إضافة إمكانية تضمين Onebox الخاص بـ GitLab
Add ability to Embed GitLab Onebox by displaying the code inside like GitHub Does in Discourse.
https://gitlab.com/DevsPen/Theme/blob/master/about.json
إعجاب واحد (1)
Gitlab needs to support it. Onebox probably has nothing to do with it.
Have you checked how they render on iframely?
3 إعجابات
I’m not so sure. Gitlab is similar to Github, which has its own onebox engine/rule
onebox/lib/onebox/engine at main · discourse/onebox · GitHub
5 إعجابات
So github is treated differently?
Yes. It has a few custom engines to one box it’s urls
3 إعجابات
Oh okay! I was unaware of it.
We’d be happy to support a PR that adds custom onebox behaviors for GitLab.
7 إعجابات
https://github.com/discourse/onebox/pull/385
A plugin as well:
https://github.com/misaka4e21/discourse-onebox-gitlab
5 إعجابات
This is very cool, but I feel like we should just fold it all into onebox, no need to add one more plugin here.
Can you show some screenshots of how it looks?
Excellent work @misaka4e21!
4 إعجابات
The plugin will only be necessary when the pull request is not merged. All things in the plugin are included in the PR.
(It seems that the GitHub icon is wrongly displayed.)
إعجابَين (2)
cool lets get the icon sorted as well, also the spacing the the gutter looks really big.
The GitHub favicon is now removed for GitLab. The independent icon of GitLab should be added to the discourse onebox.scss and assets instead of the onebox repo, in order to be shown.
As for the spacing issue, it is the same as current GitHub ones.
5 إعجابات
Hmm, this only supports gitlab.com urls, not other domains?
Here’s an example:
https://git.pleroma.social/pleroma/pleroma/blob/develop/mix.exs#L28-30
إعجابَين (2)
Yes it currently supports only gitlab.com.
Should we match any URL with pattern /<user>/<repo>/blob/<branch|commit>/<path> without checking it to be a GitLab instance?
And, there is also other git hosting platform, such as gogs: Making sure you're not a bot!
I searched for identifying elements, and there’s nothing good in the <head>, but body[data-page="projects:blob:show"] might be a good one.
Of cousre, Discourse has <meta name="generator" content="Discourse..."> :wink:
إعجابَين (2)
I think gitlab.com only for now is fine, we can further refine it later.
5 إعجابات
