サードパーティ製プラグインにより安定版のビルドに失敗
Hey all,
can’t seem to rebuild stable today
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 13067 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:112:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
39a6896636b4ad5f5fb7f82cc9bc13d96bb84e6c88f4260ed9241d5025baa074
I’m also seeing (further up)
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rake-12.3.1/exe/rake:27:in <top (required)>
Tasks: TOP => db:migrate => db:load_config => environment
and
I, [2019-01-07T04:35:29.137437 #14]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
This monkey patch is no longer required.
rake aborted!
NoMethodError: undefined method `attributes' for DirectoryItemSerializer::UserSerializer:Class
Did you mean?  attr_writer
/var/www/discourse/plugins/discourse-locations/plugin.rb:83:in `<class:UserSerializer>'
/var/www/discourse/plugins/discourse-locations/plugin.rb:82:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:298:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:296:in `each'
/var/www/discourse/lib/plugin/instance.rb:296:in `notify_after_initialize'
/var/www/discourse/config/application.rb:256:in `each'
/var/www/discourse/config/application.rb:256:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:69:in `block in execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:62:in `with_execution_control'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:67:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:51:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/application/finisher.rb:75:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/application.rb:361:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/config/environment.rb:5:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/dependencies.rb:283:in `require'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/dependencies.rb:283:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/dependencies.rb:249:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/application.rb:337:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/application.rb:520:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rake-12.3.1/exe/rake:27:in `<top (required)>'
This 3rd party plugin (discourse-locations) is no longer compatible with stable.
Thanks @sam .. I missed that bit of news :slight_smile:
Sorry, I should have made it clearer in the plugin description that the Locations Plugin, and all my other plugins, are always compatible with the latest version of Discourse.
