Icono del encabezado invisible tras la actualización
The same header icon as before:
This time upgrade from 2.0.0 to v2.3.0.beta2 +206
Resulted: icon is still the right size and highlights properly, but the lightning is not visible anymore. I wonder what happened here?
Can be the reason in this?
This is very likely. I will proceed with testing…
I used this as a guide and managed to fix it: Introducing Font Awesome 5 and SVG icons - #27 by tshenry (Also added fa-bolt to settings…)
Now I’m pondering how to change colour of the top buttons…
You need to target the SVG element and apply color to it using CSS.
I’m already getting a colour change by changing the colour scheme of the entire site. However, if I set the color of the top texts and icons to ffffff, they appear grey; if efffff, they appear quite blue…
weird colours.pdf (1.1 MB)
By default we adjust the colors to reduce contrast against the background. You can override this behavior with CSS (add to admin > customize > themes > edit html/css > common).
ul.d-header-icons .d-icon {
   color: #fff;
Thank you, it worked like a charm!
All header problems fixed! :slight_smile:
(switched this to a brand new topic)
