Feature request: Block a specific user from PMing you.
9 лайков
Yes, we definitely need to get to this.
I suggest the block can also block them from @name mentioning you as well.
I would recommend that.
Of course any block would only apply to users, not to staff. ![]()
A must have for large communities! A simple block button on the user card and/or profile page should be perfect from UI side.
Regarding the behavior, the blocked user will not be able to mention me or I will just not be notified?
Is this already planned for upcoming versions?
Did this feature ever happen? Im not finding a reference to it anywhere else but it is something I would also like to see (and which my users are requesting.)
Quite a while ago. Go to
https://meta.discourse.org/my/preferences
and look for
“Users Muted” near the bottom
