dandv
(Dan Dascalescu)
10 أكتوبر 2015، 1:54ص
I get the same error message as in this post when running the MyBB importer as I’ve described here :
$ RAILS_ENV=production ruby mybb2.rb
loading existing groups...
loading existing users...
loading existing categories...
loading existing posts...
loading existing topics...
creating users
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.7/lib/patches/db/mysql2.rb:6: [BUG] Segmentation fault
ruby 2.0.0p647 (2015-08-18 revision 51631) [x86_64-linux]
[... about 3000 lines snipped ...]
[NOTE]
You may have encountered a bug in the Ruby interpreter or extension libraries.
Bug reports are welcome.
For details: http://www.ruby-lang.org/bugreport.html
Aborted
The script does include the latest fix . By the way, while at it, can someone please merge in my PR that fixes the migration of quotes ?
I’m seeing the same on this end as well, not in the same place, but definitely the same segfault.
إعجاب واحد (1)
gerhard
(Gerhard Schlager)
10 أكتوبر 2015، 6:22م
I had a similar problem with the phpBB3 importer.
Try changing the cache_rows to true.
If that doesn’t help try upgrading the mysql2 gem:
gem update mysql2
إعجابَين (2)
Oh cool, that looks like it works. Thanks!
dandv
(Dan Dascalescu)
14 أكتوبر 2015، 1:13ص
cache_rows: true prevents the crash.
MyBB imports used to work until a few weeks ago. The crash is a regression and blocks not only imports, but also certain kinds of batch processing .
Can we please get an official fix? CC @zogstrip , @techAPJ , @riking
UPDATE removing cache_rows altogether also prevents the crash. I did downgrade the mysql gem to v0.3.20 though.
sam
(Sam Saffron)
14 أكتوبر 2015، 1:15ص
I JUST saw that today … we got to raise this issue with the mysql2 gem…its crash central with cache_rows: true. Can you raise that with them together with the segfault?
This is a reasonably new issue, was working fine a few weeks ago. Now it is bust on pretty much every ruby version.
Never mind … will raise …
إعجاب واحد (1)
dandv
(Dan Dascalescu)
14 أكتوبر 2015، 1:19ص
7
Thanks @sam . How can one revert to a working state of the gem and whatever else is involved? I only need to obtain a map of old_topic_id → imported topic_id to create a redirect map file, and the importer itself was the easiest way to get that.
sam
(Sam Saffron)
14 أكتوبر 2015، 1:22ص
8
I can’t find the core dump and am in the middle of an import, can you do a gist of it?
Unless you are a paying customer, you are not obligated to our time. If you continue to make demands like this, either buy a hosting contract, or with all due respect, take your demands somewhere else.
dandv
(Dan Dascalescu)
14 أكتوبر 2015، 2:00ص
11
I know. Discourse is an OSS project. To which I contributed many hours to the best of my abilities.
codinghorror:
I didn’t make any demand. I said “please”. Maybe too many times. Please accept my apologies.
sam
(Sam Saffron)
14 أكتوبر 2015، 2:01ص
12
I raised the issue here:
https://github.com/brianmario/mysql2/issues/691
Totally fine with a PR that removes all the cache_rows: true from the importers using mysql2 for now.
إعجاب واحد (1)
erlend_sh
(Erlend Sogge Heggen)
3 مايو 2016، 11:27ص
13
4 إعجابات
