Ошибка после установки — Discourse-doctor: антибиотики не работают
Я вижу эти ошибки — как мне найти полный лог ошибок установки и опубликовать его здесь для диагностики и, возможно, исправления?
I, [2024-02-07T04:52:47.464805 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has unmet peer dependency "@typescript-eslint/parser@^6.15.0".
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has incorrect peer dependency "typescript@^5.3.3".
warning " > @glint/environment-ember-loose@1.3.0" has unmet peer dependency "@glimmer/component@^1.1.2".
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3339 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
bootstrap failed with exit code 1
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one.
./discourse-doctor may help diagnose the problem.
3e14aea2f51d9bea24b23a8410308ed1326b59eed3442276faeb4a1acc17fa3c
Попробуйте «Доктора Discourse»:
Я пытался запустить doctor, но получаю различные ошибки, например:
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3341 exit 1>
a8290de4d358001a4a43f9a101a03713112714c6e425ff08f036f5f62d3b889a
==================== END REBUILD LOG ====================
Failed to rebuild app.
и
WARNING: ember-test-selectors: You are using an unsupported ember-cli-babel version. data-test properties are not automatically stripped from your JS code.
building...
или
111:M 07 Feb 2024 04:57:18.394 * Background saving terminated with success
Purging temp files
Bundling assets
#<Thread:0x00007f08e4ea9018 /var/www/discourse/lib/tasks/maxminddb.rake:62 run> terminated with exception (report_on_exception is true):
/var/www/discourse/lib/discourse_ip_info.rb:48:in `mmdb_download': undefined method `path' for nil:NilClass (NoMethodError)
    filename = File.basename(gz_file.path)
или
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
warning Pattern ["wrap-ansi@^7.0.0"] is trying to unpack in the same destination "/home/discourse/.cache/yarn/v6/npm-wrap-ansi-cjs-7.0.0-67e145cff510a6a6984bdf1152911d69d2eb9e43-integrity/node_modules/wrap-ansi-cjs" as pattern ["wrap-ansi-cjs@npm:wrap-ansi@^7.0.0"]. This could result in non-deterministic behavior, skipping.
warning " > discourse-markdown-it@1.0.0" has unmet peer dependency "xss@*".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > ember-router-service-refresh-polyfill@1.1.0" has incorrect peer dependency "ember-source@^3.4 || 4".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > admin > ember-source > router_js@8.0.3" has unmet peer dependency "rsvp@^4.8.5".
warning "workspace-aggregator-54e3658e-92fc-4074-9695-f148e70e1cd8 > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
Стоит упомянуть, что приложение работает, но я предпочитаю исправить эти проблемы, чтобы быть уверенным, что всё функционирует без сбоев.
Итак, Discourse Doctor перезапустил ваш старый контейнер?
Вы не привели точную ошибку, но, скорее всего, это был «exit code 137». Если так, попробуйте внести изменения, описанные в этой статье:
Предупреждения: overcommit_memory и Transparent Huge Pages. (Не совсем понятно, описывает ли этот пост именно ваш случай изменения настроек, поэтому, возможно, вам придётся поискать информацию в другом месте). Было бы интересно узнать, помогло ли это решить проблему. Если нет, можно увеличить файл подкачки (swap).
Сколько у вас оперативной памяти?
Фу — ссылка на пост с принятым решением сейчас абсолютно неверна! Правильно будет исправить эти настройки. Вместо этого посмотрите здесь, где описан один из самых свежих случаев.
Я действительно разрешил перераспределение памяти.
Моя машина — это EC2 с 2 ГБ оперативной памяти и файлом подкачки 4 ГБ
Спасибо, что обратили на это внимание! Я хотел сослаться на наше более раннее заключение, но не смог найти его на телефоне среди ночи…
Я успешно выполнил команду:
root@forum:/home/ubuntu# cat /sys/kernel/mm/transparent_hugepage/enabled always madvise [never]
Я создал службу:
sudo -s
/etc/systemd/system/disable-thp.service
[Unit]
Description=Disable Transparent Huge Pages (THP)
[Service]
Type=simple
ExecStart=/bin/sh -c 'echo never > /sys/kernel/mm/transparent_hugepage/enabled'
inserted the follow:
[Install]
WantedBy=multi-user.target`
Сохранённый файл, затем запустил службу:
sudo systemctl enable disable-thp.service
sudo systemctl start disable-thp.service
Перезагрузил машину (sudo reboot)
Теперь я попробую внести любые изменения, пересобрать приложение и отчитаюсь.
Here is the full log, since i cannot post in one body message, i have to explit it in two
root@forum:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
Ensuring launcher is up to date
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20231218-0429: Pulling from discourse/base
Digest: sha256:468f70b9bb4c6d0c6c2bbb3efc1a5e12d145eae57bdb6946b7fe5558beb52dc1
Status: Image is up to date for discourse/base:2.0.20231218-0429
docker.io/discourse/base:2.0.20231218-0429
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-02-07T09:47:28.035467 #1]  INFO -- : Reading from stdin
I, [2024-02-07T09:47:28.042109 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2024-02-07T09:47:28.079949 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-02-07T09:47:28.080639 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2024-02-07T09:47:28.084146 #1]  INFO -- :
I, [2024-02-07T09:47:28.084793 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2024-02-07T09:47:28.087691 #1]  INFO -- :
I, [2024-02-07T09:47:28.088305 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2024-02-07T09:47:28.090841 #1]  INFO -- :
I, [2024-02-07T09:47:28.091354 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2024-02-07T09:47:28.094804 #1]  INFO -- :
I, [2024-02-07T09:47:28.095396 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2024-02-07T09:47:28.098993 #1]  INFO -- :
I, [2024-02-07T09:47:28.099576 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2024/02/07 09:47:28 socat[19] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2024-02-07T09:47:28.121468 #1]  INFO -- :
I, [2024-02-07T09:47:28.121935 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2024-02-07T09:47:28.125133 #1]  INFO -- :
I, [2024-02-07T09:47:28.125586 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2024-02-07T09:47:28.128594 #1]  INFO -- :
I, [2024-02-07T09:47:28.129009 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-02-07T09:47:28.131459 #1]  INFO -- :
I, [2024-02-07T09:47:28.132081 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-02-07T09:47:28.134362 #1]  INFO -- :
I, [2024-02-07T09:47:28.139443 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-02-07T09:47:28.144552 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-02-07T09:47:28.149732 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-02-07T09:47:28.154622 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-02-07T09:47:28.155246 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2024-02-07T09:47:30.751125 #1]  INFO -- :
I, [2024-02-07T09:47:30.751953 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2024-02-07T09:47:30.754323 #1]  INFO -- :
I, [2024-02-07T09:47:30.754740 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2024-02-07T09:47:30.778074 #1]  INFO -- :
I, [2024-02-07T09:47:30.778847 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2024-02-07T09:47:30.781642 #1]  INFO -- :
I, [2024-02-07T09:47:30.782206 #1]  INFO -- : > /root/upgrade_postgres
I, [2024-02-07T09:47:30.787657 #1]  INFO -- :
I, [2024-02-07T09:47:30.788218 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2024-02-07T09:47:30.790362 #1]  INFO -- :
I, [2024-02-07T09:47:30.791615 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.792496 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.793083 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.793938 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.799721 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.801028 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.801771 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2024-02-07T09:47:30.808467 #1]  INFO -- :
I, [2024-02-07T09:47:30.809189 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.811070 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.812115 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-07T09:47:30.814049 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-07T09:47:30.814619 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-07T09:47:30.815142 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-07T09:47:30.815937 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-02-07T09:47:30.817772 #1]  INFO -- : > sleep 5
2024-02-07 09:47:30.880 UTC [42] LOG:  starting PostgreSQL 13.13 (Debian 13.13-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-02-07 09:47:30.881 UTC [42] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-02-07 09:47:30.881 UTC [42] LOG:  listening on IPv6 address "::", port 5432
2024-02-07 09:47:30.889 UTC [42] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-02-07 09:47:30.898 UTC [45] LOG:  database system was shut down at 2024-02-07 09:47:17 UTC
2024-02-07 09:47:30.906 UTC [42] LOG:  database system is ready to accept connections
I, [2024-02-07T09:47:35.821930 #1]  INFO -- :
I, [2024-02-07T09:47:35.822141 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2024-02-07 09:47:35.897 UTC [55] postgres@postgres ERROR:  database "discourse" already exists
2024-02-07 09:47:35.897 UTC [55] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2024-02-07T09:47:35.900564 #1]  INFO -- :
I, [2024-02-07T09:47:35.901065 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2024-02-07 09:47:35.980 UTC [59] postgres@discourse ERROR:  role "discourse" already exists
2024-02-07 09:47:35.980 UTC [59] postgres@discourse STATEMENT:  create user discourse;
I, [2024-02-07T09:47:35.983378 #1]  INFO -- :
I, [2024-02-07T09:47:35.983867 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2024-02-07T09:47:36.041879 #1]  INFO -- : GRANT
I, [2024-02-07T09:47:36.042564 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2024-02-07T09:47:36.101153 #1]  INFO -- : ALTER SCHEMA
I, [2024-02-07T09:47:36.101850 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2024-02-07T09:47:36.168551 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.169099 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2024-02-07T09:47:36.225091 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.225656 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists vector;"'
NOTICE:  extension "vector" already exists, skipping
I, [2024-02-07T09:47:36.282090 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.282643 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2024-02-07T09:47:36.340426 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.340963 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2024-02-07T09:47:36.397482 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.398028 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists vector;"'
I, [2024-02-07T09:47:36.455492 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-07T09:47:36.456161 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2024-02-07T09:47:36.464961 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2024-02-07T09:47:36.566296 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-02-07T09:47:36.569940 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-02-07T09:47:36.570518 #1]  INFO -- : > echo postgres installed!
I, [2024-02-07T09:47:36.573234 #1]  INFO -- : postgres installed!
I, [2024-02-07T09:47:36.579028 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-02-07T09:47:36.584300 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-02-07T09:47:36.589237 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-02-07T09:47:36.591553 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.592681 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.593494 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-02-07T09:47:36.596887 #1]  INFO -- :
I, [2024-02-07T09:47:36.597723 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.598600 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.600144 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.601562 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.602979 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-02-07T09:47:36.604383 #1]  INFO -- : > echo redis installed
I, [2024-02-07T09:47:36.607125 #1]  INFO -- : redis installed
I, [2024-02-07T09:47:36.607787 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-02-07T09:47:36.612950 #1]  INFO -- : logfile ""
I, [2024-02-07T09:47:36.613545 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-02-07T09:47:36.615296 #1]  INFO -- : > sleep 10
111:C 07 Feb 2024 09:47:36.630 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
111:C 07 Feb 2024 09:47:36.630 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=111, just started
111:C 07 Feb 2024 09:47:36.630 # Configuration loaded
111:M 07 Feb 2024 09:47:36.631 * monotonic clock: POSIX clock_gettime
111:M 07 Feb 2024 09:47:36.632 * Running mode=standalone, port=6379.
111:M 07 Feb 2024 09:47:36.632 # Server initialized
111:M 07 Feb 2024 09:47:36.633 # WARNING Your system is configured to use the 'xen' clocksource which might lead to degraded performance. Check the result of the [slow-clocksource] system check: run 'redis-server --check-system' to check if the system's clocksource isn't degrading performance.
111:M 07 Feb 2024 09:47:36.633 * Loading RDB produced by version 7.0.7
111:M 07 Feb 2024 09:47:36.634 * RDB age 20 seconds
111:M 07 Feb 2024 09:47:36.634 * RDB memory usage when created 13.66 Mb
111:M 07 Feb 2024 09:47:36.655 * Done loading RDB, keys loaded: 404, keys expired: 2.
111:M 07 Feb 2024 09:47:36.656 * DB loaded from disk: 0.022 seconds
111:M 07 Feb 2024 09:47:36.656 * Ready to accept connections
I, [2024-02-07T09:47:46.619646 #1]  INFO -- :
I, [2024-02-07T09:47:46.620451 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-02-07T09:47:46.625010 #1]  INFO -- : thpoff is installed!
