Le pied de page n'est pas aligné avec la largeur de Discourse
I’m trying to create a foot something like: https://discuss.newrelic.com/
I snagged the footer I found there, stripped stuff out, and did my best to snag the related CSS. It’s sort-of close, but the width is the whole browser rather than just the part that Discourse is using.
What am I missing?
Example: https://s2.literatecomputing.com/
CSS: : discourse-theme-footer/desktop/desktop.scss at master · pfaffman/discourse-theme-footer · GitHub
Footer: discourse-theme-footer/desktop/footer.html at master · pfaffman/discourse-theme-footer · GitHub
You missing a div with .container class. Wrap all .footer-col and .social-icons like below
<div class="container">
  <div class="footer-col"></div>
  <div class="social-icons"></div>
</div>
Also remove the margin (only for div#footer-top) in this line.
That seems to have done it. CSS remains a twisty maze of passages that all look alike. It always makes sense when it’s right, but often I can’t guess why it’s wrong.
A thousand thank-yous.
Ah, one problem, the Social Icons are outside of the desired margins. I think they’re in the container, but there’s something else I’m missing.
Ils ne sont pas à l’intérieur du conteneur, comme vous pouvez le voir ici :
Au fait, vous pouvez simplement ajouter :
.social-icons {
    margin-right: auto;
    margin-left: auto;
    padding-left: 15px;
    padding-right: 15px;
    max-width: 1170px;
Ou, alternativement, placez le div social-icons à l’intérieur du conteneur :wink:
MODIF : à la ligne 63, vous avez un </div> qui ferme le footer-col n°4 ; à la ligne 64, l’autre </div> ferme le container. Supprimez ce dernier div et ajoutez-le après la partie social-icons.
I’m using a different footer style of my own, how will I make my footer fit with Discourse on mobile
I am also having grey boxes in between categories on my forum, incorrect spacing at the bottom
Can you provide information on how to fix this?
Using media queries
Share the code you are trying to use
Here is the footer code for my forum, Can you provide how to make spacing accurate on mobile Thanks.
You have some problems with padding and margin settings in your media query.
Try to change it this way:
@media (max-width: 767px) {
  .footer {
    font-size: 14px;
    padding: 0px;
    margin-top: 0px;
  .footer .footer-left,
  .footer .footer-center,
  .footer .footer-right {
    display: block;
    width: 100%;
    text-align: center;
  .footer .footer-center i {
    margin-left: 0;
  .footer .about {
      padding-left: 15px;
      padding-top: 40px;
  .footer .name {
      padding-bottom: 40px;
it should work much better.
Thank you @dax, much appreciated :slight_smile:
