أسماء النطاقات تشير إلى مثيل AWS مشترك
Hello,
I have my website (Wordpress) and Discourse forum sharing the same AWS instance with the same public ip address. The website has the domain name while Discourse forum has its subdomain. Both domain names point to the same public ip address (set in GoDaddy), my app.yml has the subdomain name for discourse forum set.
This probably isn’t the right settings because after rebuilding app both the main domain and subdomain (supposed to go to Discourse) go to my website. Discourse is no where to be seen.
Am I missing something in the setting? Can you shed some light?
How are you handling the proxying to discourse in nginx will determine if it is configured correct or not.
I see. I’m beginning to see some light…
I’m very new to nginx. Can you let me know what I can do to handle the proxying right?
I use this guide’s nginx configuration as a baseline for setting up discourse proxying right
From there, You may be able to figure out how to add server blocks to nginx to ensure it points to your wordpress as well.
Great!, thanks again @itsbhanusharma.
Just to be sure , Do I need to add a port number for Discourse in my AWS security? Currently it only has SSH and HTTP ports.
I would suggest Open 22, 80, 443 that should suffice.
I can’t seem to get Wordpress working in nginx.
Can I have both nginx and httpd running at the same time? While nginx listen to Discourse traffic and httpd listen to Wordpress site traffic.
In my setup, both, wordpress and discourse live under the same nginx happily.
If you’re technically sound, you may want to run httpd on port 81 and then internally proxy it from nginx but I wonder what performance benifit would it bring. However, what kind of issue you’re having may help you find your solution better.
That is totally doable but why do you want to add another variable in the form of httpd when nginx can happily handle both discourse and wordpress at the same time.
Totally agree on this. Have been trying to get Wordpress working in nginx for hours. It’s either my nginx.conf isn’t set right or I missed something somewhere. When access the site with the domain name, instead of loading the default homepage, it loads index.html instead. Changing some config causes it to download the content in index.php instead and nothing show on the browser. The other pages just wouldn’t load, 404 error. I suspect the system can’t recognize anything php. Do I need to install a separate php package for Wordpress to work in nginx? Did tried to install php5-fpm but AWS doesn’t has that package. If it does install, will it mess up the php package that’s already working well with httpd?
Apology for having so many questions, I guess you can tell how confused I am.
I’d suggest you follow this guide. I see that you’re on the right track but something with php isn’t working right for you.
Great, will give this a shot! Thanks again, @itsbhanusharma
Take it as a heads up warning. You DO NOT have to alter the existing discourse config in nginx in any way for wordpress to work alongside it.
Alright, thanks for the heads up, @itsbhanusharma!
Are you following one of the guides about running Discourse on a server with another web service? Run other websites on the same machine as Discourse is one. I think there’s an Nginx specific one.
I recommended that guide on another post. What he’s stuck with is unrelated to discourse atm as discourse was happily running behind nginx proxy.
The problem was with php-fpm configuration for setting up wordpress which is fairly common. That DO guide should suffice.
Decided to revisit the idea of having Wordpress website runing on httpd and Discourse running on nginx.
Tried to install php on nginx but apparently some of the packages is in conflict with existing php that works for httpd. Apparently I need to uninstall php for httpd in order to complete installation for nginx’s php. Fearing that I may mess up the existing Wordpress site and couldn’t get Wordpress sitting on nginx to work in time, I resort to this option again. The current Wordpress site is a live site.
I can extend options that work for a lot of people! .
  1. Modify apache to run on a port other than 80 & 443 then create a server block in nginx that proxies requests back to apache in a format localhost:81
  2. take a backup of your wordpress and configure nginx properly. In case you want me to look at your server, you can drop me a PM here and we can discuss about it. Discourse’s policy restricts any kind of solicitation for work and hence we have to talk about it elsewhere.
I have followed the steps here:
and considered the steps here (but didn’t follow fully):
https://meta.discourse.org/t/run-discourse-with-or-alongside-existing-apache-sites/19514
When I run /var/discourse/launcher enter app I get:
which: no docker.io in (/sbin:/bin:/usr/sbin:/usr/bin:/opt/aws/bin)
When I run service nginx restart
[root@ip-xxx.xxx.xxx.xxx ec2-user]# service nginx restart
Stopping nginx:                                            [FAILED]
Starting nginx: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] bind() to [::]:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
                                                           [FAILED]
I guess that because port 80 is taken by httpd to serve the currently running Wordpress site.
This is the config in my nginx.conf, this is likely the setting when I was trying to configure to use nginx for the Wordpress site. /var/www/phagerx/htdocs is where the Wordpress installation resides. Shall I change it to point to /var/discourse?
