I need to allow administrators to upload a specific type of file, such as .bat, .cmd, and others. For ordinary users need to disable it. How can i do it?
I dont believe you can - the only way to do it would be to add it as an authorized extension - upload the file then remove it from the settings after.
Looks like it may be going into version 2.0
https://github.com/discourse/discourse/pull/5364
Aggiornamento: usa l’impostazione del sito estensioni autorizzate per lo staff per aggiungere estensioni speciali autorizzate per lo staff ![]()