I, [2024-02-07T09:47:46.625638 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-02-07T09:47:46.706869 #1]  INFO -- :
I, [2024-02-07T09:47:46.707567 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-02-07T09:47:46.788356 #1]  INFO -- :
I, [2024-02-07T09:47:46.789065 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-02-07T09:47:46.869768 #1]  INFO -- :
I, [2024-02-07T09:47:46.870447 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-02-07T09:47:46.873269 #1]  INFO -- :
I, [2024-02-07T09:47:46.876471 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-02-07T09:47:46.881434 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-02-07T09:47:46.886402 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-02-07T09:47:46.891375 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-02-07T09:47:46.896366 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-02-07T09:47:46.901193 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-02-07T09:47:46.901633 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2024-02-07T09:47:46.902195 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-02-07T09:47:46.904582 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
138:C 07 Feb 2024 09:47:46.917 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
138:C 07 Feb 2024 09:47:46.917 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=138, just started
138:C 07 Feb 2024 09:47:46.917 # Configuration loaded
138:M 07 Feb 2024 09:47:46.918 * monotonic clock: POSIX clock_gettime
138:M 07 Feb 2024 09:47:46.919 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
138:M 07 Feb 2024 09:47:46.919 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (33715/33715), done.
I, [2024-02-07T09:47:52.123695 #1]  INFO -- : HEAD is now at 6ab1a19e9 DEV: Convert min_trust_level_to_allow_invite to groups (#24893)
I, [2024-02-07T09:47:52.124327 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-02-07T09:47:52.276708 #1]  INFO -- :
I, [2024-02-07T09:47:52.277312 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/0-drop-code
 - [deleted]             (none)     -> origin/bulk-button-class
 - [deleted]             (none)     -> origin/dependabot/bundler/excon-0.108.0
 - [deleted]             (none)     -> origin/dependabot/bundler/hashdiff-1.1.0
 - [deleted]             (none)     -> origin/dependabot/bundler/parallel-1.24.0
 - [deleted]             (none)     -> origin/dependabot/bundler/rubocop-discourse-3.6.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/drop-target-2.0.2
 - [deleted]             (none)     -> origin/dev/add-new-chat-metrics
 - [deleted]             (none)     -> origin/dev/allow-chat-mentions-to-have-several-notifications
 - [deleted]             (none)     -> origin/dev/convert-min-trust-level-to-create-tag-to-group
 - [deleted]             (none)     -> origin/dev/convert-min-trust-level-to-ignore-to-groups
 - [deleted]             (none)     -> origin/dev/rethink-mass-mentions-polymorphic
 - [deleted]             (none)     -> origin/feature/migrations-schema-generator
 - [deleted]             (none)     -> origin/fix-join-filter-upload
 - [deleted]             (none)     -> origin/fix-modal-flash-minor
 - [deleted]             (none)     -> origin/global-notice-reactive
 - [deleted]             (none)     -> origin/labeler
 - [deleted]             (none)     -> origin/low-ram-help
 - [deleted]             (none)     -> origin/multi-invite
 - [deleted]             (none)     -> origin/plugin-extra-js
 - [deleted]             (none)     -> origin/table-builder-modal-modifier
 - [deleted]             (none)     -> origin/wip_categories
 - [deleted]             (none)     -> origin/wizard-split
   6ab1a19e9..dea753a20  main                    -> origin/main
 * [new branch]          0-ember-bump            -> origin/0-ember-bump
 * [new branch]          0-event-helper          -> origin/0-event-helper
 * [new branch]          0-extend-native         -> origin/0-extend-native
 * [new branch]          0-rev                   -> origin/0-rev
 * [new branch]          add-api-for-forced-auth -> origin/add-api-for-forced-auth
 * [new branch]          api-image-wrapper       -> origin/api-image-wrapper
 * [new branch]          asciinema-iframe        -> origin/asciinema-iframe
 * [new branch]          bulk-select-dropdown-items -> origin/bulk-select-dropdown-items
 * [new branch]          chat-channel-settings-padding-fix -> origin/chat-channel-settings-padding-fix
 * [new branch]          convert-header-to-glimmer -> origin/convert-header-to-glimmer
 * [new branch]          decorator-transforms    -> origin/decorator-transforms
 * [new branch]          dependabot/bundler/omniauth-2.0.0 -> origin/dependabot/bundler/omniauth-2.0.0
 * [new branch]          dependabot/bundler/parallel_tests-4.4.0 -> origin/dependabot/bundler/parallel_tests-4.4.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/content-tag-2.0.1 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/content-tag-2.0.1
 * [new branch]          dev-convert-topic-map-expanded-widget-to-component -> origin/dev-convert-topic-map-expanded-widget-to-component
 * [new branch]          dev/check-whether-online-user-ids-may-be-memoized-between-job-runs -> origin/dev/check-whether-online-user-ids-may-be-memoized-between-job-runs
 * [new branch]          dev/drop-the-user-id-column-from-chat-mentions -> origin/dev/drop-the-user-id-column-from-chat-mentions
 + e0c0191bb...cf69dac7c dev/dry-up-user-status-serializers -> origin/dev/dry-up-user-status-serializers  (forced update)
 * [new branch]          dev/experiment-theme-settings-free-ui -> origin/dev/experiment-theme-settings-free-ui
 * [new branch]          dev/make-admins-tl4-in-tests -> origin/dev/make-admins-tl4-in-tests
 * [new branch]          dev/move-more-client-settings-group -> origin/dev/move-more-client-settings-group
 * [new branch]          dev/promote-plugin-post-deploy-migrations -> origin/dev/promote-plugin-post-deploy-migrations
 * [new branch]          dev/proof-of-concept-rewriting-mentions-notification-logic -> origin/dev/proof-of-concept-rewriting-mentions-notification-logic
 * [new branch]          dev_category_order_database -> origin/dev_category_order_database
 * [new branch]          dev_update_category_position -> origin/dev_update_category_position
 * [new branch]          extra-js-revert         -> origin/extra-js-revert
 * [new branch]          fast-edit-expand-regex  -> origin/fast-edit-expand-regex
 * [new branch]          feature/custom-date-range -> origin/feature/custom-date-range
 * [new branch]          feature/paste-upload-on-first-upload-input-templates -> origin/feature/paste-upload-on-first-upload-input-templates
 * [new branch]          feature_async_hashtags  -> origin/feature_async_hashtags
 * [new branch]          feature_async_load_colors -> origin/feature_async_load_colors
 * [new branch]          fix-email-category-badge -> origin/fix-email-category-badge
 * [new branch]          fix_category_chooser    -> origin/fix_category_chooser
 * [new branch]          fix_in_any_groups       -> origin/fix_in_any_groups
 * [new branch]          fix_reviewable_translation -> origin/fix_reviewable_translation
   7f2bdca65..4f57be1a8  generic-import-latest   -> origin/generic-import-latest
 * [new branch]          hijacks                 -> origin/hijacks
 * [new branch]          issue/run-admin-sidebar-init-after-logs-notice -> origin/issue/run-admin-sidebar-init-after-logs-notice
 * [new branch]          loic-rubocop-plugin-rules -> origin/loic-rubocop-plugin-rules
 + 90a3535b7...e6e64cfd5 migrations-convert      -> origin/migrations-convert  (forced update)
 * [new branch]          promote-migration-tweak -> origin/promote-migration-tweak
 * [new branch]          redesign-my-threads-index -> origin/redesign-my-threads-index
 * [new branch]          revert-25009-dev/convert-min-trust-to-allow-self-wiki-to-groups -> origin/revert-25009-dev/convert-min-trust-to-allow-self-wiki-to-groups
 * [new branch]          revert-bulk-topic-actions -> origin/revert-bulk-topic-actions
 * [new branch]          sidebar-above-outlet    -> origin/sidebar-above-outlet
 * [new branch]          site-logo-height        -> origin/site-logo-height
 * [new branch]          sort-chat-channels-by-activity -> origin/sort-chat-channels-by-activity
   d7f7f79b6..124aa9ac9  stable                  -> origin/stable
 * [new branch]          support-reset-bump-date-post-id -> origin/support-reset-bump-date-post-id
 * [new branch]          system-test-for-soft-load-search -> origin/system-test-for-soft-load-search
   6ab1a19e9..32ee0e3c0  tests-passed            -> origin/tests-passed
 * [new branch]          unhide_lazy_load_categories -> origin/unhide_lazy_load_categories
 * [new branch]          universal-nonce         -> origin/universal-nonce
 * [new branch]          virtual-scroll-list     -> origin/virtual-scroll-list
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.1.4                  -> v3.1.4
 * [new tag]             v3.1.5                  -> v3.1.5
 * [new tag]             v3.2.0                  -> v3.2.0
 * [new tag]             v3.2.0.beta4            -> v3.2.0.beta4
 * [new tag]             v3.2.0.beta5            -> v3.2.0.beta5
I, [2024-02-07T09:47:53.573291 #1]  INFO -- :
I, [2024-02-07T09:47:53.573724 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-02-07T09:47:59.166238 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2024-02-07T09:47:59.166787 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-02-07T09:47:59.178706 #1]  INFO -- :
I, [2024-02-07T09:47:59.179296 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-02-07T09:47:59.183038 #1]  INFO -- :
I, [2024-02-07T09:47:59.183411 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-02-07T09:47:59.186620 #1]  INFO -- :
I, [2024-02-07T09:47:59.186984 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-02-07T09:47:59.190393 #1]  INFO -- :
I, [2024-02-07T09:47:59.190793 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-02-07T09:47:59.194202 #1]  INFO -- :
I, [2024-02-07T09:47:59.194567 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-02-07T09:47:59.198137 #1]  INFO -- :
I, [2024-02-07T09:47:59.198505 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-02-07T09:47:59.201926 #1]  INFO -- :
I, [2024-02-07T09:47:59.202293 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-02-07T09:47:59.207056 #1]  INFO -- :
I, [2024-02-07T09:47:59.207444 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-02-07T09:47:59.212501 #1]  INFO -- :
I, [2024-02-07T09:47:59.212922 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-02-07T09:47:59.218073 #1]  INFO -- :
I, [2024-02-07T09:47:59.218463 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-02-07T09:47:59.223175 #1]  INFO -- :
I, [2024-02-07T09:47:59.223559 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-02-07T09:47:59.228838 #1]  INFO -- :
I, [2024-02-07T09:47:59.229262 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-02-07T09:47:59.234110 #1]  INFO -- :
I, [2024-02-07T09:47:59.234553 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-02-07T09:47:59.240488 #1]  INFO -- :
I, [2024-02-07T09:47:59.240915 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-02-07T09:47:59.243068 #1]  INFO -- :
I, [2024-02-07T09:47:59.243549 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-02-07T09:47:59.244199 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-02-07T09:48:01.088471 #1]  INFO -- :
I, [2024-02-07T09:48:01.089265 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-02-07T09:48:01.093400 #1]  INFO -- :
I, [2024-02-07T09:48:01.094048 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-02-07T09:48:01.096633 #1]  INFO -- :
I, [2024-02-07T09:48:01.097180 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2024-02-07T09:48:01.100107 #1]  INFO -- :
I, [2024-02-07T09:48:01.101211 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-02-07T09:48:01.101849 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2024-02-07T09:48:01.102439 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-02-07T09:48:01.103117 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2024-02-07T09:48:01.104031 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2024-02-07T09:48:01.104574 #1]  INFO -- : > echo "done configuring web"
I, [2024-02-07T09:48:01.106926 #1]  INFO -- : done configuring web
I, [2024-02-07T09:48:01.107482 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-02-07T09:48:02.049424 #1]  INFO -- : Successfully installed bundler-2.5.3
1 gem installed
I, [2024-02-07T09:48:02.050149 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-02-07T09:48:10.650184 #1]  INFO -- :
I, [2024-02-07T09:48:10.650996 #1]  INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
  rm -rf app/assets/javascripts/node_modules
fi
I, [2024-02-07T09:48:10.653470 #1]  INFO -- :
I, [2024-02-07T09:48:10.653922 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > ember-router-service-refresh-polyfill@1.1.0" has incorrect peer dependency "ember-source@^3.4 || 4".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > admin > ember-source > router_js@8.0.3" has unmet peer dependency "rsvp@^4.8.5".
warning "workspace-aggregator-f2ec9be1-c81a-470b-8067-7b5d946fb3af > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
I, [2024-02-07T09:50:54.046212 #1]  INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
$ yarn --cwd app/assets/javascripts $(node -e 'const argv = JSON.parse(process.env.npm_config_argv).original; const passthrough = [`--frozen-lockfile`, `-s`].filter(arg => argv.includes(arg)); console.log(passthrough.join(` `));')
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
[4/4] Building fresh packages...
