Seeking advice for homepage
Is this close to what you had in mind?
That’s just the concept I’m after - but I’d probably have Original Author on the left column, and Last Post on the right still
Just to update - I’ve managed to figure it out.
Thanks again to Charles Walter for coming up with this neat layout !
To make the changes, I edited the “Desktop” > Header and CSS sections
1. Added this into appropriate position in Header
<!-- Author Avatar script -->
<td class="first-post">
  <div>
    <a href="/users/{{topic.creator.username}}" data-auto-route="true" data-user-card="{{topic.creator.username}}">{{avatar topic.creator imageSize="large"}}</a>
  </div>
</td>
2. Added this into appropriate position in Header
{{raw "topic-list-header-column" order='authorcenter' forceName='Author'}}
3a. Changed this part of the Header
<!-- Author Avatar script needs to remove bulk select button -->
{{raw "topic-list-header-column" order='default' name='topic.title' bulkSelectEnabled=bulkSelectEnabled showBulkToggle=toggleInTitle canBulkSelect=canBulkSelect}}
3b. Into this
{{raw "topic-list-header-column" order='default' name='topic.title'}}
4. Added this into the CSS section
// Author Avatar script
.topic-list td.first-post {
    width: 65px;
    text-align:center;
    padding-bottom:14px;
    padding-top:14px;
    .relative-date {
        color: #666;
.topic-list th.authorcenter {
    text-align:center;
In context:
Full header code
<script type='text/x-handlebars' data-template-name='list/topic-list-item.raw'>
  <div>
  </div>
</td>
<td class='main-link clearfix'>
  {{raw "topic-status" topic=topic}}
  {{topic-link topic}}
  {{#if controller.showTopicPostBadges}}
    {{raw "topic-post-badges" unread=topic.unread newPosts=topic.displayNewPosts unseen=topic.unseen url=topic.lastUnreadUrl}}
  {{/if}}
  {{discourse-tags topic mode="list"}}
  {{raw "list/topic-excerpt" topic=model}}
  <div class='creator'>
  {{#if showCategory}}
     {{category-link topic.category}}
   {{/if}}
  {{~#if topic.creator ~}}
  <a href="/users/{{topic.creator.username}}" data-auto-route="true" data-user-card="{{topic.creator.username}}">{{topic.creator.username}}</a> <a href={{topic.url}}>{{format-date topic.createdAt format="tiny"}}</a>
  {{~/if ~}}
   {{raw "list/action-list" topic=topic postNumbers=topic.liked_post_numbers className="likes" icon="heart"}}
   </div>
</td>
{{#if controller.showLikes}}
<td class="num likes">
  {{number topic.like_count}} <i class='fa fa-heart'></i>
</td>
{{/if}}
{{#if controller.showOpLikes}}
  {{number topic.op_like_count}} <i class='fa fa-heart'></i>
</td>
{{/if}}
{{raw "list/posts-count-column" topic=topic}}
<td class="last-post">
<div class='poster-avatar'>
<a href="{{topic.lastPostUr}}" data-user-card="{{topic.last_poster_username}}">{{avatar topic.lastPoster usernamePath="username" imageSize="medium"}}</a>
</div>
<div class='poster-info'>
<a href="{{topic.lastPostUrl}}">
{{format-date topic.bumpedAt format="tiny"}}
</a>
<span class='editor'><a href="/users/{{topic.last_poster_username}}" data-auto-route="true" data-user-card="{{topic.last_poster_username}}">{{topic.last_poster_username}}</a></span>
</div>
</td>
</script>
<script type='text/x-handlebars' data-template-name='topic-list-header.raw'>
  {{#if showLikes}}
     {{raw "topic-list-header-column" sortable='true' order='likes' number='true' forceName='Likes'}}
  {{/if}}
  {{#if showOpLikes}}
     {{raw "topic-list-header-column" sortable='true' order='op_likes' number='true' forceName='Likes'}}
  {{/if}}
  {{raw "topic-list-header-column" sortable='true' number='true' order='posts' forceName='Replies'}}
  {{raw "topic-list-header-column" sortable='true' order='activity' forceName='Last Post'}}
</script>
<script>
(function(){
var TopicListItemView = require('discourse/components/topic-list-item').default;
TopicListItemView.reopen({
    showCategory: function(){
        return !this.get('controller.hideCategory') &&
                this.get('topic.creator') &&
                this.get('topic.category.name') !== 'uncategorized';
    }.property()
