Disable map scroll by default?
Continuing the discussion from Embedding google maps short urls is broken
This is a feature request.. could we get the scrolling on embedded maps disabled by default?
A la: http://stackoverflow.com/questions/2330197/how-to-disable-mouse-scroll-wheel-scaling-with-google-maps-api
1 „Gefällt mir“
Discourse doesn’t actually consume the Google maps API. The oneboxer fiddles with the oneboxed URL until it gets something that can be successfully embedded in an <iframe>, so unless there’s an option to disable the mousewheel that can be passed via the query string, this is going to be a problem.
2 „Gefällt mir“
This seems to contain a solution for this problem:
Maybe someone will add it to the Google Maps Onebox.
6 „Gefällt mir“
Sure @techapj can you add this to the outstanding onebox issues along with short Google Maps URLs and the Flickr issue.
2 „Gefällt mir“
Fixed via:
https://github.com/discourse/onebox/pull/281
@elberet fixed short Google Maps URL issue via:
https://github.com/discourse/onebox/pull/280
6 „Gefällt mir“
