Comment corriger les erreurs de traduction
If you check the “only show overidden” checkbox, does the invite_forum_mailer.text_body_template key show up?
You are looking at the wrong template… the one with the problem is not the invite_mailer.text_body_template but the invite_forum_mailer.text_body_template
The result is exactly the same…
Still it has been fixed..
Can you take a screenshot of the entire window after you tick the “only show overidden” checkbox"?
Voici…
That isn’t the default translation, you have a custom translation that happens to be the old translation. You’ll need to revert the changes.
2 « J'aime »
I just selected the Greek language from inside discourse… i didn’t installed any custom translation…
How do i get the new translation?
If you click into that translation, do you see a “revert changes” button?
1 « J'aime »
Yes!!! That did the trick!!! Thanks mate… i tried to change it to fix it and it kept that change!!!
I’m not sure if i changed anything else… how can i revert all translation changes?
This topic was automatically closed after 29 hours. New replies are no longer allowed.
