Add WhiteListIframe embed of everycircuit.com
  <a href="http://everycircuit.com/circuit/5222925563068416">Push-Pull Boot Converter - EveryCircuit</a><br>
    <iframe width="560" height="360" src="http://everycircuit.com/embed/5222925563068416" frameborder="0"></iframe>
I add url line see from history Plugin whitelist iframe but can not work. How should I fix it?
The API for whitelisting iframes is a mess.
I will fix it, it is on my list.
thank you very much.
I tried use http. It work. But url embed of everycircuit.com is http only. How to fix it to work my website.
API is no longer a mess per:
https://github.com/discourse/discourse/commit/e283e6aea002fb533640e68f8ee7447cf0a7c90d
Feel free to allow whatever iframes you want via site settings.
Oh thank you very much :grinning: and i can add link embed from something web http or not. I trid add http://everycircuit.com/embed/ and post
not work
I try load http it work :sweat:
This isn’t a Discourse problem, it’s a browser security feature. You cannot embed an insecure (http) website in a secure (https) website. If you check your browser developer console you’ll see the error message
Mixed Content: The page at https://your.forum/65/3 was loaded over HTTPS, but requested an insecure resource http://everycircuit.com/embed/5222925563068416. This request has been blocked; the content must be served over HTTPS.
The only way to get it solved would be to contact everycircuit.com and get them to set up HTTPS connections to their site.
Yes. I send mail to Everycircuit themes them said “They are working on a version which will work in all browsers. When do that, They will support https.” and I’ll wait.
Sospetto che funzioni, dato che molto probabilmente hanno già aggiunto il supporto HTTPS su Everycircuit. Puoi confermare, @Bank_Live?
Sì! Ora funziona :grin: :tada:
Grazie mille per avermelo detto.
