Catégorie non pré-sélectionnée dans le composer lors de la création d'un sujet avec le raccourci 'c'
I just verified on two Discourse instances that Topic Templates work only when you click the ‘New Topic’ button, but not when you hit the c key.
2 « J'aime »
I recall this being a bug earlier in the lifecycle of Discourse.
I’m not on the latest build (out of fear of the image rebaking option), and our company’s blog is also older. These are the versions that I observed this on:
  • 2.2.0.beta6 - version 0884cd218d30d365aa3e8c5f0071e9341ecf9360
  • 2.0.0.beta1 - version d2025e33cfa1efe23328222fccee9e8f83986a64
Hope that helps.
I just tested this on try. Here’s what I found:
  • I added a topic template to the discourse category.
  • I navigated to the discourse category https://try.discourse.org/c/discourse.
  • I clicked the “New Topic” button.
    • The composer opened with the discourse cateogry pre-selected. As such, the topic template was displayed.
  • I closed the composer.
  • I then clicked c on my keyboard.
    • The composer opened without any category pre-selected. As such, no topic template was displayed.
From what I can tell the issue is not about topic templates, but that the keyboard shortcut does not open the composer to the correct category.
4 « J'aime »
https://github.com/discourse/discourse/commit/a518950e524d482bec0b1201276450f7aaa8725a
This should fix it up!
7 « J'aime »
