Solved: Exited the chat bot from that telegram group. And understood that if I wanted the bot to be the part of that group, then that group’s chat ID need to have a channel and a channel rule under itself.
The Telegram integration works very well for channels but it’s unsuitable for groups-- it will spam its operation instructions every time a chat “event” happens (like someone joining or leaving the chat, or a message getting pinned). Even if you disable the slash commands entirely. Is there a way to get the bot to not respond to these events?
Do you have group_privacy disabled?
I tried that setting too and saw that it becomes every message as you say. Even with group_privacy enabled bots can still see these join/leave/pin events.
I created the telegram bot, entered the key and activated the function in discourse. HTTPS is enabled (our site runs behind an apache proxy)
However the tab is not showing. Where can I debug this? I can not find any errors in the logs.
Is there a way to test the connection to telegram from inside the Discourse container?
thx
short update on this. I entered the discourse container with docker exec -it container /bin/bash. then I executed the following:
curl https://api.telegram.org/bot123456789:ABCDEfgh2ZojwyChMz0xuIo2Wvg4ww3XGI4g/getMe
this returned an ok response with the name of my bot etc.
however the integration with discourse does not work yet. Is there a log file somewhere so that I can debug this? Any help is appreciated.
Is the force_https site setting enabled? Is the chat_integration_enable_telegram setting enabled?
yes both settings are enabled.
HTTPS is working fine, also with login integration with fb, google, tw.
what could be the cause, or where could I find the logs?
thx
I am also facing same issue since last 4-5 days on my new discourse instance.
Hi @david, is there any way i can see the logs.
On my old instance notifications are working good with telegram bot, but in newer instance Chat ID is not getting generated. The curl command mentioned above is giving output as true from discourse instance. Other oauth plugins like google. twitter are working without any issues.
Thanks in advance.
I just got it working on a new Discourse install by firing up rails c and manually running DiscourseChat::Provider::TelegramProvider.setup_webhook()
Hope that helps!
Thanks a lot @codatory
@codinghorror Thanks for this awesome platform ![]()
It worked ![]()
can you elaborate a bit on this? should I run these commands from within the container? in which directory? I’m not a rails expert. thx! : )
Yeah; so you enter the container and run
rails c
Then wait a bit for it to load up. Once it’s loaded up you can paste in
DiscourseChat::Provider::TelegramProvider.setup_webhook(); exit
Then you can exit out of the container and it should be working.
THANK YOU, this solved my issue But had to toggle the plugin off in my admin. Then on. Then run this.
J’ai réussi à faire fonctionner cela, mais pas dans un groupe. Les notifications m’arrivent directement sous forme de chat entre moi et le bot.
J’ai ajouté le bot à un groupe privé et lui ai accordé des droits d’administration. J’ai également ajouté le groupe en tant que canal dans les paramètres du plugin Discourse. Cependant, chaque fois que j’essaie d’envoyer une notification de test au groupe (canal Telegram), je reçois une erreur 422, peu importe ce que je fais. Cette erreur provient des paramètres de canal du plugin Telegram pour Discourse.
Quelqu’un peut-il m’aider ? Je tiens vraiment à configurer cela pour notre groupe.
Ce problème devrait maintenant être résolu, grâce à cette PR :
Le problème le plus courant est une clé API invalide. Assurez-vous de l’avoir copiée/collée correctement et de ne pas avoir introduit accidentellement des espaces avant ou après.
Le jeton API fonctionne correctement : je peux recevoir les notifications dans un message privé du bot sur Telegram. Il ne peut simplement pas envoyer de messages au groupe. De plus, chaque fois qu’un membre du canal envoie un message, le bot indique : « Ce canal est configuré avec l’ID de chat : … », ce qui est très ennuyeux.
Maintenant, je rencontre cette erreur.
Errno::ECONNRESET : Connexion réinitialisée par le pair - SSL_connect
from /usr/local/lib/ruby/2.6.0/net/protocol.rb:44:in `connect_nonblock’
Peu importe comment cela est activé ou désactivé, je rencontre le même problème. Y a-t-il une solution de contournement ?
J’essaie de configurer les notifications, mais lorsque j’ajoute le bot au groupe Telegram, il n’envoie pas l’ID du chat. J’ai essayé à plusieurs reprises sans succès :<
Que puis-je faire pour dépanner ? J’ai déjà essayé d’exécuter la commande rails console.