$ ./run-patch-package
patch-package 8.0.0
Applying patches...
@ember/test-helpers@2.9.4 ✔
babel-plugin-debug-macros@0.3.4 ✔
content-tag@2.0.1 ✔
ember-cli@5.0.0 ✔
ember-this-fallback@0.4.0 (1 deprecation-name) ✔
ember-this-fallback@0.4.0 (2 themes) ✔
ember-this-fallback@0.4.0 (3 exclude-strict-mode) ✔
virtual-dom@2.1.1 ✔
Done in 77.54s.
Done in 149.09s.
yarn cache v1.22.19
success Cleared cache.
Done in 13.34s.
I, [2024-02-07T09:50:54.077938 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local deployment true'
I, [2024-02-07T09:50:54.480628 #1]  INFO -- :
I, [2024-02-07T09:50:54.481198 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local without "development test"'
I, [2024-02-07T09:50:54.683215 #1]  INFO -- : You are replacing the current local value of without, which is currently "test:development"
I, [2024-02-07T09:50:54.683835 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --retry 3 --jobs 4'
I, [2024-02-07T09:51:36.676718 #1]  INFO -- : Fetching gem metadata from https://rubygems.org/.........
Fetching concurrent-ruby 1.2.3
Fetching minitest 5.22.0
Fetching bigdecimal 3.1.6
Fetching cbor 0.5.9.8
Installing bigdecimal 3.1.6 with native extensions
Installing minitest 5.22.0
Installing cbor 0.5.9.8 with native extensions
Installing concurrent-ruby 1.2.3
Fetching excon 0.109.0
Installing excon 0.109.0
Fetching fastimage 2.3.0
Installing fastimage 2.3.0
Fetching google-protobuf 3.25.2 (x86_64-linux)
Fetching highline 3.0.1
Installing highline 3.0.1
Fetching image_size 3.4.0
Installing google-protobuf 3.25.2 (x86_64-linux)
Installing image_size 3.4.0
Fetching regexp_parser 2.9.0
Installing regexp_parser 2.9.0
Fetching zeitwerk 2.6.13
Installing zeitwerk 2.6.13
Fetching logster 2.16.0
Fetching stackprof 0.2.26
Installing stackprof 0.2.26 with native extensions
Installing logster 2.16.0
Fetching nokogiri 1.16.2 (x86_64-linux)
Installing nokogiri 1.16.2 (x86_64-linux)
Fetching rack-protection 3.2.0
Installing rack-protection 3.2.0
Fetching bootsnap 1.18.3
Installing bootsnap 1.18.3 with native extensions
Fetching net-http 0.4.1
Installing net-http 0.4.1
Fetching sass-embedded 1.70.0 (x86_64-linux-gnu)
Fetching puma 6.4.2
Installing puma 6.4.2 with native extensions
Installing sass-embedded 1.70.0 (x86_64-linux-gnu)
Fetching rbtrace 0.5.1
Installing rbtrace 0.5.1 with native extensions
Fetching net-imap 0.4.10
Installing net-imap 0.4.10
Fetching net-smtp 0.4.0.1
Installing net-smtp 0.4.0.1
Fetching faraday-net_http 3.1.0
Installing faraday-net_http 3.1.0
Fetching activesupport 7.0.8
Installing activesupport 7.0.8
Fetching tzinfo-data 1.2024.1
Installing tzinfo-data 1.2024.1
Fetching sassc-embedded 1.70.0
Installing sassc-embedded 1.70.0
Fetching faraday 2.9.0
Installing faraday 2.9.0
Fetching activemodel 7.0.8
Installing activemodel 7.0.8
Fetching actionview 7.0.8
Installing actionview 7.0.8
Fetching activejob 7.0.8
Installing activejob 7.0.8
Fetching activerecord 7.0.8
Installing activerecord 7.0.8
Fetching actionpack 7.0.8
Installing actionpack 7.0.8
Fetching actionmailer 7.0.8
Installing actionmailer 7.0.8
Fetching railties 7.0.8
Installing railties 7.0.8
Bundle complete! 138 Gemfile dependencies, 170 gems now installed.
Gems in the groups 'development' and 'test' were not installed.
Bundled gems are installed into `./vendor/bundle`
I, [2024-02-07T09:51:36.678489 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2024-02-07T09:51:41.396361 #1]  INFO -- : docker_manager is already at latest compatible version
I, [2024-02-07T09:51:41.398224 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2024-02-07T09:51:49.180668 #1]  INFO -- :
I, [2024-02-07T09:51:49.181432 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
Node.js heap_size_limit (1002.25) is less than 2048MB. Setting --max-old-space-size=2048.
111:M 07 Feb 2024 09:52:37.070 * 100 changes in 300 seconds. Saving...
111:M 07 Feb 2024 09:52:37.078 * Background saving started by pid 3430
3430:C 07 Feb 2024 09:52:37.268 * DB saved on disk
3430:C 07 Feb 2024 09:52:37.269 * Fork CoW for RDB: current 1 MB, peak 1 MB, average 1 MB
111:M 07 Feb 2024 09:52:37.279 * Background saving terminated with success
Purging temp files
Bundling assets
#<Thread:0x00007f10b85813d8 /var/www/discourse/lib/tasks/maxminddb.rake:62 run> terminated with exception (report_on_exception is true):
        from /var/www/discourse/lib/tasks/maxminddb.rake:67:in `block (3 levels) in <main>'
        from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `each'
        from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `block (2 levels) in <main>'
I, [2024-02-07T09:56:57.163180 #3444]  INFO -- : Writing /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js
I, [2024-02-07T09:56:57.173780 #3444]  INFO -- : Writing /var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js
I, [2024-02-07T09:56:57.178601 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js
I, [2024-02-07T09:56:57.182475 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js
I, [2024-02-07T09:56:57.922268 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js
I, [2024-02-07T09:56:58.142354 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js
I, [2024-02-07T09:56:58.485685 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js
I, [2024-02-07T09:56:58.751145 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js
I, [2024-02-07T09:56:58.988759 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js
I, [2024-02-07T09:56:59.267080 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js
I, [2024-02-07T09:56:59.518029 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js
I, [2024-02-07T09:56:59.905207 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js
I, [2024-02-07T09:57:00.285336 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js
I, [2024-02-07T09:57:00.464802 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js
I, [2024-02-07T09:57:00.653950 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js
I, [2024-02-07T09:57:00.933879 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js
I, [2024-02-07T09:57:01.165769 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js
I, [2024-02-07T09:57:01.446016 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js
I, [2024-02-07T09:57:01.714231 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js
I, [2024-02-07T09:57:01.983926 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js
I, [2024-02-07T09:57:02.231200 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js
I, [2024-02-07T09:57:02.569657 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js
I, [2024-02-07T09:57:02.818672 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js
I, [2024-02-07T09:57:03.084146 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js
I, [2024-02-07T09:57:03.352798 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js
I, [2024-02-07T09:57:03.579685 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js
I, [2024-02-07T09:57:03.839930 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js
I, [2024-02-07T09:57:04.111361 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js
I, [2024-02-07T09:57:04.490944 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js
I, [2024-02-07T09:57:04.726476 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js
I, [2024-02-07T09:57:04.967437 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js
I, [2024-02-07T09:57:05.210753 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js
I, [2024-02-07T09:57:05.473690 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js
I, [2024-02-07T09:57:05.756780 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js
I, [2024-02-07T09:57:06.003191 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js
I, [2024-02-07T09:57:06.261175 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js
I, [2024-02-07T09:57:06.505804 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js
I, [2024-02-07T09:57:06.845501 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js
I, [2024-02-07T09:57:07.071806 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js
I, [2024-02-07T09:57:07.320534 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js
I, [2024-02-07T09:57:07.556332 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js
I, [2024-02-07T09:57:07.779575 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js
I, [2024-02-07T09:57:08.041938 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js
I, [2024-02-07T09:57:08.269410 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js
I, [2024-02-07T09:57:08.608550 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js
I, [2024-02-07T09:57:08.935619 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js
I, [2024-02-07T09:57:09.192326 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js
I, [2024-02-07T09:57:09.526333 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js
I, [2024-02-07T09:57:09.792019 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js
I, [2024-02-07T09:57:10.147565 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js
I, [2024-02-07T09:57:10.485426 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js
I, [2024-02-07T09:57:10.736941 #3444]  INFO -- : Writing /var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js
I, [2024-02-07T09:57:10.743579 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js
I, [2024-02-07T09:57:10.750228 #3444]  INFO -- : Writing /var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js
I, [2024-02-07T09:57:10.751078 #3444]  INFO -- : Writing /var/www/discourse/public/assets/activate-account-3523016e5574f9a525ef6290fb8f4b48a26c4ce347b9abd5544100d6195d9c8c.map
I, [2024-02-07T09:57:10.967317 #3444]  INFO -- : Writing /var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js
I, [2024-02-07T09:57:10.969151 #3444]  INFO -- : Writing /var/www/discourse/public/assets/admin-65e72d00354d5ad1527c564f7025df2c0c36e843a877a6e6540ec071d92ee9da.map
I, [2024-02-07T09:57:10.981073 #3444]  INFO -- : Writing /var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js
I, [2024-02-07T09:57:10.982073 #3444]  INFO -- : Writing /var/www/discourse/public/assets/auto-redirect-783f6a24df430663e548fd3e8f2e37eee3a45923367ff44f6fbd7f6b9e0c3f68.map
I, [2024-02-07T09:57:10.988716 #3444]  INFO -- : Writing /var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js
I, [2024-02-07T09:57:10.989508 #3444]  INFO -- : Writing /var/www/discourse/public/assets/browser-detect-d6593973a5e2ecaffb3cfe4e95c12f3a269ea4b4a7e92490d159a5bd841ec570.map
I, [2024-02-07T09:57:10.995713 #3444]  INFO -- : Writing /var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js
I, [2024-02-07T09:57:10.996589 #3444]  INFO -- : Writing /var/www/discourse/public/assets/browser-update-ccac2124107451f99d1f542cf7d67a32435a9d933c8243f0579039f2cd52dc8f.map
I, [2024-02-07T09:57:11.951653 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js
I, [2024-02-07T09:57:11.958144 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js.LICENSE.txt
I, [2024-02-07T09:57:11.959085 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js.map
I, [2024-02-07T09:57:11.990961 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js
I, [2024-02-07T09:57:11.992098 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js.map
I, [2024-02-07T09:57:11.997018 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js
I, [2024-02-07T09:57:12.008392 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js
I, [2024-02-07T09:57:12.009416 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js.map
I, [2024-02-07T09:57:12.048364 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js
I, [2024-02-07T09:57:12.049498 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js.map
I, [2024-02-07T09:57:12.056056 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.89013733dad766244082.css
I, [2024-02-07T09:57:12.059151 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.89013733dad766244082.css.map
I, [2024-02-07T09:57:12.065850 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js
I, [2024-02-07T09:57:12.066755 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js.map
I, [2024-02-07T09:57:12.082214 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js
I, [2024-02-07T09:57:12.083291 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js.map
I, [2024-02-07T09:57:12.191292 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js
I, [2024-02-07T09:57:12.192659 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js.map
I, [2024-02-07T09:57:12.209804 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.9ebd5cbc071c2d3f5cf7.css
I, [2024-02-07T09:57:12.213942 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.9ebd5cbc071c2d3f5cf7.css.map
I, [2024-02-07T09:57:12.230199 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js
I, [2024-02-07T09:57:12.231366 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js.map
I, [2024-02-07T09:57:12.241829 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js
I, [2024-02-07T09:57:12.242841 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js.map
I, [2024-02-07T09:57:12.250112 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js
I, [2024-02-07T09:57:12.250961 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js.map
