P.S. You can reply me about the functions that you think are important for academic use in discourse and whether it has been developed already or in developing.
I’d consider a highlighting plugin (or even as a core function) extremely useful for the academic context, but also for other communities where posts might be a bit longer so that highlights would be a great way of finding the most important parts of those posts. I proposed the highlighting feature in more detail here:
How about a literature database that makes it easy to include references in posts?
A few thoughts on such a literature plugin:
I guess there is no point in creating a database in discourse from scratch, given existing solutions such as zotero, mendeley, endnote and (hopefully soon) Citavi Web.
To start with, I think the focus should be on supporting zotero, since it’s free and open source (and perhaps there will never be a need to support anything else).
My idea would be that the plugin acts as an interface between a dedicated zotero database and the discourse forum.
Starting with an empty db, a user who wants to add a reference (via a button in the editor) gets the option to add a new reference (not sure if this should be done with a dedicated discourse ui or simply using the existing zotero ui, but the user should not have to leave discourse to do it)
Once there are records in the db, users can search them and paste them into their post while editing.
The citation style should probably be fixed via a site setting (cite setting )
There should be a dedicated bibliography page where all db records are listed in alphabetical order with to all the posts where the respective item is cited.
Now, the last point is where it becomes tricky: Since this type of linking is analogous to how discourse already works, the best way to achieve this might be to create a post for every reference, but I’m not sure about this, since there should only be one record for each item and that should be in zotero, I suppose.
But it would also be conceivable that the zotero database is used merely as a way of quickly insert text which would then live a life of its own, without any links, but that would defeat the purpose of making it easy to find all posts citing a specific text.
Zotero is great if you really need to build your own literature database (with all the advantages & disadvantages of this route). I originally had Zotero attached to a Wordpress/bbPress forum, but have moved away from that approach and am using this instead:
For a use case where you basically just want to assist users in providing correct litterature references, I find this a much more practical approach. Check out the demo video below, I would LOVE to see this kind of functionality available on Discourse. It would really help to open it up for academic scenarios.
Download PDF feature may support the possibility to upload the document to obtain a DOI number from, say https://zenodo.org/. My interest is to have a feature (or through a plugin) to submit and obtain DOI number to a selected or featured topics using the API available from Developers | Zenodo through a click of a button (available for the staff users).
Ciao, penso che questo post debba essere aggiornato più volte. Quindi, almeno questa lista dovrebbe poter essere modificata di nuovo da me. Ora non riesco a modificare i miei post storici.
Sto scrivendo qui e non sul wiki in alto perché non sono sufficientemente sicuro dei miei fatti.
Recentemente mi è stato chiesto di utilizzare un nuovo forum di discourse che gestisco come luogo per discutere un articolo accademico in evoluzione mentre attraversa il processo formale di revisione paritaria. Il contesto accademico in questo caso è l’analisi multidisciplinare dei sistemi energetici numerici — ma la disciplina specifica coinvolta non dovrebbe essere particolarmente rilevante. Pertanto:
Caso d’uso: utilizzo di un’istanza di discourse per discutere le modifiche in evoluzione di un articolo (in questo caso richiedendo "revisioni sostanziali"!)
Spiegazione: discourse verrà utilizzato esclusivamente per la discussione — le modifiche effettive, ovvero la preparazione del documento, avverranno altrove (ad esempio Google Docs, Overleaf, MS Teams o GitLab)
Requisiti: le discussioni devono essere completamente private per l’elenco degli autori e visibili a nessun altro (ad eccezione degli amministratori)
Una soluzione
Penso di dover prima creare un gruppo con solo i coautori, ad esempio "u4ria-goals-authors". E poi una categoria, ad esempio "U4ria goals". E bloccare quella categoria e poi renderla accessibile solo al gruppo dei coautori.
Una domanda che sorge è se posso creare una categoria "Papers" e poi una sottocategoria "U4RIA goals" e poi mappare "u4ria-goals-authors" solo a quella sottocategoria?
Chiusura
Facendo un passo indietro, forse il caso d’uso più ampio delle discussioni private dovrebbe essere sviluppato maggiormente dagli sviluppatori di discourse e dalla community di discourse — per vedere se un supporto specifico e una migliore documentazione potrebbero aiutare in questo contesto? Con i migliori saluti, R
“Video non disponibile, ma ho trovato questo video: https://youtu.be/1elUGdZ2uvY?si=RHwvlLZ51bUyV4c3 su Zotero per WordPress.\n\nLe funzionalità di Zotero potrebbero essere implementate anche per Discourse?\n\nIn particolare, Discourse può supportare la generazione di citazioni accademiche standardizzate (come APA, IEEE, ecc.) allo stesso modo in cui EndNote funziona in Word?”
