Could not resolve host: github.com for SamSaffron/pups.git
Hi all -
We’re enjoying discourse thus far. I’m having an issue with running a rebuild of the docker container. The container won’t rebuild because for some reason it can’t resolve github.com. I know the host system (debian jessie) can resolve at that time via dig && ping. However if I issue a systemctl restart docker the issue goes away.
I turned to the goog or alphabet machine which suggested starting the docker daemon using the goog’s dns which I’ve done and confirmed that it seems to have taken via a systemctl status docker.
I’ve been able to reproduce on a debian droplet and a virtual box vm.
Also I’ve been able to successfully pull a Ubuntu image, and run the container.
I’m not sure if there’s something in launcher or any other suggestions? Working off of git master, and is up to date.
shortlist:
  • Debian Jessie Kernel 3.16
  • Docker version 1.6.2, build 7c8fca2
launch rebuild app
root@alpha:/var/discourse# ./launcher rebuild app
Ensuring discourse docker is up to date
Fetching origin
Discourse Docker is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 10 app
app
cd /pups && git pull && /pups/bin/pups --stdin
fatal: unable to access 'https://github.com/SamSaffron/pups.git/': Could not resolve host: github.com
210c421dbe03e0339d110f1eec9eb3c985b0a0d4e32709d569c9cd1f235a7964
systemctl status - shows --dns
root@alpha:/var/discourse# systemctl status docker
● docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; enabled)
   Active: active (running) since Thu 2015-08-13 03:42:17 UTC; 26min ago
     Docs: http://docs.docker.com
 Main PID: 22232 (docker)
   CGroup: /system.slice/docker.service
           └─22232 /usr/bin/docker -d -H fd:// --dns 8.8.8.8 --dns 8.8.4.4
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="+job wait(7d602b0addff82e7626b659c5e30131a11ab7f35034198983a19e2b8861111b5)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="-job wait(7d602b0addff82e7626b659c5e30131a11ab7f35034198983a19e2b88... = OK (0)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="DELETE /v1.18/containers/7d602b0addff82e7626b659c5e30131a11ab7f3503...8861111b5"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="+job rm(7d602b0addff82e7626b659c5e30131a11ab7f35034198983a19e2b8861111b5)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="+job log(destroy, 7d602b0addff82e7626b659c5e30131a11ab7f35034198983...e:1.0.12)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="-job log(destroy, 7d602b0addff82e7626b659c5e30131a11ab7f35034198983... = OK (0)"
Aug 13 04:03:40 alpha docker[22232]: time="2015-08-13T04:03:40Z" level=info msg="-job rm(7d602b0addff82e7626b659c5e30131a11ab7f35034198983a19e2b8861... = OK (0)"
Aug 13 04:04:15 alpha docker[22232]: time="2015-08-13T04:04:15Z" level=info msg="GET /v1.18/containers/json"
Aug 13 04:04:15 alpha docker[22232]: time="2015-08-13T04:04:15Z" level=info msg="+job containers()"
Aug 13 04:04:15 alpha docker[22232]: time="2015-08-13T04:04:15Z" level=info msg="-job containers() = OK (0)"
Hint: Some lines were ellipsized, use -l to show in full.
docker info
root@alpha:/var/discourse# docker info
Containers: 3
Images: 18
Storage Driver: aufs
 Root Dir: /var/lib/docker/aufs
 Backing Filesystem: extfs
 Dirs: 24
 Dirperm1 Supported: true
Execution Driver: native-0.2
Kernel Version: 3.16.0-4-amd64
Operating System: Debian GNU/Linux 8 (jessie)
CPUs: 1
Total Memory: 2.879 GiB
WARNING: No memory limit support
WARNING: No swap limit support
edit: formatting fix code block
This is very likely the solution
Hi @sam thanks for taking the time to review.
I have that option uncommented in /etc/defaults/docker, and I’ve restarted the docker service many times.
To clarify, after restarting the docker service the laucher rebuild will work once, after that I have to restart the service.
You can see this via my systemd status.
Same issue, I went to add the cloudflare template and when rebuilding it could not resolve github.com.
I have already tried the solution of using googles DNS servers in dockers configuration file with no success.
doing ping github.com works but again, it cant seem to resolve when rebuilding.
