Admin Plugin page is blank - Error: There is no route named adminPlugins.index
Hello!
I just upgraded via shell on a DigitalOcean installation with any size Discourse forum. All is working fine, with the exception of the plugin area in the Administration panel, which is entirely blank.
If I go to admin/upgrade, the list loads fine, instead.
I see this error in Firebug coming from a js file:
http://mydomainhere/assets/ember_jquery-37ec8949e7219a8c2b3cdebef9d43bc64a66860ec196f3e10bea842d0296256f.js
Line 16
Tried to search in the forums for the same issue but I could not find anything.
I attempted multiple rebuilds and disabled plugins, without luck.
Thanks!
Try entering safe mode: Using Safe Mode to troubleshoot issues with themes and plugins
Im seeing this as well.
Version: 1.7.0.beta8
Is it working fine in safe mode. Did you upgrade to latest?
It’s not working in safe mode, and looks it upgraded to latest automatically.
Can you try
cd /var/discourse
git pull
./launcher rebuild app
If it is still broken this may be related to some routing change @eviltrout made yesterday, what locale is your forum?
Rebuilt the app, still broken.
I tried both English and Chinese.
PR added
https://github.com/discourse/discourse/pull/4578
「いいね!」 5
Isn’t the “index” route supposed to be automatically added by Ember?
Also, that route works fine here on meta. We still don’t have a clear reproduction case.
Hi, I installed discourse on localhost a few hours ago, and I have almost the same error, but to me it doesn’t show any error, just blank page. I use firefox esr, it allows javascript, I run git pull and rebuilt it again to get the fix vinothkannans, but no luck..
It returned the error in development environment. That’s why I created that PR. Surprisingly it is working fine for me too in production server.
My PR not yet merged with master.
I can confirm that this route doesn’t work in dev anymore.
I merged @vinothkannans’s PR but I will leave it out to @eviltrout to ensure this is the right fix (not sure why this is the only route we have to do that…)
Hello,
indeed, using safe mode did not make a difference. I tried multiple times with the whole rebuild process. The weird thing is that this occurs in some installs and not in others, even with the exact same plugins.
I have not tried the fix by @vinothkannans yet!
I found way to reproduce in production server. If we use a plugin which use a nested route of adminPlugins then we will not have the issue. In this case index route created automatically like @zogstrip mentioned . For example I am using discourse-navigation plugin which have page as /admin/plugins/navigation. So I am not having the issue in my live. Like it I guess meta.discourse will have akismet plugin.
If we don’t have any plugins which using that path then we can see the issue.
「いいね!」 4
Meta is still on the Ember 2.4 branch which is why it isn’t breaking here.
It looks like in the newer versions of Ember, you need to have a nested route in order for Ember to generate the index route automatically
Hi!
I have the same error, forum is blank.
I try reboot and rebuild, but not work.
If I enter in safe-mode works fine. Any solution??
When you done rebuild? Recently a PR for this issue is merged with master. You may need to try again.
How it created the index route automatically when all plugins disabled :open_mouth:
Okey, I upgrade with the new two commits: forum is blank.
I reboot and rebuild: forum is blank :frowning:
I clarify that the entire forum is left blank, not just the plugins page.
It worked for me :stuck_out_tongue: Thank you very much @vinothkannans! :smiley:
What exactly have you done? Step by step please :smile:
