Yep, it’s fixed ![]()
Really great to see the improvements made here, everyone.
Really awesome!
You’re close! Click Edit CSS/HTML, editing the mobile styling is one of the tabs in there.
Jeff Thanks for updating did you find it Dylan?
Is it possible to use that plugin with other images except flags?
Solution: It is possible to edit flaglist.js.es6 file
"name": "fo",
"value": "fo.png"
How you can add string variables? What is the user-inputted location?
Solution: I forked plugin repo and customize for my purpose. It seems work.
With that fix, the flag is displayed to the left of the user’s name. How do I move it to the right of the name?
I was added “url” to that component in flaglist.js.es6 file:
"name": "name",
"value": "name.png",
"url": "name-link"
How can I print the URL value in show-user-card.hbs?
{{model.custom_fields.nationalflag_iso.url}}
Nice plugin indeed!
I have problem, when i go to user options, and select flag…click SAVE, when i refresh it wont save it it goes back to default.
Any clue why? ![]()
p.s. i did full system and discourse backup this morning, could that be the problem?
Thanks
This was caused by a recent change in Discourse. It will require a small change to the plugin to fix the problem.
@Ebs I have made a pull request on your repository with the change: FIX: Update for changes to Discourse core by davidtaylorhq · Pull Request #3 · Ebsy/discourse-nationalflags · GitHub
Thank you i was confused
@david
Merged. Thanks a lot!
Small issue regarding style/alignment with the mobile view of discourse. The national flag seems to be stretched vertically and is aligned above the username. Would it be possible to move the alignment of the icon to the right of the username/title (to coincide with the respective placement on the desktop view) and fix the distortion?
Desktop:
Mobile:
Please note that the only thing that was done was clicking on the view toggle link in the hamburger menu.
I second this. Please help, looks ugly on mobile..
Thought it was about time I fixed it ![]()
Just updated the plugin. flag is now after the username on mobile (and not stretched anymore) ![]()
Привет, Нил @Ebs,
Как мы и обсуждали, я отправил PR с добавлением нескольких улучшений для вашего замечательного плагина!
Предварительный просмотр:
Описания на естественном языке и поиск
Замена кодов — они по-прежнему используются кодом, btw, но скрыты:
Поддержка плагина Custom Wizard
Если вы используете оба плагина, вы сможете добавить шаг обновления флага в свой Мастер, например, для новых или существующих пользователей, чтобы они завершили настройку своего профиля.
Несколько моментов, которые стоит учесть
Есть несколько описаний для нестандартных кодов, которые нужно исправить в файле .yml. Я оставил это вам, так как вы знаете, что означает каждый из них :).
Теперь уже создана структура для добавления локализационных текстов на дополнительные языки, помимо английского.
Дайте знать, если у вас есть комментарии.
Сообщите, когда вы объедините изменения, так как вскоре после этого мне нужно будет выпустить новое обновление для Custom Wizard.
К сведению: я внес небольшие изменения для улучшения кода (спасибо за предложения @angus)
Спасибо за слияние, @Ebs.
@Vikas_Dangi, теперь выпадающий список использует описания.
