How do I create a page not a topic?
I think the easiest way would be to hack the Core … but changes would be lost with an update.
You could fork so the changes wouldn’t get wiped … but very bad idea
I have been working on a plugin It’s very much pre-alpha but feel free to study it in hopes it can give you an idea of how to write your own plugin.
https://github.com/Mittineague/discourse-newpage
Need hack the core? Do you have other idea?
What most people do is set up another site on a different domain for pages, using wordpress or ghost or something else. Then you add a shared navigation across the top and you’re done.
Here’s how Namati does it with WordPress:
But I want a plugin, seems to have no way
You are right - there is no way. Discourse is not a content management system but a discussion platform. You need to set up another site for the rest of your pages.
Or, like @Mittineague says, make it happen by creating a plugin to share with the community. I think it would be valued - especially for sites that just need one or two more pages, or who really don’t need a full fledged website to accompany their community discussions. I’d probably use it for some of my communities! ![]()
I don’t think this feature is going to be implemented soon in Discouse. Please see below topic.
https://meta.discourse.org/t/adding-custom-static-pages/5497
You can do as Jeff mentioned in the post or we have a plugin for this feature but it doesn’t seem to work stable yet.
https://meta.discourse.org/t/easy-to-use-static-pages-plugin/36280
So, as said by @tobiaseigen, it is better to host your custom webpages in your domain(www.example.com), and host discourse in sub-domain(forum.example.com).
Wie konfiguriert man Discourse Docker, damit es auf demselben Server zusammen mit beispielsweise nginx läuft, um dies zu erreichen? Ich weiß, dass nginx Reverse-Proxy unterstützt. Gibt es Anleitungen zur Einrichtung von Discourse in diesem Modus?
