Category:slug search does not work
I recently renamed my categories, leaving the slugs unchanged (so “macro” changed name to “Macro Library”).
I can with #macro or #"macro library" or category:"macro library".
But category:macro does not work for some reason, gives: No results found.
Was slug search ever supposed to work? I don’t know that this was supported at any point?
Why wouldn’t it be supported?
Then this is a feature request “make search also work with the slugs of categories, not just the names of categories”.
Did auto-complete in search solve this? You can start typing the category name/slug and hit tab for it to fill out to the correct syntax…
However, I bet the quotes are throwing off auto-complete, I tested it on my sandbox and typing “#site feedback” followed by tab changes it to #site-feedback
Whether it is a bug or a feature is up to you to decide. To me it is a broken implementation, but if you consider it to be a feature request, that’s fine too.
That does not appear to work with “category:”. I can type “#que” to complete to #questions, but I cannot type “category:que” to complete to category:questions.
