هل تكون الصفحة الرئيسية للفئة هي الافتراضية؟
Yes, I also realized that showing the category page by default might provide better orientation for new users and changed my homepage.
When read @HAWK’s statement, I’m wondering: if that is indeed a general “rule”, then wouldn’t it make sense to set the category page as default homepage for new forums?
Disclaimer: I’m assuming that there is a default homepage. I don’t remember whether this is something you are asked to specific in the setup process, but even if it is, there’ d seem to be something that pushed me towards choosing “Latest” as my homepage. (As a side note: it is also somewhat difficult to find how to change the homepage)
إعجاب واحد (1)
The easiest way is to rerun the wizard.
إعجاب واحد (1)
I’m not sure if that is “easier” than changing the order of your top menu items. If you know that this is what you have to do, I’d say that’s the easiest. But if you don’t know what to do, searching the settings will point you neither to the wizard nor to the order of the items in the top menu.
Suggestion: perhaps it would help to change the help text for the top menu settings from this:
to: “Determine which items appear in the homepage navigation and in what order (the first item is the default homepage). Example: latest|…”
But the more user friendly solution would be to add a site setting “default home page”, simple because the way things are now, it’s a bit of a nuisance that you have to remove all the items in order to change the first one.
14 إعجابًا
We are more likely to delete that setting altogether.
إعجاب واحد (1)
You mean the top menu site setting?
Hey guys,
I would like to edit our discourse channel as to make the categories the default for the homepage, just like here:
Currently, the default for the home page is “Latest”.
How can I do that?
Best,
Vlad
Re-run the wizard (example.com/wizard) and choose Categories and Latest Topics.
13 إعجابًا
Thank you! It worked.
إعجاب واحد (1)
Can you elaborate?
I am about to use the strategy mentioned here which is to set the default homepage to Categories (I assume by re-ordering that list, which is a little confusing), but then setting the Logo to link to Latest. This enables new users to encounter the Categories, but generally to after that be encountering latest.
If this is to be removed, can you explain how we could address the given concerns? Or link to discussion about this.
thanks!
That global setting is still active however it’s more simple if you choose the homepage when you run the wizard the first time (and subsequently). Whether the setting is hidden or not for you is irrelevant (you can always use the wizard).
You can certainly change the link to the logo.
I also want to remember you that now the users can choose the default page from the preferences on the user profile:
4 إعجابات
هل فكرتم يومًا في استخدام تخطيط مختلف للصفحة الرئيسية على سطح المكتب والجوال؟ أم أنني كمستخدم جديد لم أجد الإعداد الذي يقوم بذلك؟
لقد فكّرت في فكرة جعل سطح المكتب يظهر في وضع “الأحدث حسب الفئة”، لو كان هناك طريقة لجعل الجوال يظهر افتراضيًا “الأحدث” فقط.
إعجاب واحد (1)
4 إعجابات
يوجد أيضًا مكون موضوع لإجبار الصفحة الرئيسية للجوال على أن تكون مختلفة عن سطح المكتب:
ولكن تذكر أن المستخدمين لن يتمكنوا من تجاوز هذا التغيير من خلال ملف تعريف المستخدم الخاص بهم.
7 إعجابات
هذا الحل نجح معي، شكرًا لك!
كما قلتُ من قبل، هناك عنصر موضوع (theme component) لذلك
5 إعجابات
عظيم! شكرًا لتوجيهي إلى هذا الإعداد.
@codinghorror سأفتقد هذا الإعداد لو أزيل… لماذا تفعل ذلك؟
لقد قمت للتو بتبديل موقعي إلى عرض التصنيفات. يظل هذا العرض للمستخدم حتى يسجل الدخول، وعندها يتحول إلى عرض آخر التحديثات.
هل توجد طريقة لإجبار جميع تفضيلات المستخدمين على العرض الافتراضي مرة واحدة فقط؟ ربما يكون هناك أمر SQL يمكن تنفيذه؟
شكرًا لك.
يمكن للمستخدم تجاوز ذلك عبر /my/preferences/interface — انتبه إلى ما يُكتب فيه “الصفحة الرئيسية الافتراضية”
نعم، شكرًا لك. لكن من الصعب تثقيف المستخدمين في نوع المنتدى الذي نديره. سيكون أمر تحديث لمرة واحدة مفيدًا جدًا.
لقد قمت بذلك اليوم لاستخدامه مع مكون موضوع لوحة كانبان.
3 إعجابات
