Emoji in title when disabled :)
:) are replaced by :slight_smile: even of emoji are disabled.
Example
becomes
I can also repro this on my test server.
Did this regress or did we miss it @sam?
I think its a pipeline issue.. @gerhard can you have a look at it?
Should be fixed by FIX: Don't convert :) into Emoji when emojis or emoji shurtcuts are d… · discourse/discourse@e224100 · GitHub
Emoticons like :) won’t be converted into emojis anymore unless the enable_emoji and enable_emoji_shortcuts site settings are enabled.
We had the same problem in quotes, so I fixed it there as well.
