Conectando a Droplet
Hello, I’m trying to install Discourse on localhost to play around. I succsfully did all the steps in the Install Discourse on Ubuntu or Debian for Development guide.
I connected to http://localhost:9292/ and it says:
On the following link Create an admin account from the console it says to connect to Droplet by doing: ssh root@192.168.1.1.
What does it mean? I though Droplets are a thing in DigitalOcean (And I still didn’t purch a vps on DigitalOcean - just wanted to play around before buying). Where should I connect or how should I continue?
Thank you for the help
In the Install Discourse on Ubuntu or Debian for Development topic, an admin user should be created by following the step in the Create New Admin section. From your discourse directory run:
RAILS_ENV=development bundle exec rake admin:create
That command will open a prompt that asks for details about the account you are creating. Make sure to enter Y when it asks if you want to grant admin privileges to the account. Once that has been done, you should be able to login with your new admin account.
