Plugin wp-discourse-shortcodes
I got some funding to do this recent work on it. It will be safe to use by the end of the week. Right now, it’s lacking documentation and the options page needs to be cleaned up. I’m supporting the plugin, so if people use it now and run into any problems, I’ll fix it.
9 Mi Piace
I’m a newb to wordpress and discourse… coming from a good php background with other forum software.
I have WP and Discourse installed and working perfectly with the wp-discourse plugin and discourse acting as SSO.
I can’t get these shortcodes to work for me though. I installed by downloading the zip from git and uploading that zip as a plugin. It took it and it’s activated and the shortcode page shows up within the Discourse section of the WP admin. I’ve tried adding the discourse_topics and discourse_link shortcodes and I get nothing. I’ve tried a few different ways: in a text widget (with my theme modded to allow for short codes), in the shortcode widget itself, and within a normal post.
I’ve tested a couple other shortcodes to make sure shortcodes in general are working.
Anything I’m missing in the setup?
Really want to get some of the discourse embedded in wordpress and it looks like your shortcodes are the best option currently.
Many Thanks,
Mac
Is your forum private? If so, you need to check the Enable Private Topics checkbox on the Shortcodes options page.
If you’re still getting no output, try disabling the Webhook setting if you have it enabled, and using this as the shortcode: [discourse_topics cache_duration=0] It should give you some output. If not, please let me know.
4 Mi Piace
YES. That was it. I had locked things down a bit as I’m converting to Discourse from my old forum software.
Awesome stuff. Thanks so much for the quick reply.
Are you planning to add an option to filter discourse_topics by categories and tags?
We love this plugin! Thank you very much for the work put in it. We use it very prominently at the https://confederac.io homepage.
I second @anon36484860, it would be useful to display items of a single category. For instance:
[discourse_topics source="top" category=" period="weekly" max_topics="5"]
On a different, there seems to be a minor bug. A category is not displayed in the widget:
The category is “Anti-Represión” and is in fact a subcategory. The tilde seems to be fine, because the category “Colaboración” is rendered without problems. Maybe it’s the dash?
Have you recently added the category? If so, go to the Publishing options tab, select the Force Category Update checkbox and save the page. If that doesn’t solve the issue, I’ll take a look at what’s going on.
Yes, adding a Category option is a good idea.
Doh. OK, problem fixed. Thank you. :blush:
Is this plugin still maintained?
I would love to see the ability to make a list of topics by entering individual topic IDs
We are still very interested in this feature. Would it be complex to implement? Would the paid model be an option here?
Hello, Simon.
How to add a script to these ednpoints that will change them e.g. on the basis of api ?
For example:
On my wordspress blog:
Latest Topic discussion (imported from duscourse):
Topic 1 // My City is beauty
Topic 2 // How my Paris looks like
Topic 3 // My trip in New York
And i want to make it like this:
Topic 1 // My City is beauty – null (no city)
Topic 2 // How my Paris looks like + (weather from api for Paris)
Topic 3 // My trip in New York + (weather from api for New York)
etc
Qual è lo stato di questo plugin?
Non riesco a far apparire l’avatar dell’utente e non riesco a controllare date_position. Quest’ultimo va bene, ma mi piacerebbe davvero poter mostrare l’avatar.
Ho utilizzato questo codice: [discourse_topics source="latest" tile=true excerpt_length="55" date_position=bottom]
E ottengo questo output
Cosa sto facendo di sbagliato?
@simon ci sei…? :smiley:
Puoi controllare qual è il valore dell’attributo src per l’avatar? Puoi trovarlo utilizzando gli strumenti di sviluppo del tuo browser. Questo ci darà un’idea di qual è il problema.
<img class="wpds-latest-avatar" src="">
Quindi niente scuse…
Non sarò in grado di testarlo prima di lunedì. Mi metterò un promemoria per guardarlo allora. Da una rapida occhiata al codice, l’attributo src dell’avatar dovrebbe essere impostato per te. Tuttavia, non vedo nel codice nulla che gestisca l’argomento date_position=bottom. Rimuovere date_position dagli argomenti dello shortcode fa qualche differenza?
Probabilmente la maggior parte degli utilizzi di questo plugin potrà ora essere gestita da Embedding a list of Discourse Topics in another site.
Bene, ho provato a risolverlo da solo, ma non sono riuscito a farlo…
Al momento…
…è troppo basilare.
Puoi inviarmi un link a un post in cui stai utilizzando lo shortcode? Darò un’occhiata per vedere cosa sta succedendo con l’URL dell’avatar.
Ho controllato il sito da cui stai recuperando gli argomenti. Il problema è che, per ottenere il template dell’avatar dell’Autore Originale, il plugin scorre gli autori di ogni argomento per trovare quello con la descrizione “Original Poster”. Poiché il tuo sito è in danese, la descrizione da cercare per individuare l’Autore Originale dovrebbe essere “Oprindelig forfatter”.
Non sono sicuro di quale sia il modo migliore per individuare l’Autore Originale dall’elenco degli argomenti. Se desideri provare a risolvere il problema sul tuo sito, il codice che deve essere modificato si trova qui: wp-discourse-shortcodes/lib/discourse-topic-formatter.php at master · communiteq/wp-discourse-shortcodes · GitHub. Sostituendo il pattern /Original Poster/ con /Oprindelig forfatter/ dovresti risolvere il problema.
Non penso che risolverò il problema legato a date_position=bottom. Rimuoverò quel parametro dal README del plugin. Mi piace molto questo plugin, ma ho capito che gli shortcode non sono più l’approccio migliore per questo tipo di operazioni su WordPress. Sarebbe fantastico avere un nuovo plugin che permetta di aggiungere un Blocco Lista Argomenti Discourse a un post di WordPress.
4 Mi Piace
L’ha risolto :smiley:
Grazie!
