How do I get all posts from a specific category?
Is there a way to get all the posts from a certain category by a specific user?
Something like this?
https://meta.discourse.org/search?q=category%3Abug%20user%3Acpradio
「いいね!」 4
i didnt see it in any of the posts.. is there a specific URL i can query?
Don’t look at the results, look at the URL and how it is querying for a category and a specific user.
thanks got it, is there any way to get the raw data? i saw a search() function in the API, but not sure how to include the parameters.
gives you
https://meta.discourse.org/search.json?q=category%3Abug+user%3Acpradio
awesome thanks.. anyone know how to use the Ruby gem to call this?
https://github.com/discourse/discourse_api
I see in the source code, but wasnt able to create the right parameters to successfully retrieve the query results.
  # @param term [String] a search term
  # @param options [Hash] A customizable set of options
  # @option options [String] :type_filter Returns results of the specified type.
  # @return [Array] Return results as an array of Hashes.
  def search(term, options={})
    response = get('/search/query', options.merge(term: term))
    response[:body]
  end
Sorry, I’m not very keen on Ruby, but it should be as simple as sending a HTTP Get request to https://meta.discourse.org/search.json?q=category%3Abug+user%3Acpradio and just replacing the string sent as q=
Looks like it would be api_object.get('/search', {q: 'category:bug user:cpradio'})
