Impossibile trovare il modulo `discourse-common/lib/icon-library`
Any idea How we can solve below error?
uncaught Error: Could not find module discourse-common/lib/icon-library imported from `discourse/plugins/discourse-solved/discourse/initializers/extend-for-solved-button
[v1.9.0.beta1]
I think you are trying to use the current solved plugin with an older version of Discourse core. You should upgrade core to latest, it should fix the issue.
we are not able to upgrade discourse, how we can use older version of solved?
That is unsupported, but if you absolutely can’t update Discourse, then you could checkout a commit prior to the commit that adds the icon-library import.
It does not matter, 1.9 has security exploits and is unsupported. At minimum you should be on 2.1, and 2.2 is about to be released..
So if we use old version of solved, it means we don’t have icon-library but we have an issue with solved button is not appearing.
I am not sure but I think we have an issue with database, we can not upgrade now. Do you have any other workaround?
Is there some reason that you cannot upgrade to latest?
I am trying to follow
https://meta.discourse.org/t/use-old-commit-to-build-discourse/108028/2
But I am getting error any idea?
I, [2019-01-31T17:08:39.945102 #15]  INFO -- : > cd /var/www/discourse/plugins && mkdir -p plugins
I, [2019-01-31T17:08:39.950402 #15]  INFO -- :
I, [2019-01-31T17:08:39.950737 #15]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2019-01-31T17:08:41.890949 #15]  INFO -- :
I, [2019-01-31T17:08:41.891630 #15]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
Cloning into 'discourse-solved'...
I, [2019-01-31T17:08:43.344731 #15]  INFO -- :
I, [2019-01-31T17:08:43.345246 #15]  INFO -- : > cd /var/www/discourse/plugins && cd discourse-solved
I, [2019-01-31T17:08:43.349650 #15]  INFO -- :
I, [2019-01-31T17:08:43.350051 #15]  INFO -- : > cd /var/www/discourse/plugins && get reset --hard 7745adb6eb0c1d1b2a37c9441c3877b7eec087cd
sh: 1: get: not found
I, [2019-01-31T17:08:43.354172 #15]  INFO -- :
I, [2019-01-31T17:08:43.354702 #15]  INFO -- : Terminating async processes
I, [2019-01-31T17:08:43.354881 #15]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid: 70
I, [2019-01-31T17:08:43.355271 #15]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 186
2019-01-31 17:08:43.355 UTC [70] LOG:  received fast shutdown request
186:signal-handler (1548954523) Received SIGTERM scheduling shutdown...
that should be a git reset, not get
yes i found that but still have issue.
I, [2019-01-31T17:31:46.695638 #15]  INFO -- : > cd /var/www/discourse/plugins && cd discourse-solved
I, [2019-01-31T17:31:46.699054 #15]  INFO -- :
I, [2019-01-31T17:31:46.699228 #15]  INFO -- : > cd /var/www/discourse/plugins && git reset --hard 7745adb6eb0c1d1b2a37c9441c3877b7eec087cd
fatal: Could not parse object '7745adb6eb0c1d1b2a37c9441c3877b7eec087cd'.
I, [2019-01-31T17:31:46.728342 #15]  INFO -- :
I, [2019-01-31T17:31:46.728832 #15]  INFO -- : Terminating async processes
I, [2019-01-31T17:31:46.728916 #15]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid: 70
that’s the wrong folder, you’ll want to do the git reset in the discourse-solved folder.
yes, I know. how i can go to correct one.
try
cd /var/www/discourse/plugins/discourse-solved && git reset --hard 7745adb6eb0c1d1b2a37c9441c3877b7eec087cd
thanks. It is worked in staging but I can not test to see if problem with solved button is ok or not.
staging and production are in different version, I need to ask for downtime for production. please keep ticket open. thanks.
Thank you Thank you sooooo much, It solved lots of issues. :smiley::smiley::smiley::smiley:
