Hello,
this is a little plugin which allow to index data in Algolia Indexes.
https://github.com/mlamarque/algoliasearch-discourse
This plugin is work in progress to fetch data from front-office.
it’s, of course, open source, so help / feedback is welcome.
6 „Gefällt mir“
Bas
(Bas van Leeuwen)
2. August 2017 um 11:26
Hi @matthieu_lamarque ,
I’d love to get this working! But I’m having some issues with the Docker install.
If you follow the original instructions, it won’t work, since it’ll be removed after a rebuild. So I guess I need to somehow get this into the app.yml
Simply adding any of the following variations to app.yml yields errors and I don’t have the Ruby/Docker knowledge to debug them properly.
bundle exec rake plugin:install repo=https://github.com/mlamarque/algoliasearch-discourse.git
git clone https://github.com/mlamarque/algoliasearch-discourse.git
They all yield (a variation of) NameError: uninitialized constant AlgoliaSearch
I have a feeling it’s a simple fix, if you or anyone else can, please help
fefrei
(Felix Freiberger)
2. August 2017 um 13:19
1 „Gefällt mir“
Bas
(Bas van Leeuwen)
2. August 2017 um 13:44
Hey Felix, that’s exactly where I’m stuck
My current app.yml contains;
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
- git clone https://github.com/vinkas0/discourse-navigation.git
- git clone https://github.com/vinkas0/discourse-branding.git
- git clone https://github.com/discourse/discourse-solved.git
- git clone https://github.com/mlamarque/algoliasearch-discourse.git
The first three load perfectly fine, the last one fails
fefrei
(Felix Freiberger)
2. August 2017 um 14:53
YAML is very picky about whitespace. Remove the blank line (which contains a space) and make sure there aren’t any tabs in there, then try again
Bas
(Bas van Leeuwen)
2. August 2017 um 15:05
Thanks for the debugging, but that’s not it either unfortunately
this fails:
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
this works (but of course, doesn’t install the plugin):
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
# - git clone https://github.com/mlamarque/algoliasearch-discourse.git
fefrei
(Felix Freiberger)
2. August 2017 um 15:31
7
Can you post the log from the rebuild command?
The plugin may be incompatible with current versions of Discourse.
1 „Gefällt mir“
Bas
(Bas van Leeuwen)
3. August 2017 um 11:52
8
Yeah, I’m afraid that it might be outdated
Log is rather long, relevant part:
Bundled gems are installed into ./vendor/bundle.
I, [2017-08-03T11:42:56.485801 #14] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
/var/www/discourse/plugins/algoliasearch-discourse/plugin.rb:9:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:208:in `block in notify_after_initialize'
Full log: log.txt.gz (41.9 KB)
Bas
(Bas van Leeuwen)
25. September 2017 um 09:36
9
fyi: one of our Ruby devs made a PR on this which was accepted
Plugin is no longer #plugin:broken-plugin
5 „Gefällt mir“
