The Default Locale bug seems to have come back. Latest discourse, new install, I selected “Français” during the wizard setup, and got an English setup. So I went to the Admin settings and changed the default locale setting to ‘Français’ and saved… But I keep having the site in English. I tried with a new session in a private window: it’s English indeed.
Logs says:
An attempt was to change default_locale SiteSetting to fr however it is shadowed so this will be ignored!
c.f.: https://champs.lepiceriesansfin.org/logs/show/6ecaa9300a8ba60f634652f702149448
Solution
gerhard:
Please take a look at the configuration file for the Discourse Docker container (probably app.yml ) and make sure that DISCOURSE_DEFAULT_LOCALE is commented out. It should look like this:
# DISCOURSE_DEFAULT_LOCALE: en
You won’t be able to change the default_locale within Discourse when that environment variable is set.
Hmm who should this be assigned to @sam ?
sam
(Sam Saffron)
27. August 2018 um 01:19
@gerhard can you add to your list to investigate when you work on the TOS/FAQ stuff?
gerhard
(Gerhard Schlager)
5. September 2018 um 12:53
Could you please post the content of that log entry? Also, did you set DISCOURSE_DEFAULT_LOCALE in app.yml or is it still set to the default (# DISCOURSE_DEFAULT_LOCALE: en)?
Oh, that’s a bug in the wizard’s UI. Pressing Enter while selecting the locale forwards you to the next step without actually changing the locale. I’m going to fix this.
Be careful though that changing the locale through the admin interface fails as well!
gerhard
(Gerhard Schlager)
5. September 2018 um 15:24
I can’t reproduce that. Could you post the log entry please?
Are you using any non-official plugins?
Isn’t the link to the log available to you?
Yes there are some custom plugins, notably some by Angus. I’ll post the full list when I get back home…
Here is the full list:
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
- git clone https://github.com/discourse/discourse-assign.git
- git clone https://github.com/discourse/discourse-github-linkback.git
- git clone https://github.com/discourse/discourse-policy.git
- git clone https://github.com/discourse/discourse-solved.git
- git clone https://github.com/discourse/discourse-spoiler-alert.git
- git clone https://github.com/discourse/discourse-voting.git
- git clone https://github.com/angusmcleod/discourse-custom-wizard.git
- git clone https://github.com/angusmcleod/discourse-events.git
- git clone https://github.com/angusmcleod/discourse-locations.git
- git clone https://github.com/cpradio/discourse-plugin-checklist.git
- git clone https://github.com/davidtaylorhq/discourse-whos-online.git
# - git clone https://github.com/lidel/discourse-openstreetmap.git
P.S.: I just tested again from the admin interface. The locale appears to be changed, but reloading the page puts it back to English.
gerhard
(Gerhard Schlager)
5. September 2018 um 15:52
9
That link only works for admins.
Message
Backtrace
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.2.11/lib/logster/logger.rb:94:in `add_with_opts'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.2.11/lib/logster/logger.rb:51:in `add'
/usr/local/lib/ruby/2.5.0/logger.rb:536:in `warn'
/var/www/discourse/lib/site_setting_extension.rb:397:in `block in setup_shadowed_methods'
/var/www/discourse/lib/site_setting_extension.rb:347:in `set'
/var/www/discourse/lib/site_setting_extension.rb:356:in `set_and_log'
/var/www/discourse/lib/wizard/step_updater.rb:33:in `update_setting'
/var/www/discourse/lib/wizard/step_updater.rb:37:in `apply_setting'
/var/www/discourse/lib/wizard/builder.rb:28:in `block (2 levels) in build'
/var/www/discourse/lib/wizard/step_updater.rb:15:in `update'
/var/www/discourse/app/controllers/steps_controller.rb:14:in `update'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:194:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:132:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:134:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionview-5.2.0/lib/action_view/rendering.rb:32:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:191:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:252:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:840:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-protection-2.0.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/conditional_get.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/head.rb:12:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:214:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:98:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.2.11/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.5/lib/rails_multisite/middleware.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:285:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/message_bus-2.1.5/lib/message_bus/rack/middleware.rb:63:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:180:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/engine.rb:524:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `<main>'
Env
hostname ps-web
process_id 9776
application_version 07e11a223ceee1b62aaa2de18e8cf438893e9e82
HTTP_HOST champs.lepiceriesansfin.org
REQUEST_URI /wizard/steps/locale
REQUEST_METHOD PUT
HTTP_USER_AGENT Mozilla/5.0 (X11; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0
HTTP_ACCEPT */*
HTTP_REFERER https://champs.lepiceriesansfin.org/wizard/steps/locale
HTTP_X_FORWARDED_FOR 176.156.211.225, 176.156.211.225
HTTP_X_REAL_IP 176.156.211.225
username how
params null
Here is the log from my most recent attempt:
Message
Backtrace
/var/www/discourse/app/controllers/admin/site_settings_controller.rb:16:in `update'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.4/lib/rails_multisite/middleware.rb:24:in `call'
Env
hostname ps-web
process_id 3322
application_version ecf60c0c33a8bfd391f37f931f5430b0617a9cb1
REQUEST_URI /admin/site_settings/default_locale
REQUEST_METHOD PUT
HTTP_ACCEPT */*
HTTP_REFERER https://champs.lepiceriesansfin.org/admin/site_settings/category/required
HTTP_X_FORWARDED_FOR 212.239.136.241, 212.239.136.241
HTTP_X_REAL_IP 212.239.136.241
username how
params default_locale fr
gerhard
(Gerhard Schlager)
5. September 2018 um 20:01
11
Bitte werfen Sie einen Blick auf die Konfigurationsdatei für den Discourse Docker-Container (wahrscheinlich app.yml) und stellen Sie sicher, dass DISCOURSE_DEFAULT_LOCALE auskommentiert ist. Es sollte wie folgt aussehen:
Sie können die default_locale innerhalb von Discourse nicht ändern, wenn diese Umgebungsvariable gesetzt ist.
@sam Ich glaube nicht, dass dies ein Fehler ist, aber es wäre vielleicht eine gute Idee, die Änderung der default_locale in der Benutzeroberfläche (Assistent und Site-Einstellungen) zu deaktivieren, wenn sie überschattet wird. Ein Hinweis, warum sie deaktiviert ist, wäre auch großartig. Was denkst du?
sam
(Sam Saffron)
5. September 2018 um 20:19
12
Sounds right to me should be removed from the UI
Thank you so much @gerhard , your answer was point blank!
So in order to run multiple instances in different languages, DISCOURSE_DEFAULT_LOCALE must be commented out in /var/discourse/containers/app.yml, or in my case, using multiple containers: /var/discourse/containers/web.yml.
(I guess this should move to Support and be closed.)
