¿Desactivar el formato de código para una indentación de 4 espacios inapropiada?
In my community, no one should ever post code. It would always be off-topic.
However, sometimes people do have their posts formatted as code by accident.
Is it possible to disable everyone from applying the ‘code’ format to content in their post?
2 Me gusta
How do they use a code by mistake? By clicking the code button in the editor? Or simply leaving 4 spaces at the beginning of the line?
You can try to hide the code button with CSS using:
.code.btn {
    display: none;
You can also change the site setting code formatting style from the default 4-spaces-indent to code-fences. If users can leave 4 blanks spaces before a line (maybe because they use emails?) it is difficult for them to use ``` by mistake.
5 Me gusta
In my case it’s always the user’s email app adding an indent at the first line in a paragraph. Their posts by email are jumbled up as a result.
More here:
3 Me gusta
Hi @dax,
Those are great ideas - I’ve implemented both. Thank you!
I do think it is because they add four spaces to the start of a line. I wonder if this was a typing convention in some schools or something? Or it is entered via their email program? It seems to happen a couple of times a week.
That is/was the standard way to create a paragraph when writing on paper:
4 Me gusta
I doubt they insert manually 4 space. I think instead that they write the posts via email. You should be able to determine this by looking at the post itself. If you see an envelope icon the post has been submitted by email.
Or they simple copy paste the text from an another program where they use the Tab to create new paragraphs,
3 Me gusta
You would be surprised! I had hundreds of users, in a instance where reply by email was disabled, putting the four spaces because they were mimicking pen and paper standards. They also did the same when using a word processor or email.
7 Me gusta
The Thunderbird email client does it automatically for some of my users. :unamused:
3 Me gusta
Dax, he notado que incluso con esta configuración establecida como ‘code-fences’, el sistema sigue traduciendo cuatro espacios a un formato de código. ¿Existe alguna forma u opción para desactivar globalmente en un sitio el formato de código de cuatro espacios?
Lo pregunto porque un par de veces por semana un participante publica accidentalmente sus comentarios en formato de código, lo que dificulta su lectura. Creo que se debe a que esta convención todavía prevalece entre algunas personas:
3 Me gusta
No, no existe ninguna forma de hacerlo.
4 Me gusta
¡Vale!
Por favor, considera esto como una solicitud de funcionalidad.
Me pregunto qué porcentaje de los foros de Discourse necesitan bloques de código. Por lo que a mí me parece, podría tratarse de una minoría distintiva de comunidades.
3 Me gusta
