Help us test select-kit
We’re in the process of re-writing most of our dropdown, list, multi-select, … kind of components. See below for examples!
If you notice anything weird or not working please report all UX bugs in this topic.
Components list
{{category-chooser}}
{{category-selector}}
{{list-setting}}
{{multi-select}} for colors
{{dropdown-select-box}}
{{future-date-input-selector}}
{{search-advanced-category-chooser}}
{{combo-box}}
{{toolbar-popup-menu-options}}
{{period-chooser}}
{{category-drop}} and {{tag-drop}}
{{mini-tag-chooser}}
34 лайка
Наличие очень длинного названия категории и отключение тегов приводит к следующему:
Thx @dax I will revisit this when I finally push the tags chooser revamp. Should happen quite soon.
When adding multiple users to a PM, the user field automatically collapses when not in focus. When this happens the field height increases by 4 pixels, padding is removed (resulting in a overall field height decrease and no left margin for the text) and the “x more” indicator has no spacing to the left so it touches the username.
it’s not using select kit
A post was split to a new topic: Adds support for label and for attribute on select-kit
Thanks to everyone actively testing and reporting bugs. I will now close this topic. Any further issue, please open a dedicated topic.
