, puis-je supprimer en toute sécurité le répertoire /var/discourse/shared/standalone/uploads/default/293 sans risquer de rompre le lien vers l’image ci-dessus ? Ou, pour le dire autrement, Discourse saura-t-il toujours que /uploads/default/293/8d45810f8911c08c.jpg est un alias de /uploads/default/original/2X/0/0d1e04b9215f210faf1d8509e6bede9c3319e02b.jpeg, et cette correspondance sera-t-elle préservée lors de la restauration du site à partir d’une sauvegarde ?
Oui. L’URL ne devrait pas différer entre le brut et le traité. Pouvez-vous coller ici le contenu complet des colonnes brut et traité du message ?
