Farbe der Aufzählungszeichen für Tags ändern
I’ve searched through every CSS element I could find through the console and I tried my best to change colors and wraps but I cannot find a way to change the color of the tag bullet & icon. Whenever the scroll-down header animation initiates, the tag color goes from visible to hardly visible. Is this even possible to do via CSS?
You need to look at before and after pseudo selectors too
35%20PM
So in this case you need to add
.discourse-tag.bullet:before {
   color: $header_primary;
Oh wow, the more you learn! :sparkles:
Now that fix definitely makes the tags visible on the scroll-down header, but then what happens is the tags before the scroll-down (so normal, start of the topic) get practically invisible. I tried playing with .discourse-tag.bullet:after but no luck.
Right, so you want to be more specific
.d-header {
Wow CSS never fails to impress me with the amount of possibilities. I really appreciate your support @awesomerobot, you continue to motivate me to fully learn CSS :smile:
