Discourse SSO and API Helper for PHP
Installation
The package is registered at Packagist as vinkas/discourse-php and can be installed using composer:
composer require vinkas/discourse-php
Usage
$discourse = new Vinkas\Discourse\PHP\Client('discouse.example.com', true);  // set true if ssl enabled
API
$api = $discourse->api('API_KEY', 'API_USERNAME');
$api->topics()->create('TITLE', 'CONTENT', 'CATEGORY_SLUG')
SSO
$payload = $_GET['sso'];
$signature = $_GET['sig'];
$sso = $discourse->sso('SECRET', $payload, $signature);
if (!($sso->isValid())) {
    header("HTTP/1.1 403 Forbidden");
    echo("Bad SSO request");
    die();
$userParams = array(
    'external_id' => 'USER_ID',
    'email'     => 'EMAIL_ADDRESS',
    'username' => 'USERNAME',  // optional
    'name'     => 'FULL_NAME'  // optional
    // for more available fields https://meta.discourse.org/t/official-single-sign-on-for-discourse/13045
$url = $sso->getResponseUrl($userParams)
header('Location: ' . $url);
exit(0);
Since I committed in other task I didn’t tested the code well and unable to give detailed documentation with usage examples.
I will release next version soon with more options, documentation and examples.
I haven’t looked closely at this but it sounds like there might be some overlap with @michaeld’s PHP API client for Discourse:
https://github.com/communiteq/discourse-api-php
I already aware of this existing package. But I didn’t used it. I used famous GuzzleHttp (they used php native curl) and composer. Also in mine it have SSO option too.
After all I created this package because of I am also creating laravel package (which depends it) for easy implementation with laravel features like eloquent model. Yes few laravel packages also already exist for discourse. But I have something different in my mind for development :slight_smile:
Too bad you decided to create another, instead of just contributing to what already existed, and making it better.
Sorry @michaeld. Coding structure which I wanted and created is totally different from your existing package. That’s why I created it as new one.
In other words I created this package for my own purpose. Then I decided to open source it.
Для тех, кто только сейчас наткнулся на эту тему (сейчас март 2020 года… привет из домашней карантина по COVID-19!) —
Библиотека от @michaeld, упомянутая выше, судя по всему, предназначена только для работы с API. Это никак не связано с SSO.
Я пробовал использовать библиотеку от @vinothkannans, которую он поделил на Github, но, как он сам отметил выше, он не проводил достаточного тестирования. Действительно, я обнаружил, что она довольно глючная и пока не готова к использованию в продакшене.
Я нашел этот вариант, и он отлично работает у меня:
9 лайков