I, [2024-02-07T09:57:12.258351 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js
I, [2024-02-07T09:57:12.259326 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js.map
I, [2024-02-07T09:57:12.265456 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js
I, [2024-02-07T09:57:12.266406 #3444]  INFO -- : Writing /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js.map
I, [2024-02-07T09:57:12.270036 #3444]  INFO -- : Writing /var/www/discourse/public/assets/discourse-07daaccc3e754332f981cc6510086e28c41cda9589ac33e33c8a96597fccb083.css
I, [2024-02-07T09:57:12.273597 #3444]  INFO -- : Writing /var/www/discourse/public/assets/discourse.d41d8cd98f00b204e9800998ecf8427e-e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855.css
I, [2024-02-07T09:57:12.280029 #3444]  INFO -- : Writing /var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js
I, [2024-02-07T09:57:12.281016 #3444]  INFO -- : Writing /var/www/discourse/public/assets/embed-application-00e08d311d3285925aeed70aa17bb9b979372a54980d2c65d4ca76e61fb5707b.map
I, [2024-02-07T09:57:12.287567 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js
I, [2024-02-07T09:57:12.288498 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-tag-manager-28fec92fc63ed5152565c43f5342c098a1f3f3e9def1124373a0481b4abd4cab.map
I, [2024-02-07T09:57:12.299830 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js
I, [2024-02-07T09:57:12.300855 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-universal-analytics-v3-0bd4423881936fcc413adb3fea0296c8dfa09ce3b774cbe1369b094d10d5f94d.map
I, [2024-02-07T09:57:12.306805 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js
I, [2024-02-07T09:57:12.307680 #3444]  INFO -- : Writing /var/www/discourse/public/assets/google-universal-analytics-v4-fd5a48f039d353888be5f587b5d59fcc2a9468e578468f4832e4bc84675d294a.map
I, [2024-02-07T09:57:12.313773 #3444]  INFO -- : Writing /var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js
I, [2024-02-07T09:57:12.314662 #3444]  INFO -- : Writing /var/www/discourse/public/assets/onpopstate-handler-aa17feb9a185b68dbd42e87bac3109bc26045effbc9f848929392b102d8ae0ae.map
I, [2024-02-07T09:57:12.473958 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js
I, [2024-02-07T09:57:12.475720 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/chat-d085afe6491c005413edbd82be60ec128e23e8aa22a4d5be91b74ae371663e5a.map
I, [2024-02-07T09:57:12.487376 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js
I, [2024-02-07T09:57:12.488387 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/checklist-d313dfa20c113a70f9a6a7356c86fdfad5996e2570302f9667c2ee2b5aed831d.map
I, [2024-02-07T09:57:12.494311 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js
I, [2024-02-07T09:57:12.495135 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-details-dc285aa1ef01d7a4bb93ca99bdc9cdc0ff4c05ce78dd0fa7e7198da0b066ede5.map
I, [2024-02-07T09:57:12.502222 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js
I, [2024-02-07T09:57:12.503123 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-lazy-videos-6832d6205141068be6c94993f8a6948a13bcf4d05bbb293f5fc2af59cc0cc172.map
I, [2024-02-07T09:57:12.515043 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js
I, [2024-02-07T09:57:12.516112 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-local-dates-c18813e741a7747622a6873b7f1de8b6c45f1533a603a24f2a018cd443fdc1f3.map
I, [2024-02-07T09:57:12.522278 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js
I, [2024-02-07T09:57:12.523101 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-narrative-bot-00cdd3eabafea37d524a9c9a3c1c1e727ee729f3c5b25a1ae0e43ad85b451ffd.map
I, [2024-02-07T09:57:12.530828 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js
I, [2024-02-07T09:57:12.531846 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-presence-e6e61f80036635f57d4b1319cf027210a0797d7c8af514273f941ad05d4366d0.map
I, [2024-02-07T09:57:12.543679 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js
I, [2024-02-07T09:57:12.544823 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/docker_manager_admin-1be63b922753aa8c941b2285d74440bcacf3ac1f8b38aed1b1f955d58c493070.map
I, [2024-02-07T09:57:12.551032 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js
I, [2024-02-07T09:57:12.551948 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/footnote-38ad4ddd96d53000e5606fa3bb10d539d237aa5d1367b32cfe2e7cf976c8b0a1.map
I, [2024-02-07T09:57:12.568343 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js
I, [2024-02-07T09:57:12.569433 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/poll-c38b44a06d721be7511061eda1e987daeb63ec660b3cd1585df7e20f0c5e035c.map
I, [2024-02-07T09:57:12.576083 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js
I, [2024-02-07T09:57:12.576972 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/spoiler-alert-c117d91598beb6e547891e4e9fb9c1d814ecb4547858e57c0f253e10f8ca0521.map
I, [2024-02-07T09:57:12.616918 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js
I, [2024-02-07T09:57:12.619886 #3444]  INFO -- : Writing /var/www/discourse/public/assets/plugins/styleguide-101ca23730c843d08fad554bf102779c495ce88eb84ac5536f8f1b092f843e14.map
I, [2024-02-07T09:57:12.636512 #3444]  INFO -- : Writing /var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js
I, [2024-02-07T09:57:12.637551 #3444]  INFO -- : Writing /var/www/discourse/public/assets/print-page-b9a8366d333fa5ef54d14b5cfa40885b3aea3c8d49f7d332ccf7a42a250cdbba.map
I, [2024-02-07T09:57:12.662672 #3444]  INFO -- : Writing /var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js
I, [2024-02-07T09:57:12.663722 #3444]  INFO -- : Writing /var/www/discourse/public/assets/publish-999a41b17ddf0224b00fc888ea37d6cbd4629b472676926122fe5206d5ba717b.map
I, [2024-02-07T09:57:12.674386 #3444]  INFO -- : Writing /var/www/discourse/public/assets/qunit-custom-23d2cc579f152b7ddd11e425e3eff4bcc80264f5bbc0494154e099810ed938fc.css
I, [2024-02-07T09:57:12.826484 #3444]  INFO -- : Writing /var/www/discourse/public/assets/qunit-03ec5e47030fa3064c6befc72bae7d8ac6ca3605370754cf3e0f7579980f50bf.css
I, [2024-02-07T09:57:12.836847 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js
I, [2024-02-07T09:57:12.845922 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js
I, [2024-02-07T09:57:12.855830 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js
I, [2024-02-07T09:57:12.865006 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js
I, [2024-02-07T09:57:12.874325 #3444]  INFO -- : Writing /var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js
I, [2024-02-07T09:57:12.920728 #3444]  INFO -- : Writing /var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js
I, [2024-02-07T09:57:12.921833 #3444]  INFO -- : Writing /var/www/discourse/public/assets/splash-screen-38153d76aa3609862ff8d5d5c04e41ba7280f21051bf82999734482adb7e8d4f.map
I, [2024-02-07T09:57:12.945788 #3444]  INFO -- : Writing /var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js
I, [2024-02-07T09:57:12.946850 #3444]  INFO -- : Writing /var/www/discourse/public/assets/start-discourse-5d7f503971ee51084b839dabaf96da17c03351df51736ce06fb063b64e816149.map
I, [2024-02-07T09:57:13.120427 #3444]  INFO -- : Writing /var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js
I, [2024-02-07T09:57:13.122822 #3444]  INFO -- : Writing /var/www/discourse/public/assets/test-i18n-3d7e1954db574b8753bf00eded5e2e5dfc5c5c598b9ba2268aa85e424498a6c2.map
I, [2024-02-07T09:57:13.146986 #3444]  INFO -- : Writing /var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js
I, [2024-02-07T09:57:13.149836 #3444]  INFO -- : Writing /var/www/discourse/public/assets/test-site-settings-09fdd7327b1593bc2a3ad73cfe23a068ae8ae94213e0224f36b24767f44b06a8.map
I, [2024-02-07T09:57:13.284182 #3444]  INFO -- : Writing /var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js
I, [2024-02-07T09:57:13.287444 #3444]  INFO -- : Writing /var/www/discourse/public/assets/vendor-9e7ee12d4e946d040429cc0640822ca10bb8a4099126d35f8dc8d3461b508026.map
I, [2024-02-07T09:57:13.313482 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js
I, [2024-02-07T09:57:13.314599 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js.map
I, [2024-02-07T09:57:13.321321 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js
I, [2024-02-07T09:57:13.322195 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js.map
I, [2024-02-07T09:57:13.339080 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js
I, [2024-02-07T09:57:13.340232 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js.map
I, [2024-02-07T09:57:13.347715 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js
I, [2024-02-07T09:57:13.348836 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js.map
I, [2024-02-07T09:57:13.362558 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js
I, [2024-02-07T09:57:13.363628 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js.map
I, [2024-02-07T09:57:13.371534 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js
I, [2024-02-07T09:57:13.372495 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js.map
I, [2024-02-07T09:57:13.386981 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js
I, [2024-02-07T09:57:13.388086 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js.map
I, [2024-02-07T09:57:13.395154 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js
I, [2024-02-07T09:57:13.396048 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js.map
I, [2024-02-07T09:57:13.414468 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js
I, [2024-02-07T09:57:13.415568 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js.map
I, [2024-02-07T09:57:13.423533 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js
I, [2024-02-07T09:57:13.424487 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js.map
I, [2024-02-07T09:57:13.430474 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js
I, [2024-02-07T09:57:13.431385 #3444]  INFO -- : Writing /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js.map
I, [2024-02-07T09:57:13.435249 #3444]  INFO -- : Writing /var/www/discourse/public/assets/favicon-24b22a63aae0cf353d72b6b728504377bfc42edc6563f202e3a1401763497249.ico
I, [2024-02-07T09:57:13.438322 #3444]  INFO -- : Writing /var/www/discourse/public/assets/logo-dev-0b53838dc1ee09248b94e3d4aa5c70d4a9897f26b8133d147e17bf8d41d3be7b.png
I, [2024-02-07T09:57:13.441108 #3444]  INFO -- : Writing /var/www/discourse/public/assets/logo-single-dev-5545f7e0d4d1d1d5ba821a6d8c1e394033558324e90acc1c6045cf382b4880c8.png
I, [2024-02-07T09:57:13.443571 #3444]  INFO -- : Writing /var/www/discourse/public/assets/logo-single-d7a0dacc998273856c42737dba8693fbdb9e5fd929d36afeb3f13844f147e865.png
I, [2024-02-07T09:57:13.446227 #3444]  INFO -- : Writing /var/www/discourse/public/assets/logo-ba2f2da6eac779d8b34d4aa977be739e4de07f7d34e970f4b8ac32682706c122.png
I, [2024-02-07T09:57:13.452049 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/README-cd3d86d8264ad01fe0966bc06caabc962948261d4dc6e7b9e8749ea67e23fd42.md
I, [2024-02-07T09:57:13.454583 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/assigned-822196daa0f5cef80e0ba05c2a1731f61aa12b1f9efc83d3d13fab4e3d4d467c.png
I, [2024-02-07T09:57:13.457120 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/chat_mention-bbf06e5b63dac6c41418517847799a61d6fc389facc46c372dc25eb9d815f6f8.png
I, [2024-02-07T09:57:13.459560 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/chat_message-1665cc2e8f27e3409776bd96d51ad1483a3f325afe206528e1d0032b9e826687.png
I, [2024-02-07T09:57:13.463549 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/check-dd4b108020453fcfb68e0dfc5d8558dd3bca63988e48a9de1ef9c6e4772300b7.png
I, [2024-02-07T09:57:13.466120 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/discourse-bdbc548a4e328f39b017bb143b679c5dfe7b060574760cd71d77971c2a9eff1f.png
I, [2024-02-07T09:57:13.468754 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/group_mentioned-d8f97cc6b3933d27d9f87beba43e4281b59ea9a7bcd4280cfb023f606abfe15f.png
I, [2024-02-07T09:57:13.471309 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/linked-07ccda5efd10981a2deb5c4e7e8b395e250b6744e77736994c70dba426b5906d.png
I, [2024-02-07T09:57:13.473927 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/mentioned-d8f97cc6b3933d27d9f87beba43e4281b59ea9a7bcd4280cfb023f606abfe15f.png
I, [2024-02-07T09:57:13.476500 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/posted-05bfde0bc18cfa3ec1864e2a828614cfbc00e19545a71860fa19eca01db240fe.png
I, [2024-02-07T09:57:13.479032 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/private_message-7884f8d7291161e2ebb4a4c7ba6f1bf13310ba6a4265294aafb1c5a20782cbc8.png
I, [2024-02-07T09:57:13.482046 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/quoted-2133a9d118a10109b6d72f96918ff6bfa1529dd808600cbd280871d44d43cc75.png
I, [2024-02-07T09:57:13.484714 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/replied-05bfde0bc18cfa3ec1864e2a828614cfbc00e19545a71860fa19eca01db240fe.png
I, [2024-02-07T09:57:13.487339 #3444]  INFO -- : Writing /var/www/discourse/public/assets/push-notifications/watching_first_post-05bfde0bc18cfa3ec1864e2a828614cfbc00e19545a71860fa19eca01db240fe.png