</script>
Full CSS code
//add space between categories
.topic-list.categories {
  border-spacing: 0 1em;
  border-collapse: separate;
//change category background color to white
.topic-list.categories>tbody>tr {
  background-color: lighten($secondary, 10%);
//padding for category title and description
.topic-list.categories th,
.topic-list.categories td {
  padding: 0 15px 0 15px;
//Shadows for categories
.topic-list.categories>tbody>tr td.category,
.topic-list.categories>tbody>tr td.stats,
.topic-list.categories>tbody>tr td.latest {
  -webkit-box-shadow: 0 2px 5px 0 rgba(0, 0, 0, 0.16), 0 0 0 0 rgba(0, 0, 0, 0.12);
  -moz-box-shadow: 0 2px 5px 0 rgba(0, 0, 0, 0.16), 0 0 0 0 rgba(0, 0, 0, 0.12);
//add shadow behind the list of topics on right in Category and Latest View
//add shadow behind list of categories on left in Category and Latest View
//add shadow behind topics in Latest view
.category-list,
.topic-list:not(.categories),
.latest-topic-list {
  -webkit-box-shadow: 0 2px 5px 0 rgba(0, 0, 0, 0.16), 0 2px 10px 0 rgba(0, 0, 0, 0.12);
  -moz-box-shadow: 0 2px 5px 0 rgba(0, 0, 0, 0.16), 0 2px 10px 0 rgba(0, 0, 0, 0.12);
  border-collapse: collapse;
//underline navigation links
.nav-pills>li.active>a,
.nav-pills>li>a.active {
  color: $primary;
  font-weight: 500;
  background-color: $secondary;
  border-bottom: 3px solid $tertiary;
//remove highlighting navigation background on hover
.nav-pills>li>a:hover {
//fix color of user profile navigation icons
.user-main .nav-pills {
  a.active i {
    color: $primary;
  a:hover:not(.active) i {
    color: $quaternary;
//create conversation cards
.topic-body {
  margin-top: 10px;
  padding-left: 20px;
  border-radius: 2px;
  padding-right: 20px;
//more space for avatars
.topic-avatar {
  border-top: 0;
  padding-right: 10px;
  .avatar-flair {
    right: 4px;
//remove stray border from bottom of last post
.topic-status-info {
  border-top: 0;
//improve format of embedded posts
.embedded-posts .topic-avatar {
  padding-left: 0px;
.embedded-posts.top.topic-body {
  -webkit-box-shadow: 0 2px 5px 0 rgba(0, 0, 0, 0), 0 2px 10px 0 rgba(0, 0, 0, 0);
  -moz-box-shadow: 0 2px 5px 0 rgba(0, 0, 0, 0), 0 2px 10px 0 rgba(0, 0, 0, 0);
//raise and round buttons
.btn:not(.bulk-select) {
  border-radius: 2px;
//flatten editor, topic-map, more badges, and revision view buttons
.d-editor-button-bar .btn,
.topic-map .btn.no-text,
.badge-section .btn,
#revision .btn {
  border-radius: 0px;
//properly space buttons on login modal
button#login-link,
button#new-account-link {
  padding-left: 20px;
//darken color, remove shadow and border when pressed
.btn:active {
  background-color: rgba(0, 0, 0, .4);
  -webkit-box-shadow: 0 0px 0px 0 rgba(0, 0, 0, 0.16), 0 0px 00px 0 rgba(0, 0, 0, 0.12);
  -moz-box-shadow: 0 0px 0px 0 rgba(0, 0, 0, 0.16), 0 0px 00px 0 rgba(0, 0, 0, 0.12);
.btn:focus {
  outline: -webkit-focus-ring-color auto 0px;
//shift "more" button slightly left
.more-topics .btn {
  margin-right: 10px;
//New Topic Fab
#create-topic.btn-default {
  border-radius: 40px;
  position: fixed;
  bottom: 30px;
  right: 50px;
  z-index: 999;
  padding: 24px 20px 22px 5px;
  background-color: $tertiary;
  color: $tertiary;
  white-space: nowrap;
  text-indent: 10px;
  -webkit-box-shadow: 0 0 4px rgba(0, 0, 0, 0.14), 0 4px 8px rgba(0, 0, 0, 0.28);
  -moz-box-shadow: 0 0 4px rgba(0, 0, 0, 0.14), 0 4px 8px rgba(0, 0, 0, 0.28);
  overflow: hidden;
  width: 63px;
  height: 63px;
  -webkit-transition: right .5s, bottom .5s, border-radius .5s, text-indent .2s, visibility 1s, width .2s ease, height .5s ease .4s, color .5s, background-color 2s, -webkit-transform .5s;
  transition: right .5s, bottom .5s, border-radius .5s, text-indent .2s, visibility 1s, width .2s ease, height .5s ease .4s, color .5s, background-color 2s, transform .5s;
#create-topic.btn-default .fa-plus {
  color: white;
#create-topic.btn-default:hover {
  text-indent: 8px;
  width: 190px;
  color: white;
//Reply Fab
.timeline-footer-controls {
  position: relative;
.widget-button.btn.create {
  position: absolute;
  top: 50px;