# For more information on configuration, see:
#   * Official English Documentation: http://nginx.org/en/docs/
#   * Official Russian Documentation: http://nginx.org/ru/docs/
user nginx;
worker_processes auto;
error_log /var/log/nginx/error.log;
pid /var/run/nginx.pid;
# Load dynamic modules. See /usr/share/doc/nginx/README.dynamic.
include /usr/share/nginx/modules/*.conf;
events {
    worker_connections 1024;
http {
    log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                      '$status $body_bytes_sent "$http_referer" '
                      '"$http_user_agent" "$http_x_forwarded_for"';
    access_log  /var/log/nginx/access.log  main;
    sendfile            on;
    tcp_nopush          on;
    tcp_nodelay         on;
    keepalive_timeout   65;
    types_hash_max_size 2048;
    include             /etc/nginx/mime.types;
    default_type        application/octet-stream;
    # Load modular configuration files from the /etc/nginx/conf.d directory.
    # See http://nginx.org/en/docs/ngx_core_module.html#include
    # for more information.
    include /etc/nginx/conf.d/*.conf;
    server {
        listen       80 default_server;
        listen       [::]:80 default_server;
        server_name  phagerx.com;
        root         /var/www/phagerx/htdocs;
	index   index.php;
        # Load configuration files for the default server block.
        include /etc/nginx/default.d/*.conf;
        location / {
        # redirect server error pages to the static page /40x.html
        error_page 404 /404.html;
            location = /40x.html {
        # redirect server error pages to the static page /50x.html
        error_page 500 502 503 504 /50x.html;
            location = /50x.html {
HIGH:SEED:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!RSAPSK:!aDH:!aECDH:!EDH-DSS-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!SRP;
    server {
        listen       80 ;
        listen       [::]:80 ;
    	server_name ask.phagerx.com; # managed by Certbot
        location / {
    listen [::]:443 ssl ipv6only=on; # managed by Certbot
    listen 443 ssl; # managed by Certbot
    ssl_certificate /etc/letsencrypt/live/ask.phagerx.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/ask.phagerx.com/privkey.pem; # managed by Certbot
    include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
This is my app.yml:
templates:
  - "templates/cron.template.yml"
  - "templates/postgres.template.yml"
  - "templates/redis.template.yml"
  - "templates/sshd.template.yml"
  - "templates/web.ratelimited.template.yml"
  - "templates/web.socketed.template.yml"
## Uncomment these two lines if you wish to add Lets Encrypt (https)
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  #- "80:80"   # http
  #- "443:443" # https
This is my discourse.conf:
server {
	listen 80; listen [::]:80;
	#listen [::]:80 ipv6only=on default_server;
	server_name ask.phagerx.com;  # <-- change this
	location / {
		proxy_pass http://unix:/var/discourse/shared/standalone/nginx.http.sock:;
		proxy_set_header Host $http_host;
		proxy_http_version 1.1;
		proxy_set_header X-Forwarded-Proto $scheme;
ask.phagerx.com is intended to be the Discourse forum and phagerx.com is the existing Wordpress site working on httpd.
Would appreciate if you can shed some light on the part that I’ve been missing. I have added a new custom port 101 in my AWS security for Discourse traffic to be routed to if necessary. But I haven’t added this new port in all my Discourse config yet.
I don’t really understand the point behind complicating things by mixing and matching different examples.
Let me try to break it down as simple as I can.
  1. Discourse won’t run well behind apache. I’ve tried it in past and it is terrible.
  2. Two webservers can’t be made to run together on same machine so No, You can not make it so that apache2 handles wordpress and nginx handles discourse.
  3. You may want to start a 2nd server in case you can’t figure out how to migrate your wordpress from apache2 to nginx
  4. You don’t have to open custom ports for discourse to work as it is talking to nginx over unix sockets by the way that you have configured it. opening more ports is of no use.
now, Coming to the solution part:
If you really love httpd (apache2) you can make it run on port 81 or any other port and then configure nginx to proxy back your wordpress domain’s requests to that port.
If you don’t care what webserver serves your wordpress and just need it to work, take a backup of wordpress, announce a downtime and remove apache & php, configure php-fpm and that should do the trick for you.
if you don’t understand what the heck I’m talking about, better choice will be to spin up a new server and move your discourse or wordpress to that.
Thanks @itsbhanusharma for a good summary.
Yes, I understand what you meant. I agree with you that having nginx to handle both Wordpress site and Discourse is the most efficient way for long term. I don’t develop a special relationship with apache2.
Avoiding a downtime for the live site is what I have been trying to do.
Let me know discuss with the company if a downtime is bearable or we will spin up a new server and I can follow the standard Discourse installation.
Your input has helped me learned a lot and I very much appreciate that. Will be in touch with you if we need your help.