Compressing: break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js
terser '/var/www/discourse/public/assets/_break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js' -m -c -o '/var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js' --source-map "base='/var/www/discourse/public/assets',root='/assets',url='break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js > /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js.gz
part two
brotli -f --quality=11 /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js --output=/var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js.br
Done 'break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js' : 0.23 secs
Compressing: service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js
terser '/var/www/discourse/public/assets/_service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js' -m -c -o '/var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js' --source-map "base='/var/www/discourse/public/assets',root='/assets',url='service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js > /var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js --output=/var/www/discourse/public/assets/service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js.br
Done 'service-worker-da3469515669cd3904669da5fe943376ecafe237258e1493c401e226273c073a.js' : 0.24 secs
Compressing: locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js > /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js --output=/var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js.br
Done 'locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js' : 0.01 secs
Compressing: scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js > /var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js --output=/var/www/discourse/public/assets/scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js.br
Done 'scripts/discourse-test-listen-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js' : 0.01 secs
Compressing: locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js > /var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js --output=/var/www/discourse/public/assets/locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js.br
Done 'locales/ar-5ec1bebfcd04cb6e17ea0cff8e25c3f112d0b12df16fd70945a80960a00e71e1.js' : 0.12 secs
Compressing: locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js > /var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js --output=/var/www/discourse/public/assets/locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js.br
Done 'locales/be-478bb5d07b3c6ceb04dc7f6e7efe45c95cd568d914d75825f30029dcf5dc35f2.js' : 0.08 secs
Compressing: locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js > /var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js --output=/var/www/discourse/public/assets/locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js.br
Done 'locales/bg-8a0343f42ab34112f94c5352445ea865b9d2636ae12b0fe038a03eff1d05baef.js' : 0.11 secs
Compressing: locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js > /var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js --output=/var/www/discourse/public/assets/locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js.br
Done 'locales/bs_BA-9f9fe150612233ffe6146f69eee5ede13d4638dc28ceee193be16a9660d7bfb8.js' : 0.09 secs
Compressing: locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js > /var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js --output=/var/www/discourse/public/assets/locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js.br
Done 'locales/ca-944228db852bf59889b26335eb9e497d9a8bd0727dc59fb51aec2d424bcb0e76.js' : 0.09 secs
Compressing: locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js > /var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js --output=/var/www/discourse/public/assets/locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js.br
Done 'locales/cs-3a5a530036349f33145dfc5ce417bb052bb75852059a5bdafb916824525a9bb7.js' : 0.09 secs
Compressing: locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js > /var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js --output=/var/www/discourse/public/assets/locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js.br
Done 'locales/da-3ca7058747f57f99a6e47ef0a9ffc45d8ad5712f430608ffe7e2083ae4d06543.js' : 0.09 secs
Compressing: locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js > /var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js --output=/var/www/discourse/public/assets/locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js.br
Done 'locales/de-9c498b97d9937ef03b89a09f795f12a764437f92983a19be5925a687307e326d.js' : 0.09 secs
Compressing: locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js > /var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js --output=/var/www/discourse/public/assets/locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js.br
Done 'locales/el-e49ed1c5b3afae163d990473a04aef46af7fe5c3b5b6799ecca859e006a442fd.js' : 0.11 secs
Compressing: locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js
terser '/var/www/discourse/public/assets/locales/_en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js' -m -c -o '/var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js' --source-map "base='/var/www/discourse/public/assets/locales',root='/assets/locales',url='en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js > /var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js --output=/var/www/discourse/public/assets/locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js.br
Done 'locales/en-126f2d0415bdb00a0db3136d4740ed59a2ab300963a23cdde158c4e36f8a8b1f.js' : 4.67 secs
Compressing: locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js
terser '/var/www/discourse/public/assets/locales/_en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js' -m -c -o '/var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js' --source-map "base='/var/www/discourse/public/assets/locales',root='/assets/locales',url='en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js > /var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js --output=/var/www/discourse/public/assets/locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js.br
Done 'locales/en_GB-9daa4982aa730931cfab4dfd4d4430b45d3fe40cffec4f649a13510909467492.js' : 4.56 secs
Compressing: locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js > /var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js --output=/var/www/discourse/public/assets/locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js.br
Done 'locales/es-eea4482cfd5eb400c0f05cde391f9d682116f14652a0c51940a87bbafeaa5cfa.js' : 0.09 secs
Compressing: locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js > /var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js --output=/var/www/discourse/public/assets/locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js.br
Done 'locales/et-96c844e1337d7a20da19d02e9b5e2a4f5882e1a036e4433d6e5f4ec0cc477bfd.js' : 0.09 secs
Compressing: locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js > /var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js --output=/var/www/discourse/public/assets/locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js.br
Done 'locales/fa_IR-24f2a0a0ccc87f11fd5a9d66816c986d39c0cdca087b67665309ff642fda46bc.js' : 0.11 secs
Compressing: locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js > /var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js --output=/var/www/discourse/public/assets/locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js.br
Done 'locales/fi-7c9cf3a4029bfe3187d0683e2b6b68c4a62fc9f51507913b8f0303750f7861b9.js' : 0.09 secs
Compressing: locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js > /var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js --output=/var/www/discourse/public/assets/locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js.br
Done 'locales/fr-378071853444fe132f301f1ca98249348294758d680cc6acfe4159165c84e04c.js' : 0.09 secs
Compressing: locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js > /var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js --output=/var/www/discourse/public/assets/locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js.br
Done 'locales/gl-db0572af00838d126b698b56eda9cd0a5b8785edb8fd1008363b03ab0894a3e2.js' : 0.09 secs
Compressing: locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js > /var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js --output=/var/www/discourse/public/assets/locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js.br
Done 'locales/he-22611126291765ccf1c54ebd3534e8736c43957c06c792ae3f6be4464567f388.js' : 0.13 secs
Compressing: locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js > /var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js --output=/var/www/discourse/public/assets/locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js.br
Done 'locales/hr-99db6a030463019dbc5df326bef38bbc08ad04001758d7c03cf7021fadfc01b7.js' : 0.08 secs
Compressing: locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js > /var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js --output=/var/www/discourse/public/assets/locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js.br
Done 'locales/hu-f1ff918cc7cb60fc1294a09d8f29a7a186645b6b9fbdcee79a75d684784d7831.js' : 0.09 secs
Compressing: locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js > /var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js --output=/var/www/discourse/public/assets/locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js.br
Done 'locales/hy-ea04dd415900cc7a3acfcbbd4390f724014c479dde0b56b1f9caa72682da9d55.js' : 0.1 secs
Compressing: locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js > /var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js --output=/var/www/discourse/public/assets/locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js.br
Done 'locales/id-4156e6f563818171dab0310f428118f3b140f1a6a09c20892a8b61f5a306cdd9.js' : 0.09 secs
Compressing: locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js > /var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js --output=/var/www/discourse/public/assets/locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js.br
Done 'locales/it-b6f98b4d2bf29ed309dbbc74d0093bca59ac89c9ddb25bf7ce5995231333bbcc.js' : 0.09 secs
Compressing: locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js > /var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js --output=/var/www/discourse/public/assets/locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js.br
Done 'locales/ja-25ecf6a2e70c96aeb3c66bf0d01111fa3353792eb8d247004fae0842f1ac0771.js' : 0.08 secs
Compressing: locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js > /var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js --output=/var/www/discourse/public/assets/locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js.br
Done 'locales/ko-9a8439e72caacd2b1a89a459561bbf67a252b90d78d824e45d35841642ff040e.js' : 0.08 secs
Compressing: locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js > /var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js --output=/var/www/discourse/public/assets/locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js.br
Done 'locales/lt-8c0d945b7a9ce06a4e8cd13ee9a1e5b0c5570e56552abe7bb7d21d4208592cab.js' : 0.08 secs
Compressing: locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js > /var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js --output=/var/www/discourse/public/assets/locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js.br
Done 'locales/lv-c306b6de8f20f9f2baece89d8b3da02593870db13b792c58dae38151b580781b.js' : 0.09 secs
Compressing: locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js > /var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js --output=/var/www/discourse/public/assets/locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js.br
Done 'locales/nb_NO-13759e78988431c08694b1062267d819214f79493929012bc33ffc96850c2345.js' : 0.09 secs
Compressing: locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js > /var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js --output=/var/www/discourse/public/assets/locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js.br
Done 'locales/nl-44b8f3959c1bceba57a04160992df64d312e16d48ce1d6ec2a6f23995681b3db.js' : 0.09 secs
Compressing: locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js > /var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js --output=/var/www/discourse/public/assets/locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js.br
Done 'locales/pl_PL-c62c29412bba4545ce4cabf81f84cd65605152edd08c48a68602b23c0dddada8.js' : 0.09 secs
Compressing: locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js > /var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js --output=/var/www/discourse/public/assets/locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js.br
Done 'locales/pt-acfea97e78bebcb33e90df67a2555be1405cbb6596d66ec08991ab13a78285cb.js' : 0.09 secs
