インポート/移行された投稿で Discourse-math が動作しない
I installed the plugin discourse-math and activated it from the admin panel. But, MathJax does not render the imported posts (imported from OSQA) correctly.
However, if I edit the post (just clicking on ‘edit’ and not changing a thing) and save it, the math is rendered perfectly.
Can anyone help me in rectifying this behaviour ?
Give the exact URL of the plugin you used, please?
https://github.com/discourse/discourse-math
Sounds like you need to rebake all posts.
Thanks!. I will try it and let you know here.
It worked. Thank you!
