Can anyone suggest how the Unbounce community is doing this:
You can see the live page here:
It’s a simple but very clever workaround
They have added a link at the end of the About category topic
Then they simply customized that link with CSS:
.category-heading a {
display: inline-block;
padding: 4px 10px;
border-radius: 1px;
border: solid 3px #F6921E;
font-family: Whitney SSm A,Whitney SSm B,Helvetica Neue,Helvetica,Arial,sans-serif;
text-transform: uppercase;
font-weight: 600;
margin-top: 20px;
margin-right: 10px;
font-size: 12px;
color: #fff;
background-color: #F6921E;
z-index: -1;
box-shadow: 0px 3px 0px #d87809;
That’s the CSS to make the link look like a button. I get that. But I still don’t understand how they got that whole section to appear above the navigation. Is there a built-in option for that? It also doesn’t account for the presence of the image.
It looks to be a Banner that they’ve used CSS to either offset or otherwise not display the “dismiss x”
It’s different in every category, though. Is that a thing?
That is a mystery. AFAIK, there can be only one Banner.
Because they’re different. I think they’ve found a way to display Pinned topics as though they were Banners. Or wrote some code to allow more than one Banner.
You can use jQuery (or Handlebars for the brave) to create, position and style elements, on the fly, in specific pages.
Discourse adds classes to the <body> tag that match the category you’re on.
So you think maybe they’re iframes containing the first posts?
The example website does not seem to be using iframes,
I’m not extremely knowledgeable with the native Discourse element tree, but it looks like they have added a <section> that contains an <img> a <p> and an <a> with composer parameters to that match. In other words, plain html added to the native .list-controls div
@dax shared the CSS they use for the <section> tag above
Edit:
Well I was way off on this one.
Sorry @alehandrof , I’m a bit confused now… I was sure you were referring to the button inside the banner, not the banner itself…
This is a category on my forum:
As you can see I have the category description above the navigation. I do not remember having customized anything here, so the “banner” is created (or created) directly from Discourse.
I’ll take a look at my settings in the meantime.
Right, @dax. The example of the category description from your forum is what I’d like to achieve.
There are three pieces and I’m only missing one:
Use CSS to style the link to look like a button
Use the category logo setting to display an image to the left of the description
Add a description… how?
Yes is a category setting, you as owner of this topic, can select a reply as solution clicking on the solution icon
,near the Reply button.
A few notes notes for posterity, because I couldn’t find this “category banner” documented anywhere.
<small>Lo intenté, pero no funciona: Ateliers - Koweb Kafé
Falta el contenido del tema ‘About’. ¿Tienes alguna idea de por qué?