Compressing: locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js > /var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js --output=/var/www/discourse/public/assets/locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js.br
Done 'locales/pt_BR-97f7ab0dfa38af32f4355f6f3a3963f0e1d0f690e5766d9f721356c3d20a1e16.js' : 0.09 secs
Compressing: locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js > /var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js --output=/var/www/discourse/public/assets/locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js.br
Done 'locales/ro-9c17c40ce359e9b53ddbdf43a210e2b1f38326bc0f7c1cccdd31e80c482dd069.js' : 0.09 secs
Compressing: locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js > /var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js --output=/var/www/discourse/public/assets/locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js.br
Done 'locales/ru-2ef37637fea299907b73978185fb11136ac2d3e2f246cfb60ec17c4aaf5453b0.js' : 0.12 secs
Compressing: locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js > /var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js --output=/var/www/discourse/public/assets/locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js.br
Done 'locales/sk-e56c6ff353edd6963912888c68fa391fd320e649fe5937b18bf0759462226d71.js' : 0.08 secs
Compressing: locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js > /var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js --output=/var/www/discourse/public/assets/locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js.br
Done 'locales/sl-31e941d1a2a9694ae6d45507d18a2433aaeb3f2a0b9a501731cb9030917ab36e.js' : 0.08 secs
Compressing: locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js > /var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js --output=/var/www/discourse/public/assets/locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js.br
Done 'locales/sq-d6b848865c65e122b18cdc8ef215aa361945b0774277c009cd95f702c035f21a.js' : 0.09 secs
Compressing: locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js > /var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js --output=/var/www/discourse/public/assets/locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js.br
Done 'locales/sr-e629c5879b2fc64109d432e325ce0c881bd67b09e2e39e34c13e284bf95e91c8.js' : 0.09 secs
Compressing: locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js > /var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js --output=/var/www/discourse/public/assets/locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js.br
Done 'locales/sv-417302e22ab1bdabdb7e4d70444d973d17743f8701a9d0a3ba319eb24e5e218c.js' : 0.09 secs
Compressing: locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js > /var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js --output=/var/www/discourse/public/assets/locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js.br
Done 'locales/sw-83588e3b4ecd305f232e0185c7aeee5f17fce237d373fe6b4d7ed596dd99b152.js' : 0.09 secs
Compressing: locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js > /var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js --output=/var/www/discourse/public/assets/locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js.br
Done 'locales/te-f7a29a28a37be0dc3eb5601271ceba7e5b38e4ddef15b84e0244b2bd41cb7b2e.js' : 0.09 secs
Compressing: locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js > /var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js --output=/var/www/discourse/public/assets/locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js.br
Done 'locales/th-810bb8bdff215d13f2ca72c79eb3cce1473a5d2174ac41b0a2b02314b8712527.js' : 0.1 secs
Compressing: locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js > /var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js --output=/var/www/discourse/public/assets/locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js.br
Done 'locales/tr_TR-a2773ccb54970936cc0541671d46b70c31bdaf4569e9fe9fc9301638f423a1ec.js' : 0.09 secs
Compressing: locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js > /var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js --output=/var/www/discourse/public/assets/locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js.br
Done 'locales/uk-12d529fe25d64593ca0405e87266e879ad6c25c58ea5ed066ccbd256512253c6.js' : 0.12 secs
Compressing: locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js > /var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js --output=/var/www/discourse/public/assets/locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js.br
Done 'locales/ur-5aab52e02e2d642ef66a1a45b612799ae9224c6a618410d4e3092f4ad5eca0fe.js' : 0.1 secs
Compressing: locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js > /var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js --output=/var/www/discourse/public/assets/locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js.br
Done 'locales/vi-04047804a03d8579e25569abfe89d480a4cda48e39fe5bd9055f29708cca77f8.js' : 0.09 secs
Compressing: locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js > /var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js --output=/var/www/discourse/public/assets/locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js.br
Done 'locales/zh_CN-996d5ad4daf7bde159acf488f3df89e9fbf2eaaca953db276868d254758c5749.js' : 0.08 secs
Compressing: locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js > /var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js --output=/var/www/discourse/public/assets/locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js.br
Done 'locales/zh_TW-6be676dbd1b0915cefc9304240d9d918d184e6b9d423260fa361ed2e5d7930cf.js' : 0.09 secs
Compressing: plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js
terser '/var/www/discourse/public/assets/plugins/_footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js' -m -c -o '/var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js.map',includeSources=true"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js > /var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js --output=/var/www/discourse/public/assets/plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js.br
Done 'plugins/footnote_extra-295b457b90cb18fedfdb544868c494c71842a27c0781d3042fa4fd26589204fa.js' : 0.5 secs
Compressing: activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js
gzip -f -c -9 /var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js > /var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js --output=/var/www/discourse/public/assets/activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js.br
Done 'activate-account-9cb2015b7a740c93dc536067024f741b284ca1dd97e3ff19fa29e04e24dde7c5.js' : 0.01 secs
Compressing: admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js
gzip -f -c -9 /var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js > /var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js --output=/var/www/discourse/public/assets/admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js.br
Done 'admin-237f6e03841f868911b68a2291c517ba197f33c906206fff331c6bc7182758bc.js' : 0.1 secs
Compressing: auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js
gzip -f -c -9 /var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js > /var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js --output=/var/www/discourse/public/assets/auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js.br
Done 'auto-redirect-03e5d3e9a32ee2864cfa327612eb79b3a581c27b7c9341dcb705945abadf53d8.js' : 0.01 secs
Compressing: browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js
gzip -f -c -9 /var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js > /var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js --output=/var/www/discourse/public/assets/browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js.br
Done 'browser-detect-99f42f91bffa8ca1606d62b70bb92f981d83921e78ccdbd3d9538f07007f27ac.js' : 0.01 secs
Compressing: browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js
gzip -f -c -9 /var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js > /var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js --output=/var/www/discourse/public/assets/browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js.br
Done 'browser-update-9070f07226d022f68c06506e046ae33f8fe725302ff53955cd3d483f2fc47ff6.js' : 0.01 secs
Compressing: chunk.29563816297bab23578d.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js > /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.29563816297bab23578d.d41d8cd9.js.br
Done 'chunk.29563816297bab23578d.d41d8cd9.js' : 0.56 secs
Compressing: chunk.32579d39db9b922cbf59.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js > /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js.br
Done 'chunk.32579d39db9b922cbf59.d41d8cd9.js' : 0.01 secs
Compressing: chunk.400de55c235850808ecf.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js > /var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.400de55c235850808ecf.d41d8cd9.js.br
Done 'chunk.400de55c235850808ecf.d41d8cd9.js' : 0.01 secs
Compressing: chunk.5dcc7f080d915da65582.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js > /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js.br
Done 'chunk.5dcc7f080d915da65582.d41d8cd9.js' : 0.01 secs
Compressing: chunk.5df408b55017d116a754.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js > /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.5df408b55017d116a754.d41d8cd9.js.br
Done 'chunk.5df408b55017d116a754.d41d8cd9.js' : 0.02 secs
Compressing: chunk.89013733dad766244082.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js > /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.89013733dad766244082.d41d8cd9.js.br
Done 'chunk.89013733dad766244082.d41d8cd9.js' : 0.01 secs
Compressing: chunk.899f6c640294036601c1.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js > /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.899f6c640294036601c1.d41d8cd9.js.br
Done 'chunk.899f6c640294036601c1.d41d8cd9.js' : 0.01 secs
Compressing: chunk.9c430abf9bff67e3096e.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js > /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js.br
Done 'chunk.9c430abf9bff67e3096e.d41d8cd9.js' : 0.06 secs
Compressing: chunk.cf19b316e63f3692ad55.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js > /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js.br
Done 'chunk.cf19b316e63f3692ad55.d41d8cd9.js' : 0.01 secs
Compressing: chunk.e364c4bb60ad86f543bb.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js > /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js.br
Done 'chunk.e364c4bb60ad86f543bb.d41d8cd9.js' : 0.01 secs
Compressing: chunk.e6715d7d674703ce9537.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js > /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js.br
Done 'chunk.e6715d7d674703ce9537.d41d8cd9.js' : 0.01 secs
Compressing: chunk.ebbf0472e39001e0eb82.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js > /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js.br
Done 'chunk.ebbf0472e39001e0eb82.d41d8cd9.js' : 0.01 secs
Compressing: chunk.fd1533f5879c37cf4984.d41d8cd9.js
gzip -f -c -9 /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js > /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js --output=/var/www/discourse/public/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js.br
Done 'chunk.fd1533f5879c37cf4984.d41d8cd9.js' : 0.01 secs
Compressing: embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js
gzip -f -c -9 /var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js > /var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js --output=/var/www/discourse/public/assets/embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js.br
Done 'embed-application-1896c09383b1c54200925ff073e8a02aaf7c9f1e568deff3fa7907fba28c423f.js' : 0.01 secs
Compressing: google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js
gzip -f -c -9 /var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js > /var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js --output=/var/www/discourse/public/assets/google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js.br
Done 'google-tag-manager-78e83b8ae984b564b9745ad42fff40e8e544d5f805befd1f8265e859205f96b4.js' : 0.01 secs
Compressing: google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js
gzip -f -c -9 /var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js > /var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js --output=/var/www/discourse/public/assets/google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js.br
Done 'google-universal-analytics-v3-08add7ec997ab472fcd9f821d32ff7caf4b8b9a5de2ec18ca723a040be07a098.js' : 0.01 secs
Compressing: google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js
gzip -f -c -9 /var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js > /var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js --output=/var/www/discourse/public/assets/google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js.br
Done 'google-universal-analytics-v4-e154af4adb3c483a3aba7f9a7229b8881cdc5cf369290923d965a2ad30163ae8.js' : 0.01 secs