  left: -18px;
  z-index: 999;
  color: white;
  text-indent: 10px;
  overflow: hidden;
  width: 63px;
  height: 63px;
//Center and increase size of reply icon
.widget-button.btn.create .fa-reply {
  color: white;
  font-size: 20px;
  margin-left: -8px;
//Proper spacing for iPad portrait
@media only screen and (min-width: 768px) and (max-width: 1250px) {
  .timeline-container {
    margin-left: 820px;
  .topic-admin-popup-menu {
    left: -40% !important;
//Properly space notifications button
.widget-button.btn.notifications-dropdown {
  right: 4px;
  position: relative;
  width: 30px;
  padding: 6px;
//cards for search results
.fps-result {
  margin-top: 10px;
  padding: 20px;
  border-radius: 2px;
@keyframes background-fade-highlight {
  0% {
    background-color: lighten($tertiary, 20%);
  100% {
#topic-status-info {
  border-top: none;
// RTL Overrides
.rtl {
  .widget-button.btn.notifications-dropdown .fa {
    margin-left: -2px;
  .topic-avatar {
    padding-right: initial;
    padding-left: 10px;
    .avatar-flair {
      right: initial;
      left: 4px;
    padding-left: initial;
    padding-right: 0;
  button#login-link,
    padding-left: 20px;
    right: initial;
    left: 50px;
    padding: 24px 5px 22px 20px;
    left: initial;
    right: -18px;
    margin-left: initial;
    margin-right: -8px;
    right: initial;
    left: 4px;
    margin-right: -2px;
// RTL Overrides
  .rtl {
      margin-right: 820px;
      left: initial !important;
      right: -40% !important;
//Mods from Sam's theme
.topic-list > tbody > tr:nth-child(odd) {
    background-color: white;
.topic-list > tbody tr:not(.last-visit):not(.topic-list-item-separator) td {
    border-bottom: 1px solid #eee;
.topic-list a.title:not(.badge-notification) {
    color: #3b5998;
    font-weight: normal;
    font-family: 'Helvetica Neue', Helvetica, Arial, Utkal, sans-serif;
    font-size: 18px;
.topic-list a.title:not(.badge-notification):hover {
    text-decoration: underline;
.topic-list .creator, .topic-list .editor {
    font-size: 13px;
    display: block;
    margin-top: 3px;
.topic-list .main-link {
    width: auto;
.topic-list {
    td, .creator a, .editor a {
        color: #888;
.topic-list td {
    padding-bottom: 10px;
.topic-list th {
    color: black;
    background-color: #fafafa;
.topic-list {
    border-top: none;
.topic-list td:first-of-type {
    padding-left: 10px;
    padding-top: 10px;
.topic-list tr.topic-list-item-separator td:first-of-type {
    padding: 0;
.topic-list {
    .fa-tag {
        opacity: 0.7;
        font-size: 10px;
        margin-right: -2px;
    .num.posts-map {
        position: relative;
        font-size: 17px;
        a {
            color: #888 !important;
        a.heatmap-high {
            color: #c66 !important;
        width: 100px;
.topic-list td.last-post, .topic-list th.activity {
    width: 160px;
    .relative-date {
        color: #666;
    width: 65px;
    text-align:center;
    padding-top:14px;
    .relative-date {
        color: #666;
    text-align:center;
.topic-list .creator .relative-date {
    margin-left: 8px;
.badge-category-bg {
    opacity: 0.8;
.topic-list .badge-wrapper.bar {
    .badge-category {
      color: #9a9a9a !important;
      font-weight: 600;
      font-size: 12px;
      padding: 2px 6px;
        top: -1px;
.last-post {
    .poster-avatar {
        margin-right: 10px;
    .poster-avatar, .poster-info {
        float: left;
.topic-list .posts {
    width: auto;
/* topic page */
#topic-progress {
    background-color: #f1f1f1;
    color: #666;
    .bg {
       background-color: #bee9e9;
nav.post-controls button.has-like {
    color: #08c;
.badge-wrapper.bullet span.badge-category {
    color: #333 !important;
.creator .badge-wrapper.bullet span.badge-category {
    margin-top: -2px;
#suggested-topics td.main-link {
    width: 500px;
.topic-list a.title.visited:not(.badge-notification) {
    color: #6644aa;
.topic-list-item .discourse-tags {
    font-size: 0.75em;
    display: inline-block;
    margin-left: 5px;
Which gives me the layout
8 Mi Piace
