Can I keep a log for 404 not found pages?
Can i keep a log for 404 not found pages?
Like that pattern:
date - url -how many time
You should be able to use Google Analytics to get that info.
I am already use Analytics. I should get the info on Analytics panel, right?
No – if you’re using GA you get that data directly from the GA interface, rather than through the Discourse UI.
Edit: I made an assumption about what you meant by the Analytics panel.
It’s not that easy to be honest.
You need to either make a custom javascript file to check if “Oops! That page doesn’t exist or is private.” exists, or change the 404 template to fire an event. So no, this is not out of the box and also it’s a bit fragile.
I would agree that this feature is useful; especially in the days directly after a migration.
We’re about to customize our 404 page using tips from: Customize the 404 page ("Oops! That page doesn't exist or is private")
Is the information in this topic still relevant?
  • that there’s no way to do log this in discourse
  • that GA still makes it hard to track 404s out of the box
I don’t believe this has changed.
One way that might make it easier to track in Google Analytics is if we update the page title to something like 404 not found - forum name — In GA you can create a custom report that filters for page title without any custom JS or events.
Existe-t-il un moyen de mettre à jour le titre de la page pour les pages 404 ?
Tout texte dans Discourse peut être personnalisé. Dans votre cas, vous devrez modifier page_not_found.title depuis /admin/customize/site_texts/page_not_found.title.
Désolé, je fais référence au titre de la page dans la section head qui s’affiche dans l’onglet du navigateur. Je n’ai trouvé aucune personnalisation de texte liée à cela.
