Right Sidebar Blocks
But it only works on homepage when empty.
sorry i thought you meant topic list page. I don’t think you can do it for every topic page. I think it would make your topics hard to read too.
Do you know the route for every topic page?
no and i don’t think it will work with this component.
Yeah, @Lilly is correct. Right Sidebar Blocks isn’t compatible with the “viewing a topic” page. It generally only works on topic list pages.
I will try this! Thanks
This plugin broken my theme.
Discourse Bars, Right Sidebar Blocks, FKB Pro and Fakebook may have some issues with each other, since they all add some form of a right/new sidebar(s).
Waiting for the next version
Is this theme component used for this right sidebar in the Discourse theme? Or is that something exclusive for the Meta brand?
i may be wrong, but i’m guessing that is built with the new blocks api.
Would it be possible to increase the # from 5 to 10 for “Top Contributors” ? Thanks.
I can check later, but isn’t that what the count parameter does?
That works thank you!
A post was split to a new topic: Tags block is conflicting with other tag dropdowns
