Ich habe eine E-Mail von jemandem erhalten, der Probleme beim Aktivieren der Zwei-Faktor-Authentifizierung (2FA) hat – dabei kann ich mich nicht daran erinnern, dies jemals aktiviert oder etwas dafür eingerichtet zu haben. Muss ich das tun?
2FA was added back in early March. See Discourse 2.0.0.beta4 Release Notes. You (a Discourse site admin) shouldn’t need to do anything.
@featheredtoast may have some suggestions on what to try (or to ask the user to try) to get this working.
Thanks ![]()
Is there anyway we can disable it? I haven’t looked into it so not sure how it works, but I don’t like the idea of having to rely on (or send user info to) a third party.
I don’t believe it can be disabled, no. Also, no data is being sent to a third party.
Here’s a quick summary of 2FA: Discourse implemented the TOTP (time-based one time password) algorithm. When a user decides to enable 2FA they are presented with a QR code (or a long string of characters). That string is used by an authentication app (like Google Authenticator, Microsoft Authenticator, Authy, YubiKey, etc.) to generate a new 6-digit password every 30 seconds. Those apps are in no way connected to your Discourse site, nor do they have any user info. They simply generate a code every 30 seconds. Your Discourse site also knows what those codes are, so when a user tries to log in, after entering their username and password they’re asked for a code. They check their app, enter the code, and the server checks if it’s the same code it expected.
Does that make sense?
A good thing to check is whether or not the server time is in sync with the world (generally through ntp).
Having an incorrect time can cause some interesting errors as this protocol is time based.
Thanks both ![]()
Does it need to connect to a third party to learn/check what those codes are? Or is it all generated on my server?
Just checked the time and it’s fine.. would timezones matter? I’m guessing the person is in a different timezone to that of what is set for the server.
Ask the user to use the “Time correction for codes” operation in the app’s settings.
Not at all - it is 100% on the server.
No. It’s based off UTC; not local time.
What may help is if you want to check what the server’s opinion of the current code is you can use e.g. from the rails console:
pry(main)> User.find_by(username: "Supermathie").totp.now
=> "319971"
Hey, ist es für einen Admin möglich, die Zwei-Faktor-Authentifizierung eines Benutzers zu deaktivieren?
Es scheint keine Option dafür zu geben, aber ein Mitglied unserer Community ist ausgesperrt und kann sich nicht einloggen, da er die 2FA eingerichtet hat.
Es ist nicht möglich, die Zwei-Faktor-Authentifizierung über die Benutzeroberfläche zu deaktivieren – dies erfordert den Zugriff auf die Rails-Konsole. Siehe How to disable 2FA - #11 by featheredtoast
Ein kleines Update dazu: Administratoren können die Zwei-Faktor-Authentifizierung jetzt für andere Benutzer auf der Seite /admin/users jedes Benutzers deaktivieren. ![]()