Compressing: onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js
gzip -f -c -9 /var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js > /var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js --output=/var/www/discourse/public/assets/onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js.br
Done 'onpopstate-handler-1ea3e951679a33d36b6c5f2f8d98016e9908c4af9110736a24b159542c83a9b8.js' : 0.01 secs
Compressing: plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js > /var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js --output=/var/www/discourse/public/assets/plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js.br
Done 'plugins/chat-a5042147e8fd41aa200c6182b331a2d6c451fdce85f476050c5bb654e357eea6.js' : 0.07 secs
Compressing: plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js > /var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js --output=/var/www/discourse/public/assets/plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js.br
Done 'plugins/checklist-273fb3ab5f7d346fa16c1482aedbd81035c5f677a83d7940da78abf7c1e16744.js' : 0.01 secs
Compressing: plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js > /var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js --output=/var/www/discourse/public/assets/plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js.br
Done 'plugins/discourse-details-48148ec534a4c5e9614302186b345123ba1358787c41bc31cbd17231f794fe42.js' : 0.01 secs
Compressing: plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js > /var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js --output=/var/www/discourse/public/assets/plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js.br
Done 'plugins/discourse-lazy-videos-93eefdae5b7d15a7cb3301aeba28935598be3f8484243b33146694690e2dd474.js' : 0.01 secs
Compressing: plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js > /var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js --output=/var/www/discourse/public/assets/plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js.br
Done 'plugins/discourse-local-dates-a1b9590bc8f26e3bcd3d4cf00594250816149a8c4f00c75ffed0bfcf3e409d74.js' : 0.01 secs
Compressing: plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js > /var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js --output=/var/www/discourse/public/assets/plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js.br
Done 'plugins/discourse-narrative-bot-643f10339e287d380f81413fde738a8ad3a6e2a5ee4d7e30f2e841f92c78e5eb.js' : 0.01 secs
Compressing: plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js > /var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js --output=/var/www/discourse/public/assets/plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js.br
Done 'plugins/discourse-presence-fc08c21eda4e026fe0e91d04f30a77cd839e6e0c9e443bc9bd9817cb6eddf0d4.js' : 0.01 secs
Compressing: plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js > /var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js --output=/var/www/discourse/public/assets/plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js.br
Done 'plugins/docker_manager_admin-f303fe8961251b1e7cef8ae8d8b5811b4b0c83694e9a8fd9a9a52b8a17f7f33b.js' : 0.01 secs
Compressing: plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js > /var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js --output=/var/www/discourse/public/assets/plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js.br
Done 'plugins/footnote-9e6a21e04868e13dc75adf73cfaab1be722d32b46af9a8b1894712c647ab6499.js' : 0.01 secs
Compressing: plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js > /var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js --output=/var/www/discourse/public/assets/plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js.br
Done 'plugins/poll-c514fbef324ad213e9825daf68ecdfebd34a708e617429299d36fa1dd3fd6c6f.js' : 0.01 secs
Compressing: plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js > /var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js --output=/var/www/discourse/public/assets/plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js.br
Done 'plugins/spoiler-alert-77512c36f465902e7dbf3b8252c7cd6387edc9bf4ca804b79466212c1d1c843d.js' : 0.01 secs
Compressing: plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js
gzip -f -c -9 /var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js > /var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js --output=/var/www/discourse/public/assets/plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js.br
Done 'plugins/styleguide-e6b8e469ca7532a25fc3bbe7661b21cffbb1884aba0df5dbf30eabd81fbde22f.js' : 0.02 secs
Compressing: print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js
gzip -f -c -9 /var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js > /var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js --output=/var/www/discourse/public/assets/print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js.br
Done 'print-page-56cf61969efa7e4e490b3b2dff49ea19a32c7996a53b6060d3e9c479ad0d0e47.js' : 0.01 secs
Compressing: publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js
gzip -f -c -9 /var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js > /var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js --output=/var/www/discourse/public/assets/publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js.br
Done 'publish-955ebc11c25146ca9f2d846e9d40e875f8f7e737f62d68a77acd0d62626a5a79.js' : 0.01 secs
Compressing: scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js > /var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js --output=/var/www/discourse/public/assets/scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js.br
Done 'scripts/discourse-boot-aa32d2b2d86a6dc385cdd26cc1a3daf031b31084d48de01bfcc15d9eff652aaf.js' : 0.01 secs
Compressing: scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js > /var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js --output=/var/www/discourse/public/assets/scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js.br
Done 'scripts/discourse-test-load-dynamic-js-600d633f9d3e3a49ad787e95d2de235a44db49bc5ac076c3a8be2c6b0fcc1f3c.js' : 0.01 secs
Compressing: scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js > /var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js --output=/var/www/discourse/public/assets/scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js.br
Done 'scripts/discourse-test-trigger-ember-cli-boot-9b14a0fc65c689577e6a428dcfd680205516fe211700a71c7adb5cbcf4df2cc5.js' : 0.01 secs
Compressing: scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js > /var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js --output=/var/www/discourse/public/assets/scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js.br
Done 'scripts/module-shims-013050f889b1900ce5d82314988dc6378bf501702813a9ef34ed957e60e5851c.js' : 0.01 secs
Compressing: scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js
gzip -f -c -9 /var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js > /var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js --output=/var/www/discourse/public/assets/scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js.br
Done 'scripts/start-app-b012dc3844eefc581e6d6d0de42cb10920aaf545a6a28137529fab0041be3ddc.js' : 0.01 secs
Compressing: splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js
gzip -f -c -9 /var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js > /var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js --output=/var/www/discourse/public/assets/splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js.br
Done 'splash-screen-4ec06c1132e220f9f4d0e7b26a520b4baab051cdc2a0a847d49f470573da51b9.js' : 0.01 secs
Compressing: start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js
gzip -f -c -9 /var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js > /var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js --output=/var/www/discourse/public/assets/start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js.br
Done 'start-discourse-7c0f5f4daf3c942b7b6ecfe8e62e2e5a0f6555924859cf055314c0df3d617353.js' : 0.01 secs
Compressing: test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js
gzip -f -c -9 /var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js > /var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js --output=/var/www/discourse/public/assets/test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js.br
Done 'test-i18n-a17a20cba2db098ef0798c7d30b4207223127cbe135f26faa0d7f705a9e6f406.js' : 0.09 secs
Compressing: test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js
gzip -f -c -9 /var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js > /var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js --output=/var/www/discourse/public/assets/test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js.br
Done 'test-site-settings-d185766bba53a871960328259ddeda3413b31134c6ca97d3157f860306deeeba.js' : 0.01 secs
Compressing: vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js
gzip -f -c -9 /var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js > /var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js --output=/var/www/discourse/public/assets/vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js.br
Done 'vendor.f196a698a6a811ae0583c1ea5284644b-53642a3b547b78e34800ab2eeb101f12b39be8c27ec85e9ad359a095161fad6b.js' : 0.06 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js.br
Done 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js' : 0.01 secs
Compressing: workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js
gzip -f -c -9 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js > /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js --output=/var/www/discourse/public/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js.br
часть 3
Готово 'workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js': 0,01 сек
Готово 'Готово сжатие всех JS-файлов': 15,84 сек
Начало компиляции CSS: 2024-02-07 09:57:38 UTC
Компиляция CSS для дефолтного 2024-02-07 09:57:38 UTC
цель препроцессинга: desktop
цель препроцессинга: mobile
цель препроцессинга: admin
цель препроцессинга: wizard
цель препроцессинга: desktop_rtl
цель препроцессинга: mobile_rtl
цель препроцессинга: admin_rtl
цель препроцессинга: wizard_rtl
цель препроцессинга: chat
цель препроцессинга: checklist
цель препроцессинга: discourse-details
цель препроцессинга: discourse-lazy-videos
цель препроцессинга: discourse-local-dates
цель препроцессинга: discourse-narrative-bot
цель препроцессинга: discourse-presence
цель препроцессинга: docker_manager
цель препроцессинга: footnote
цель препроцессинга: poll
цель препроцессинга: spoiler-alert
цель препроцессинга: chat_mobile
цель препроцессинга: chat_desktop
цель препроцессинга: poll_desktop
цель препроцессинга: chat_rtl
цель препроцессинга: checklist_rtl
цель препроцессинга: discourse-details_rtl
цель препроцессинга: discourse-lazy-videos_rtl
цель препроцессинга: discourse-local-dates_rtl
цель препроцессинга: discourse-narrative-bot_rtl
цель препроцессинга: discourse-presence_rtl
цель препроцессинга: docker_manager_rtl
цель препроцессинга: footnote_rtl
цель препроцессинга: poll_rtl
цель препроцессинга: spoiler-alert_rtl
цель препроцессинга: chat_mobile_rtl
цель препроцессинга: chat_desktop_rtl
цель препроцессинга: poll_desktop_rtl
цель препроцессинга: desktop_theme Default
цель препроцессинга: mobile_theme Default
цель препроцессинга: color_definitions Default (Solarized Dark)
цель препроцессинга: color_definitions Default (Dark)
цель препроцессинга: color_definitions Default (WCAG Light)
цель препроцессинга: color_definitions Default (WCAG Dark)
цель препроцессинга: color_definitions Default (Dracula)
цель препроцессинга: color_definitions Default (Solarized Light)
цель препроцессинга: color_definitions Default (Base)
Готово компиляция CSS: 2024-02-07 09:57:45 UTC
/var/www/discourse/lib/discourse_ip_info.rb:48:in `mmdb_download': undefined method `path' for nil:NilClass (NoMethodError)
    filename = File.basename(gz_file.path)
        from /var/www/discourse/lib/tasks/maxminddb.rake:67:in `block (3 levels) in <main>'
        from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `each'
        from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `block (2 levels) in <main>'
I, [2024-02-07T09:57:45.765426 #1]  INFO -- : yarn run v1.22.19
$ /var/www/discourse/app/assets/javascripts/node_modules/.bin/ember build
Сборка
Окружение: development
ПРЕДУПРЕЖДЕНИЕ: ember-test-selectors: Вы используете неподдерживаемую версию ember-cli-babel. свойства data-test не удаляются автоматически из вашего JS-кода.
сборка...
...[ConfigLoader]
...[Babel: @embroider/macros > applyPatches]
...[Babel: discourse-widget-hbs > applyPatches]
...[Babel: ember-source > applyPatches]
...[ember.js]
...[Babel: @glimmer/component > applyPatches]
...[Babel: pretty-text > applyPatches]
...[Babel: discourse-common > applyPatches]
...[Babel: truth-helpers > applyPatches]
...[Babel: @ember/render-modifiers > applyPatches]
...[Babel: @ember/test-waiters > applyPatches]
...[Babel: ember-destroyable-polyfill > applyPatches]