Here is the error:
Here is me pinging github.com
Imgur: The magic of the Internet
Interestingly though, when I ping6 github.com I of course do not recieve a response because github does not have AAAA records i believe.
Any idea how to fix this?
This isn’t a Discourse problem, it’s a Docker problem. You’ll probably get more knowledgeable help at the Docker support forums (which, helpfully, also run Discourse).
I figured out the issue and solution to this problem at least for me.
The issue was that Docker uses 8.8.8.8 and 8.8.4.4 as its DNS and I had an OVH network based firewall blocking ALL IPv4 traffic that did not match port 80, 443, and a few other specific rules. I had to authorize IPv4 traffic for 8.8.8.8 and 8.8.4.4
У меня возникла аналогичная проблема в последней версии Discourse из репозитория Git. Это началось после выполнения обновления системы и/или обновления Discourse через веб-интерфейс. Теперь при попытке пересобрать приложение я получаю:
[root@forum /var/discourse]# ./launcher rebuild app
Ensuring launcher is up to date
Fetching origin
Launcher is up-to-date
+ /usr/bin/docker stop -t 60 app
app
fatal: unable to access 'https://github.com/discourse/pups.git/': Could not resolve host: github.com
8f082ebcb977f9efafbdbff15ab69e8d06c0a7e2cb99410f85e1f90b03ae733b
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one.
./discourse-doctor may help diagnose the problem.
Я могу выполнить ping до github.com и 8.8.8.8, а также попробовал отредактировать файл /etc/default/docker, чтобы переключить опцию DNS: DOCKER_OPTS="--dns 8.8.8.8 --dns 8.8.4.4".
Куда мне стоит продолжить investigation этой проблемы?
Это Ubuntu 18.04 с последними обновлениями.
Я получаю ту же ошибку, что и gekkonen, после попытки обновления до последней версии Discourse.
Похоже, Docker больше не может вообще получать доступ к Интернету из сети моста по умолчанию:
docker run -it --net=bridge --rm busybox ping -c 1 github.com
ping: bad address 'github.com'
Если я принудительно использую сеть хоста, он получает доступ к Интернету:
docker run -it --net=host --rm busybox ping -c 1 github.com
PING github.com (140.82.112.4): 56 data bytes
64 bytes from 140.82.112.4: seq=0 ttl=53 time=6.902 ms
--- github.com ping statistics ---
1 packets transmitted, 1 packets received, 0% packet loss
round-trip min/avg/max = 6.902/6.902/6.902 ms
Я также использую Ubuntu 18.04.4 LTS, обновив все пакеты и установив все обновления безопасности непосредственно перед выполнением последовательности обновления Discourse.
@gekkonen У меня всё снова работает. В качестве обходного решения, чтобы заставить интернет работать из Docker, можно настроить сеть docker0 в «пропускном» (promiscuous) режиме:
[root@forum /var/discourse]# ifconfig docker0 promisc
После этого вы сможете использовать launcher для пересборки приложения, и форум Discourse должен работать нормально. Однако имейте в виду, что, вероятно, вам придётся выполнять эту команду снова после каждой перезагрузки.
Дайте знать, если у вас получится.
Я всё ещё не знаю корневую причину проблемы.
Да, это, похоже, пока решило проблему с DNS. Спасибо за совет.
В CentOS 8 эта ошибка возникает из-за того, что пакеты Docker для RHEL 7 (пакеты для RHEL 8 ещё не выпущены) не поддерживают новый фаервол на основе nftables. Необходимо вручную настроить маскирование для интерфейса docker0.
https://serverfault.com/questions/987686/no-network-connectivity-to-from-docker-ce-container-on-centos-8
Хочу подтвердить, что это решение работает. Я использую CentOS 8 от Hetzner.
Если быть точным, я выполнил следующие команды в указанном порядке (источник) — спасибо @paulraines68.
# Маскирование позволяет обеспечить входящий и исходящий трафик для Docker (это ключевой момент)
firewall-cmd --zone=public --add-masquerade --permanent
# Разрешить входящий трафик конкретно на порты 80/443 (ничего нового здесь нет)
firewall-cmd --zone=public --add-port=80/tcp
firewall-cmd --zone=public --add-port=443/tcp
# Перезагрузить брандмауэр для применения постоянных правил
firewall-cmd --reload
