Features of the chrome extension:
We use discourse internally as a learning management system.
We have tried more complicated LMS and discourse is significantly better with the help of this chrome extension.
By all means, please share it in #plugin:extras!
I’d be very interested in a description of how you used discourse as an LMS as well !
From the picture you shared I can see each topic is a single question, but how do people answer these questions and how are they rated as correct or not ?
Do you use polls ?
Using polls.
The poll choice from a selected admin is considered the correct answer.
There is some hard coded stuff in the current browser extension. I will convert them into parameters and then upload it.
Sembra fantastico, per favore spiegati meglio! Sembra un sacco di divertimento per gli educatori