...[Babel: ember-this-fallback > applyPatches]
...[Babel: ember-cached-decorator-polyfill > applyPatches]
...[Babel: ember-load-initializers > applyPatches]
...[Babel: float-kit > applyPatches]
...[Babel: select-kit > applyPatches]
...[@embroider/compat/app]
...[@embroider/webpack]
...[SourceMapConcat]
...[Babel: discourse > applyPatches]
...[Babel: discourse-plugins > applyPatches]
очистка
очистка...
Проект успешно собран. Сохранено в «dist/».
Размеры файлов:
 - dist/assets/activate-account.js: 600 Б (343 Б сжато)
 - dist/assets/admin.js: 1,06 МБ (159,84 КБ сжато)
 - dist/assets/auto-redirect.js: 175 Б (157 Б сжато)
 - dist/assets/browser-detect.js: 425 Б (300 Б сжато)
 - dist/assets/browser-update.js: 1,51 КБ (862 Б сжато)
 - dist/assets/chunk.29563816297bab23578d.d41d8cd9.js: 4,4 МБ (990,44 КБ сжато)
 - dist/assets/chunk.32579d39db9b922cbf59.d41d8cd9.js: 46,79 КБ (15,36 КБ сжато)
 - dist/assets/chunk.400de55c235850808ecf.d41d8cd9.js: 149 Б (137 Б сжато)
 - dist/assets/chunk.5dcc7f080d915da65582.d41d8cd9.js: 4,06 КБ (1,82 КБ сжато)
 - dist/assets/chunk.5df408b55017d116a754.d41d8cd9.js: 126,09 КБ (50,68 КБ сжато)
 - dist/assets/chunk.89013733dad766244082.css: 20,97 КБ (4,87 КБ сжато)
 - dist/assets/chunk.89013733dad766244082.d41d8cd9.js: 211 Б (189 Б сжато)
 - dist/assets/chunk.899f6c640294036601c1.d41d8cd9.js: 58,76 КБ (10,29 КБ сжато)
 - dist/assets/chunk.9c430abf9bff67e3096e.d41d8cd9.js: 447,97 КБ (119,69 КБ сжато)
 - dist/assets/chunk.9ebd5cbc071c2d3f5cf7.css: 70,35 КБ (12,39 КБ сжато)
 - dist/assets/chunk.cf19b316e63f3692ad55.d41d8cd9.js: 57,28 КБ (17,43 КБ сжато)
 - dist/assets/chunk.e364c4bb60ad86f543bb.d41d8cd9.js: 21,3 КБ (8,22 КБ сжато)
 - dist/assets/chunk.e6715d7d674703ce9537.d41d8cd9.js: 6,54 КБ (2,66 КБ сжато)
 - dist/assets/chunk.ebbf0472e39001e0eb82.d41d8cd9.js: 6,67 КБ (2,52 КБ сжато)
 - dist/assets/chunk.fd1533f5879c37cf4984.d41d8cd9.js: 209 Б (187 Б сжато)
 - dist/assets/discourse.css: 171 Б (157 Б сжато)
 - dist/assets/discourse.d41d8cd98f00b204e9800998ecf8427e.css: 0 Б
 - dist/assets/embed-application.js: 1,19 КБ (579 Б сжато)
 - dist/assets/google-tag-manager.js: 526 Б (357 Б сжато)
 - dist/assets/google-universal-analytics-v3.js: 654 Б (404 Б сжато)
 - dist/assets/google-universal-analytics-v4.js: 461 Б (298 Б сжато)
 - dist/assets/onpopstate-handler.js: 157 Б (143 Б сжато)
 - dist/assets/plugins/chat.js: 950,94 КБ (147,99 КБ сжато)
 - dist/assets/plugins/checklist.js: 3,66 КБ (1,71 КБ сжато)
 - dist/assets/plugins/discourse-details.js: 1,25 КБ (614 Б сжато)
 - dist/assets/plugins/discourse-lazy-videos.js: 6,7 КБ (2,37 КБ сжато)
 - dist/assets/plugins/discourse-local-dates.js: 33,3 КБ (8,95 КБ сжато)
 - dist/assets/plugins/discourse-narrative-bot.js: 1,7 КБ (788 Б сжато)
 - dist/assets/plugins/discourse-presence.js: 11,25 КБ (2,66 КБ сжато)
 - dist/assets/plugins/docker_manager_admin.js: 38,28 КБ (7,45 КБ сжато)
 - dist/assets/plugins/footnote.js: 2,6 КБ (1,17 КБ сжато)
 - dist/assets/plugins/poll.js: 63,62 КБ (16,4 КБ сжато)
 - dist/assets/plugins/spoiler-alert.js: 3,24 КБ (1,38 КБ сжато)
 - dist/assets/plugins/styleguide.js: 153,9 КБ (21,41 КБ сжато)
 - dist/assets/print-page.js: 111 Б (124 Б сжато)
 - dist/assets/publish.js: 294 Б (213 Б сжато)
 - dist/assets/qunit-custom.css: 2,56 КБ (746 Б сжато)
 - dist/assets/qunit.css: 887,96 КБ (126,39 КБ сжато)
 - dist/assets/scripts/discourse-boot.js: 866 Б (511 Б сжато)
 - dist/assets/scripts/discourse-test-listen-boot.js: 122 Б (106 Б сжато)
 - dist/assets/scripts/discourse-test-load-dynamic-js.js: 1,14 КБ (599 Б сжато)
 - dist/assets/scripts/discourse-test-trigger-ember-cli-boot.js: 122 Б (106 Б сжато)
 - dist/assets/scripts/module-shims.js: 1,95 КБ (883 Б сжато)
 - dist/assets/scripts/start-app.js: 220 Б (177 Б сжато)
 - dist/assets/splash-screen.js: 1,17 КБ (551 Б сжато)
 - dist/assets/start-discourse.js: 518 Б (345 Б сжато)
 - dist/assets/test-i18n.js: 569,58 КБ (134,8 КБ сжато)
 - dist/assets/test-site-settings.js: 12,37 КБ (4,61 КБ сжато)
 - dist/assets/vendor.f196a698a6a811ae0583c1ea5284644b.js: 450,66 КБ (126,63 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.dev.js: 6,93 КБ (1,79 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-cacheable-response.prod.js: 603 Б (354 Б сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.dev.js: 37,73 КБ (8,89 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-core.prod.js: 3,13 КБ (1,46 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.dev.js: 32,82 КБ (8,82 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-expiration.prod.js: 6,37 КБ (2,51 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.dev.js: 33,29 КБ (7,73 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-routing.prod.js: 3,5 КБ (1,47 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.dev.js: 52,47 КБ (10,13 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-strategies.prod.js: 6,88 КБ (2,29 КБ сжато)
 - dist/assets/workbox-9b5674ca0ecb89bae1fa6f4b09a18f12/workbox-sw.js: 1,36 КБ (749 Б сжато)
 - dist/javascripts/@json-editor/json-editor/2.10.0/jsoneditor.js: 523,75 КБ (99,29 КБ сжато)
 - dist/javascripts/ace.js/1.4.13/ace.js: 371,81 КБ (101,02 КБ сжато)
 - dist/javascripts/ace.js/1.4.13/ext-searchbox.js: 11,91 КБ (3,57 КБ сжато)
 - dist/javascripts/ace.js/1.4.13/mode-html.js: 60,88 КБ (18,24 КБ сжато)
 - dist/javascripts/ace.js/1.4.13/mode-scss.js: 24,03 КБ (7,98 КБ сжато)
 - dist/javascripts/ace.js/1.4.13/mode-sql.js: 4,84 КБ (1,86 КБ сжато)
 - dist/javascripts/ace.js/1.4.13/mode-yaml.js: 5,09 КБ (1,77 КБ сжато)
 - dist/javascripts/ace.js/1.4.13/theme-chaos.js: 3,18 КБ (1,04 КБ сжато)
 - dist/javascripts/ace.js/1.4.13/theme-chrome.js: 3,04 КБ (1,06 КБ сжато)
 - dist/javascripts/ace.js/1.4.13/worker-html.js: 208,1 КБ (47,44 КБ сжато)
 - dist/javascripts/ace/ace.js: 370,75 КБ (100,77 КБ сжато)
 - dist/javascripts/ace/ext-searchbox.js: 11,91 КБ (3,57 КБ сжато)
 - dist/javascripts/ace/mode-html.js: 60,88 КБ (18,24 КБ сжато)
 - dist/javascripts/ace/mode-scss.js: 24,03 КБ (7,98 КБ сжато)
 - dist/javascripts/ace/mode-sql.js: 2,21 КБ (1,01 КБ сжато)
 - dist/javascripts/ace/mode-yaml.js: 5,09 КБ (1,77 КБ сжато)
 - dist/javascripts/ace/theme-chrome.js: 3,04 КБ (1,06 КБ сжато)
 - dist/javascripts/ace/worker-html.js: 208,1 КБ (47,44 КБ сжато)
 - dist/javascripts/chart.js/3.5.1/chart.min.js: 188,37 КБ (65,2 КБ сжато)
 - dist/javascripts/chartjs-plugin-datalabels/2.2.0/chartjs-plugin-datalabels.min.js: 12,94 КБ (5,24 КБ сжато)
 - dist/javascripts/count.js: 1,44 КБ (636 Б сжато)
 - dist/javascripts/diffhtml/1.0.0-beta.30/diffhtml.min.js: 22,41 КБ (8,53 КБ сжато)
 - dist/javascripts/embed-topics.js: 1,34 КБ (630 Б сжато)
 - dist/javascripts/embed.js: 2,47 КБ (1,01 КБ сжато)
 - dist/javascripts/magnific-popup/1.1.0/jquery.magnific-popup.min.js: 20,22 КБ (7,35 КБ сжато)
 - dist/javascripts/media-optimization-worker.js: 5,01 КБ (1,75 КБ сжато)
 - dist/javascripts/pikaday/1.8.2/pikaday.js: 42,54 КБ (9,66 КБ сжато)
 - dist/javascripts/squoosh/mozjpeg_enc.js: 39,03 КБ (10,74 КБ сжато)
 - dist/javascripts/squoosh/squoosh_resize.js: 4,53 КБ (1,29 КБ сжато)
Готово за 295,21 с.
Загрузка MaxMindDB...
Сжатие Javascript и генерация исходных карт
I, [2024-02-07T09:57:45.856251 #1]  INFO -- : Завершение асинхронных процессов
I, [2024-02-07T09:57:45.861977 #1]  INFO -- : Отправка INT для HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2024-02-07T09:57:45.864780 #1]  INFO -- : Отправка TERM для exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 111
2024-02-07 09:57:45.863 UTC [42] LOG:  получен запрос на быстрое завершение
111:signal-handler (1707299865) Получен SIGTERM, планирование завершения...
2024-02-07 09:57:45.870 UTC [42] LOG:  отмена любых активных транзакций
2024-02-07 09:57:45.888 UTC [42] LOG:  фоновый рабочий «logical replication launcher» (PID 51) завершился с кодом выхода 1
2024-02-07 09:57:45.893 UTC [46] LOG:  завершение работы
111:M 07 Feb 2024 09:57:45.904 # Пользователь запросил завершение...
111:M 07 Feb 2024 09:57:45.904 * Сохранение финального снапшота RDB перед выходом.
2024-02-07 09:57:45.997 UTC [42] LOG:  система баз данных завершена
111:M 07 Feb 2024 09:57:46.277 * БД сохранена на диск
111:M 07 Feb 2024 09:57:46.277 # Redis теперь готов к выходу, пока...
ОШИБКА
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' завершился с ошибкой, код возврата #<Process::Status: pid 3342 exit 1>
Место ошибки: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
Выполнение не удалось с параметрами {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
Загрузка не удалась с кодом выхода 1
** НЕ УДАЛОСЬ ЗАПУСТИТЬ ** пожалуйста, прокрутите вверх и поищите сообщения об ошибках, их может быть несколько.
./discourse-doctor может помочь диагностировать проблему.
2a12c656e06b5582a2cb414e35e7be3ce5f412fc3b8af27b83d61532c9595a73
Похоже на проблему с конфигурацией maxmindb или с плагином? Можете ли вы удалить эту часть вашей конфигурации? (Это просто геолокация по IP-адресу, что для большинства людей довольно необязательно, и вы можете добавить это обратно, когда станет ясно, в чём проблема.)
@Ed_S Спасибо за то, что нашли время ответить на мои вопросы. Я очень это ценю.
Я раскомментировал MaxMind, выполнил пересборку, и вот результаты:
Моя цель — максимально чистый сервер без ошибок.
Вот htop за 1 минуту после установки, если это поможет:
Ссылка для скачивания видео (8 МБ): https://global.discourse-cdn.com/meta/original/4X/2/c/7/2c72c17a42dfa11c6c2745c20ab12fb940db2806.mp4
Думаю, это успех — выглядит хорошо. Надеюсь, у вас получится успешно получить доступ к вашему форуму.
И если это так, то, похоже, проблема в области maxmindb. У меня нет опыта работы с этим, надеюсь, кто-то сможет рассказать подробнее.
Вот некоторые ошибки из pastebin:
111:M 07 Feb 2024 10:59:07.639 # WARNING Your system is configured to use the 'xen' clocksource which might lead to degraded performance. Check the result of the [slow-clocksource] system check: run 'redis-server --check-system' to check if the system's clocksource isn't degrading performance.
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has unmet peer dependency "@typescript-eslint/parser@^6.15.0".
warning "@discourse/lint-configs > eslint-plugin-ember > ember-eslint-parser@0.2.5" has incorrect peer dependency "typescript@^5.3.3".
warning " > @glint/environment-ember-loose@1.3.0" has unmet peer dependency "@glimmer/component@^1.1.2".
I, [2024-02-07T10:59:37.634934 #1]  INFO -- :
I, [2024-02-07T10:59:37.635504 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
warning Pattern ["wrap-ansi@^7.0.0"] is trying to unpack in the same destination "/home/discourse/.cache/yarn/v6/npm-wrap-ansi-cjs-7.0.0-67e145cff510a6a6984bdf1152911d69d2eb9e43-integrity/node_modules/wrap-ansi-cjs" as pattern ["wrap-ansi-cjs@npm:wrap-ansi@^7.0.0"]. This could result in non-deterministic behavior, skipping.
warning " > discourse-markdown-it@1.0.0" has unmet peer dependency "xss@*".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > ember-router-service-refresh-polyfill@1.1.0" has incorrect peer dependency "ember-source@^3.4 || 4".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > admin > ember-source > router_js@8.0.3" has unmet peer dependency "rsvp@^4.8.5".
warning "workspace-aggregator-4991301b-c83a-4afe-8d12-6d86c77e8844 > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
Есть ли что-то, что я могу сделать, чтобы устранить эти ошибки?
Было бы неплохо видеть меньше предупреждений! Особенно когда это WARNING. Возможно, стоит создать отдельную тему по этому вопросу. Скорее всего, ответ будет таким, что они безвредны и не являются приоритетом. Но всегда возможно, что они не безвредны.
Если форум работает нормально, это хороший знак.
Что касается предупреждения о xen clocksource, возможно, стоит посмотреть:
Я попробую изменить источник такта на tsc и посмотрю, станет ли redis/discourse стабильнее.
Не уверен, как решить проблему с отсутствующими пакетами npm: не знаю, имеет ли смысл запускать их вручную или есть ли файл конфигурации Discourse, который может что-то переопределить… Не могли бы вы дать какой-нибудь совет?
Я думаю, что, скорее всего, проблема не в отсутствии чего-либо, а в том, что версии компонентов не совсем подходят для корректной работы всего. Я не могу быть уверен. Похоже, что в моей установке есть rsvp 4.8.5… а также несколько других версий:
root@ubuntu-2gb-nbg1-1:~# egrep -h rsvp `find / -xdev -name yarn-error.log` | egrep -B1 resolved
  "@types/rsvp@*", "@types/rsvp@^4.0.2":
    resolved "https://registry.yarnpkg.com/@types/rsvp/-/rsvp-4.0.2.tgz#bf9f72eaa6771292638a85bb8ce1db97e754b371"
  rsvp@^3.0.14, rsvp@^3.0.17, rsvp@^3.0.18, rsvp@^3.0.21, rsvp@^3.0.6, rsvp@^3.1.0, rsvp@^3.3.3, rsvp@^3.5.0:
    resolved "https://registry.yarnpkg.com/rsvp/-/rsvp-3.6.2.tgz#2e96491599a96cde1b515d5674a8f7a91452926a"
  rsvp@^4.7.0, rsvp@^4.8.1, rsvp@^4.8.2, rsvp@^4.8.3, rsvp@^4.8.4, rsvp@^4.8.5:
    resolved "https://registry.yarnpkg.com/rsvp/-/rsvp-4.8.5.tgz#c8f155311d167f68f21e168df71ec5b083113734"
  rsvp@~3.2.1:
    resolved "https://registry.yarnpkg.com/rsvp/-/rsvp-3.2.1.tgz#07cb4a5df25add9e826ebc67dcc9fd89db27d84a"
  rsvp@~3.2.1:
