I’m using webhooks to process new users via zapier , and lately it’s being triggered too often.
The option we have in the admin is When a user is created, approved or updated.
I thought that the email would only be sent on new user creation . but we’re getting it even if the user had a badge awarded, joined a group, etc.
So the question is.. what’s the best way to identify when the webhook is related to a new user, vs a user being updated?
Thanks!
Hmm I think our webhook should be more distinct here.
user created
user updated
Can you add this to your list @neil
simon
08.Октябрь.2017 22:01:13
You can get that from the X-Discourse-Event header field. When a user is created that field’s value will be user_created.
It seems that the User user_updated webhook is being sent every time a user creates a Topic or a Post. This didn’t used to happen and seems like a bug.
simon:
header field
Thanks @simon it looks like Zapier doesn’t surface the headers which are sent over. Assuming we get the user_created & user_updated in the body of the webhook, I should be able to know just when to perform an action for a newly created user.
For the record, these are the fields I can act on via Zapier as of Oct 7 2017
I asked Zapier about this, and while the information sent in the header is awesome, they don’t include it in Zaps .
I’d love to see this information sent in the body of Discourse’s webhook, and not just the headers.
Given this set of headers:
Request URL: https://hooks.zapier.com/hooks/catch/REDACTED/
Request method: POST
Accept: */*
Connection: close
Content-Length: 7429
Content-Type: application/json
Host: hooks.zapier.com
User-Agent: Discourse/1.9.0.beta12
X-Discourse-Instance: https://SITE_NAME
X-Discourse-Event-Id: 168
X-Discourse-Event-Type: user
X-Discourse-Event: user_updated
Specifically: X-Discourse-Event-Type and X-Discourse-Event
Though I can see where X-Discourse-Instance would be useful too.
Maybe this change can be included with the fix for 71643
neil
(Neil Lalonde)
24.Октябрь.2017 20:35:40
The issue with user_updated always being triggered was fixed by @tgxworld .
simon
05.Декабрь.2019 17:15:44
8
watchmanmonitor:
Я спрашивал об этом в Zapier, и хотя информация, отправляемая в заголовке, отличная, они не включают её в Zaps .
Это немного сложно, но вы можете извлечь заголовок запроса веб-хука в Zapier с помощью метода, описанного в этом посте: https://meta.discourse.org/t/discourse-webhooks-and-zapier/56753/32 .
