Cita transdiscursiva
It would be useful if I could quote posts from external discourse instances. Something like
[quote=“member, post:3, topic:275, source:meta.discourse.org”]
Where source:meta.discourse.org would provide a similar level of context as internal quotes.
My primary use case is that I’m currently training my Staff to rely on flags instead of manual moderation, and wanted to show them this:
I copied/quoted that from the topic here on meta, and pasted it into my forum, not really thinking about what I was doing. It of course linked to a topic on my forum with the same id, which makes perfect sense, but isn’t what I want.
I could link to the post directly, which works nicely with the onebox, but I really just want to call out the relevant piece.
Aside from staff-training, I also run a few different sites that could benefit from occasionally sharing parts of conversations between them. As an added bonus, this would show users that there’s a larger Discourse world out there by bridging conversations between communities.
5 Me gusta
errr isn’t this called “oneboxing an external URL”? I mean, it already works..
https://community.letsencrypt.org/t/how-to-stop-using-tls-sni-01-with-certbot/83210
1 me gusta
Yes that works, but that’s not what I’m describing. That’s a link to the entire post, I’m wondering about the possibility of linking to a quote:
The idea is to load a quote like the one above, so that readers can see a specific part of an external post instead of a link to the full thing, but also with a link back to the source.
It would be quicker than onebox to get specific info to readers, while still letting them get all the context if they want it.
edit: update with example from the link you posted
If you’ve configured Certbot to use a directory other than /etc/letsencrypt, you should use that directory in the commands instead.
The reference post in its entirety would be too much info if I just wanted to quote the piece above, and would cause more friction for the user than is ideal. Focusing on the quote instead is more useful, but now it is somewhat orphaned. Quoting parts of posts between instances would be the best of both features.
3 Me gusta
Right but in that case I’d just quote the remote site and provide the URL at the top.. like so?
As it says in https://community.letsencrypt.org/t/how-to-stop-using-tls-sni-01-with-certbot/83210
All most users need to do is make sure your Certbot installation is up-to-date and test and configure automatic renewal for the updated version of Certbot. You can find instructions for how to do this at https://certbot.eff.org . You need Certbot version 0.28.0 or newer. You can check which version you have installed by running Certbot with the --version flag.
2 Me gusta
The reason oneboxing exists is you can’t assume what other servers are running in terms of version or platform. Not to mention that just because a site is running a particular platform today, that the same will be true tomorrow.
Create a dependency on Discourse now and if anyone ever does move away any platform-specific embedding would break. It’s one of the reasons oneboxing is so damn useful.
4 Me gusta
@codinghorror that does work yeah, but it doesn’t have the same slickness as the regular copy/quote feature. Regardless, this isn’t a common enough of a case to be bothersome, but it does have me curious about what is possible. :thinking:
@Stephen I hear ya, that does make sense. Though, would it not be within Discourse’s control to send information about itself to another Discourse instance if it recognized the request? There’s no assumption if a response says: “Hey, I’m a Discourse site too! Here’s the author name and post url to render alongside that quote you requested.”.
That’s a good point though about platform-specific embeds and migration issues. :grimacing:
Perhaps I’m envisioning something too grand here, but a Discourse instance recognizing its siblings across the web seems so cool as a concept, as does users being able to directly quote/converse with each other across communities.
Maybe one day!
4 Me gusta
Transclusión de Discourse (citando de otras instancias de Discourse)
Hace una década hubo una discusión similar, pero no llegó a ninguna parte. Ahora, tenemos un poco más de experiencia y herramientas…
Imagina que eres el Equipo de Discourse y estás utilizando una instancia pública y una privada de Discourse. Normalmente copiarías una cita de la pública a la privada, pero entonces perderías el contexto: en lugar de poder expandir la cita, o hacer clic e ir al original, también tendrías que mencionar la URL de la fuente. Ahora, si tu lector está autenticado y la URL source es parte de la cita, puedes ir perfectamente de una instancia a la siguiente.
Perfecto para sitios Discourse-connectados y para sitios que utilizan ActivityPub Plugin.
3 Me gusta
¡Me gusta mucho esta idea! Lo que describes es exactamente lo que hacemos entre Meta y nuestra instancia interna.
Creo que el lugar obvio para obtener esto es el botón Copiar cita que aparece cuando seleccionas texto en una publicación.
4 Me gusta
Abogaría por una configuración del sitio que alternara entre pasar el dominio o no en la cita copiada. Tengo un caso de uso en educación en el que no querría que el texto copiado y pegado revelara el dominio del que provino :slightly_smiling_face:
3 Me gusta
También estuvo Include the forum's URL in quotes en 2023, y no era consciente de los otros dos temas cuando publiqué esta solicitud de función :face_with_tongue:
No me sorprendería si el tema hubiera surgido en otros temas.
5 Me gusta
¿Puedes ampliar esto?
Si añadiéramos el dominio al copiar a través de Copiar cita, creo que podríamos eliminarlo convenientemente al pegarlo en el compositor del mismo sitio, por lo que la experiencia percibida sería la misma en este caso. No se eliminaría en otra instancia o si se pegara en cualquier otro lugar.
2 Me gusta
Mi caso es más práctico: cuando uso Copiar cita se conserva el código fuente LaTeX sin procesar, que es lo que necesito al reutilizar matemáticas en otros lugares. Si solo resalto y copio, normalmente solo obtengo el MathJax renderizado, no la fuente. El problema es que Copiar cita también agrega la línea de atribución con el dominio, que no quiero. Por lo tanto, la necesidad aquí es: mantener el comportamiento de preservación de LaTeX, pero sin que se agregue el enlace automático.
Un requisito importante para mí es que cualquier futura cita “consciente de la fuente” sea opcional.
Lo ideal sería una preferencia de usuario o una configuración del sitio que active o desactive si \text{Copiar cita} incluye una fuente/dominio. El formato de cita mínimo actual debe seguir siendo el predeterminado o, al menos, debe poder conservarse, ya que se utiliza para la reutilización (por ejemplo, la extracción de LaTeX sin formato en la educación).
