Osama
8 ديسمبر 2017، 11:03ص
As you can see the “Expand” button is between the name and the avatar, whereas on desktop the button is aligned to the right after the name/username.
It seems this left floating in mobile/user.scss is the culprit
https://github.com/discourse/discourse/blob/master/app/assets/stylesheets/mobile/user.scss#L114-L116
If I float it to right in my chrome dev console I get this:
Which seems to fix this particular issue, but might break something else.
3 إعجابات
sam
(Sam Saffron)
8 ديسمبر 2017، 10:11م
Yeah I think you would need to test this with all the admin controls as well. Not sure what the impact would be.
User page on mobile really needs a very good cleanup @awesomerobot , expanded we are also using up tons of pointless space.
6 إعجابات
Mobile needs some general cleanup for sure.
@osama the button position here is definitely odd and does seem to make more sense on the right. I can take a quick look at this and see if the change impacts anything else (including admin controls on the user profile).
6 إعجابات
Yeah this definitely needs work, if you could do a quick pass.. it’s been messed up for quite a while on mobile.
3 إعجابات
ok, so I’ve cleaned up the user profiles on mobile a bit and it’s live on meta —
10 إعجابات
codinghorror
(Jeff Atwood)
تم إغلاقه في
15 ديسمبر 2017، 2:00ص
7
This topic was automatically closed after 47 hours. New replies are no longer allowed.
