Browser-based PDF Viewer with search and highlighting capabilities
Hello my friends,
regarding to my earlier topic - let’s say: unsolved key issue - I’m still looking for an option to open uploaded pdf files into the browser.
I’m using Discourse as knowledge-base. A lot of the content is embedded into pdf files. Unfortunately I can’t switch to other hosting alternatives like Dropbox or Owncloud … It’s simply too complicated to mange multiple systems and link every single file.
Moreover, it would be a real benefit for every single user, if highlighting and putting notes to the pdfs would be possible. But the most important feature I’m looking for, is to search through these documents in addition the Discourse search engine. Maybe enabled through another checkbox beside the search filed :slight_smile:
This would be a real benefit for Discourse at all. :blush:
What are you guys thinking about this feature request?
Best
3 curtidas
Changing Discourse so that PDFs could be displayed in the browser rather than downloaded seems like it would be pretty easy and useful, although clicking the downloaded file isn’t that difficult.
Including some kind of PDF editor/highlighter seems like a plugin that would be a fair amount of work. If you’d like someone to develop that, you should post in the Marketplace.
1 curtida
Searching within attachments has been discussed and there are existing topics on that. Not easy to do and not on our current roadmap though.
3 curtidas
I am not sure if this fits in here but I thought I’d mention it: there used to be a great tool called crocodoc but it has been discontinued and replaced by box view:
https://blog.box.com/blog/new-box-view/
3 curtidas
hi @terraboss Did you find any solution ?
1 curtida
hi @ufukayyildiz, nope :roll_eyes:
2 curtidas
Eu adoraria ver esse recurso também. Infelizmente, não tenho condições de patrociná-lo. Acompanhando este tópico caso algo surja…
2 curtidas
Como a solicitação inicial é bastante antiga e o Discourse evoluiu fantasticamente durante esse período, essa funcionalidade poderia ser revisitada — há alguma chance?
Bem-vindo ao Meta @Cocco17 :wave:
Agora temos um componente de tema que permite renderizar arquivos PDF diretamente em sua postagem. Confira aqui
7 curtidas
@Johani uau, não encontrei isso na minha pesquisa. Muito obrigado, isso é ótimo!
